Question about Dell Inspiron E1505 Notebook
I have a Dell Inspiron 1526, and have had recent problems with getting the screen to come on. Now, it won't come on at all. When I power up the laptop, the power light comes on, but the screen is blank and the HD led is blank. I've tried reseating RAM, the processor, and holding down Fn while powering up. The number lock blinks rapidly, while the other two leds stay constantly lit. Have scoured the net for what that code means, with no firm answer. Any suggestions? Oh, I also tried using an external monitor with no luck. Is it the motherboard? The HD is relatively new, so probably not that. Thanks in advance for your help!
    Problem Solver:
  • 5 Answers
Sounds like the motherboard, BUT have you dismantled the computer. Remove the RAM the drives, The HDD, the BIOS battery, the power cord, the computer battery and everything that can be removed relatively easily. Clean everything out with compressed air. Not to crazy though...take it easy!
If a friend has a similar computer try the screen on his once its removed.
Once clean reassemble.
Dells shortcuts are a little different than others. You may need to press F2 and run diagnostics from the boot menu or F8, or F12 which brings you to the BIOS. All at startup. Not 100% sure on ur Dell but it is on mine.
From this point I'm not sure...Hopefully this will help get you in the right direction. Best of luck!
Posted on Nov 09, 2010
Guys help pls!
Hi, the audio driver is the AC97 a google search will get you a free download, or go to this link: http://www.driversbay.com/drivers/notebooks-tablet-pc/dell/inspiron-1526/microsoft-windows-xp/
For your vidio card I would go to Del website for the latest driver.
Hope this helps
Jul 22, 2010 | Dell Inspiron 1526 Notebook
Restore defaults on Dell
Put the DVD with Vista on it in and reboot. Follow the promts on the screen.
Apr 15, 2010 | Dell Inspiron 1526 Notebook
Error Code 0146
Found in Dell solutions:
http://en.community.dell.com/forums/p/19314740/19628095.aspx?c=us&l=en&cs=&s=gen
Apr 04, 2010 | Dell Inspiron 1526 Laptop
When i start up my dell inspiron 1521 it goes into startup mode then screen goes black.took the power cord out n it will start up plug it back in the screen will go blank again.it will run on battery n the...
I have a Dell Inspiron 1525 and had the same exact problem. I finally called Dell and they sent a tech out. They replaced my power cord and all the software. The reason for this is because Dell Inspirons has a default in the AC cords. Sounds like the AC power cord is the problem. You could find someone who has this cord and test your Inspiron with it or try calling Dell! It worked for me.
Jan 28, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
My dell inspiron 1526 turns on but the screen stays black, the power light turns on but the screen does nothing
oks just check the bios settings , the memories and the hdd getting detected if no then remove the ram clean it with an eraser and put it back, if yes then plz put a windows cd and repair your os or format it
Jan 11, 2010 | Dell Inspiron 1526 Laptop
How to do a master reset on a dell Inspiron 1526, but I don't have any of the discs.My computer keeps going to a page saying I have to type in my dell password. I do that and it goes to a black screen...
Step 1: Start up your computer and as the computer logo appears (such as Dell orHP) hit "Ctrl>F11" simultaneously. This may be different fordifferent machines, but the most common keys to hit are"Ctrl>F11." If this does not work, the F8 key has been said towork for certain machines.Step 2: Select "Repair My Computer" from the list of menu options thatappear and press "Enter."
Jan 04, 2010 | Dell Inspiron 1526 Notebook
Dell inspiron 1526 has problem (plugged in ,not
Hello there:
First you will want to ensure that the power cord is fully inserted at both the laptop and all the connections for the cord and that it is getting proper power. and check tosee that the connector thatthe power cord goes into is not loose if so this will have to be repaired
next remove the battery from the computer and unplug the power cord and then press in the power button for 1 minute than if this has a reset button on the back use a toothpick or a small item and pressin on the reset button for 30 seconds
now insert the power cord (NOT THE BATTERY YET)
and turn on the computer and it should now start up if so insert the battery and leave charge for 1 hour than you should be ok from here ok
Please keep me posted on this so i can assist you if needed.
Best regards michael
Dec 16, 2009 | Dell Inspiron 1526 Laptop
Dell Inspiron 1526 blank screen after hibernation
Press Fn Key plus POWER key ans see if the diagnostics will start. If no go, then the system is likely in a No POST state.
You can check the warranty status here:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&cs=04&l=en&s=bsd&~ck=anavml
and no paperwork is needed to get warranty support, all you need is the express service code on the bottom and be a authorized user of the system.
Oct 21, 2009 | Dell Computers & Internet
Dell Inspiron 1526 LCD inverter unable to turn on lamp error message in diagnostics. PC boots up to login user screen and then goes black with the exception of the mouse prompt. It is visible moving...
Go on ebay and buy a new inverter for less than $10. Go on youtube to see how to replace the dell inspiron 1526 lcd inverter or the dell inspiron 1526 lcd screen. I put the lcd screen on because sometimes the problem might be your screen. If things don't work after installing the new inverter board, then buy a new lcd screen off ebay. The inverter board and screen are easy to install. Just go on youtube.com to find a video that walks you through it. The inverter sits at the bottom of the lcd screen. Some are screwed on, some are welded onto the screen, some are held by a small piece of tape. Even if you have to pry the old one off, just put the new on on held by a small piece of tape.
10results for Dell Inspiron 1526 inverter board
Dec 17, 2017 | Dell Inspiron 6400 Notebook
Dell Inspiron E1505 Notebook Logo
268 people viewed this question
Alun Cox
