Question about Barco iQ Pro G300 LCD Projector
I purchased a second hand iq g 300 .. has i excess of 9000 hours on the clock.. and the colours are washed out/dull ... have the lcd panels had it or id there some other issue .... otherwise the projector is in great condition
  • 3 more comments
  • David Ward
    David Ward Nov 10, 2010
    Hi ...thanks for the response ..cleaning and inspecting the optical engine ..does it require a service technician or can it be completed by a lay person... and if requires a technician how many hours to complete the task... am trying establish if the projector is worth keeping
    thanks
    David
  • David Ward
    Hi There .. thanks for that... haven't used one of these services before .. what a God send... the projector came without the password .. can it be recovered or does it need a visit to Barco
    thanks
    David
  • David Ward
    David Ward Nov 11, 2010
    Thanks for all of the assistance
    David
  • David Ward
    Sensational service!!
  • roger
    roger Jun 18, 2012
    default password is 0000
  • Barco Master
  • 11,800 Answers
No, the LCD panel wouldn't cause that: their performances don't change with the age, when they age individual pixels start to fail and appear as bright spots.
No, in your case it's either the optical engine - it needs cleaning and inspecting - or the bulb.
Posted on Nov 09, 2010
  • Azrael SRL Nov 10, 2010
    If you haven't done this before then definitely yes, it's a job for a pro - it's very easy to damage the lenses by accident. It will take around 2.5 hours.
  • Azrael SRL Nov 11, 2010
    For the password (if the unit is locked) only Barco can help you, they are the only ones with the necessary tools
I have a Siemens washinmachine iq 300 and i want to unlock the child lock. How do I do it?
about using only natural methods to increase your erect p enis size by more than 3 inches.
http://fitnesseducations.com/asox9-reviews/
Sep 02, 2016 | Siemens IQ-300 WM12Q390GB White 598 mm...
Siemens washing machine display F21 flashing. Fault is not resetting after power off.vario perfect iq 300.
Try this, unplug it and press and hold down the power button for 10 seconds and then plug it back in and see if the error code has cleared.
Aug 28, 2016 | Siemens Washing Machines
Siemens iq 300 washer
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Enter IQ 300. You will be presented with a list of common repair parts and may be able to view a general video showing how to disassemble it.
May 26, 2016 | Washing Machines
How do I remove child lock from a siemans washer
The display will have a icon for a lock. It may be for one or two buttons to be held for 5-8 seconds to unlock. It's the same thing as locking it.
Feb 29, 2016 | Siemens IQ-300 WM14Q390GB White 598 mm...
My screen colouration seems to have gone and there is allot of flickering? is this fixable and if so what is the estimated cost for this?
LG Zenith recommends replacing the Y-sustain, x-sustain and digital /logic board as a set. After you replace you will need to check the voltages listed on your panel. The cost if bought from second hand dealer like shopjimmy.com will be around 250-300 for the parts.
please leave feedback
Feb 21, 2011 | LG 42LC3R 42 in. LCD TV
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Apollo vp835 projector,poor quality. Replaced bulb, didn't help
you have at least 2 issues with your optical engine. both are due to excessive dust and heat. the fly-eye (diffuser) lens is fried, as is the light filter on one of the lcd panels. unfortunately, you cannot purchase individual parts for the optical engine. you'll have to replace the whole thing.
Oct 23, 2009 | Office Equipment & Supplies
Optoma DV10 loud vibration and odd colours
check the colour glass wheel is shattered with a piece of glass still stack to the wheel. it not even thats why it vibrates
Aug 17, 2009 | Optoma MovieTime DV10 DLP Projector
Time is behind 4 hours, wont start with new battery
I inserted new batteries, second hand would not move at all. 1 hour later I came back and clock was running with the correct time.
Jan 29, 2009 | La Crosse Radio Controlled Atomic Clock
Kogi l7eh-ta ko 17 in
It looks like your power supply is shutting down (terminal overload shutdown) due to excessive current consumption. You need to get a power supply that meets the voltage and current requirements of that monitor or greater current reuirements.
Sep 03, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Barco iQ Pro G300 LCD Projector Logo
144 people viewed this question
Top Barco Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Barco Office Equipment and Supply Expert? Answer questions, earn points and help others
