Question about Goodman GMS90703BXA Heater
Blowing cold air >has pilot light on<
  • Goodman Master
  • 4,655 Answers
Here is a manual that has the parts break down. Click Here=> Goodman GMS90703BXA Sounds to me that your gas valve is not responding to the thermostat calling for heat. Double check gas valve settings and also have someone near switch the heat on to say about 90 degrees. You should hear a relay click sound to pull the gas valve open. Also Click Here=> Appliance 991 Help Forum That manual that is on that page has all needed information a tech or installer will need so please read carefully and use caution. I find that very odd that the fan will run before the heat exchanger reaches higher temperatures. Indicating a possable electronic failure. It must wait until hot enough before fan comes on. In left sidebar and 7 links down is the diagnostics PDF. Click and save if you like. Contact me here or from that site and I will try my best to assist you while we try to find out why the electronics is allowing fan to run first. There are different models on that PDF so keep that in mind that all models listed are somewhat the same yet not exactly. There shoud be a light code to look for that just may point to the problem the furnace is having. If not comfortable then please have a qualified Technician help you solve this. Just let me know when ready, Thanks, Sea Breeze
Posted on Nov 09, 2010
Electronic ignition hot water heater (6gal) lights but wont get water hot. The red light inside my RV goes off and back on after about 3 minutes. When I checked the unit outside, the pilot is lt, but not...
check to see if setiment has settled on the pilot....blow it out with air if it has. This issue comes up often with water heaters and rv refers. If that is not the problem and the pilot remains lit, but never increases when the thermostat is turned up, you probably need a new gas valve/thermostat.
Feb 26, 2014 | Jayco RVs
2004 Honda Pilot hot & cold
Sounds like a blend door problem under the dash.
Jun 25, 2013 | Cars & Trucks
Ruud 90 plus will not blow hot air
My Ruud is a different model, so this may not work. Remove the cover to the burners. Look on the left side for a small rubber hose going to a metal cylinder. Remove the hose and blow through it to remove any moisture. Replace the hose and see if the burners start up.
Feb 23, 2013 | Ruud Rheem Rgfe09ezcms Gas Furnace
Why other leter n ke board not function
its just dirty contacts if you can open your keyboard, clean contacts with non rubber eraser like the ones used by engineers and draftsmen. also include the rubber contacts under the keys
Jul 25, 2012 | Acer Computers & Internet
Diagnostic Report (1.9.0027.0): ----------------------------------------- Windows Validation Data--> Validation
> Blocked VLK
> Windows Product Key: *****-*****-3R89F-D2KXW-VPK3J
> Windows License Type: Volume
> Windows OS version: 5.1.2600.2.00010100.3.0.
Where did you obtain the CD-ROM that you used to install Windows,
using that Product Key?
A "VLK' is a "volume license key" -- when some organization purchases a specific number
of licenses to install Windows XP, Microsoft issues a "volume" license-key,
so that all (up to the number of licenses they purchased) computers in that organization
can use the _same_ license-key.
If Microsoft detects that the product-key is being used *OUTSIDE* of that specific organization,
then Microsoft will *BLOCK* all attempts to "activate" Windows that cite that product-key.
I did a Google-search for '3R89F-D2KXW-VPK3J' and Google reported 37 THOUSAND web-pages that contain that string. That is a *DEFINITE* sign that the VLK has been "leaked" onto the Internet.
So, you are trying to use a "non-genuine" copy of Microsoft Windows XP.
Thus, you are a "SOFTWARE PIRATE".
Purchase a *GENUINE* copy of Windows XP (or Vista or 7) and install it,
and throw away your "pirated" copy of Windows.
Dec 10, 2010 | Computers & Internet
2006 yamaha straoliner, engine code 37 comes up
Displayed Fault Codes For The ‘Liners
  • 12 - Crankshaft Position Sensor <<Dead Engine>>
  • 13 - Cyl #1 Intake Air Pressure sensor (open or shorted)
  • 14 - Cyl #1 Intake Air Pressure Sensor (hose system) - Clogged or detached
  • 15 - Throttle Position Sensor (open or shorted)
  • 17 - EXUP Servo Motor Ckt. (open or shorted)
  • 18 - EXUP Motor Locked Up – Frozen
  • 19 - Blue/Black ECU wire broken or disconnected <<Dead Engine>>
  • 22 - Air Temp Sensor (in headlight) (open or shorted)
  • 24 - O2 Sensor – No Normal Signal Received
  • 25 - Cyl #2 Intake Air Pressure Sensor (open or shorted)
  • 26 - Cyl #2 Intake Air Pressure Sensor (hose system) - Clogged or detached
  • 28 - Engine Temp. Sensor (open or shorted)
  • 30 - Lean Angle Sensor Latched Up (Bike Laid Down) <<Dead Engine>>
  • 33 - Cyl #1 L. or R. Faulty Ignition Coil << May Run >>
  • 34 - Cyl #2 L. or R. Faulty Ignition Coil << May Run >>
  • 35 - Cyl #1 L. or R. Faulty Ignition coil << May Run >>
  • 36 - Cyl #2 L. or R. Faulty Ignition Coil << May Run >>
  • 37 - ESC Valve Stuck Open (Engine Speed Control / High Idle Speed)
  • 41 - Lean Angle Sensor (open or shorted) <<Dead Engine>>
  • 42 - Speed Sensor – No Normal Signals Received OR Neutral Switch (open or shorted)
  • 43 - Fuel System Voltage (ECU Unable to Monitor Batt. Voltage)
  • 44 - Error In Writing Amount Of CO Adjustment To EEPROM
  • 46 - Voltage To F.I. System Not Normal
  • 50 - ECU Internal Failure – Memory Check <<Dead Engine>>
  • 70 - Engine Idling Stop – After 20 Minutes Of Idling
Apr 08, 2009 | 2006 Yamaha Stratoliner S
Pliot is lit...no heat
check to see if voltage to gas valve if no replace or check wires
Jan 06, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Goodman GMS90703BXA Heater Logo
122 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
