Question about Samsung CLP 300 Laser Printer
Toner waste bin is full - Samsung CLP 300 Laser Printer
  • 1,218 Answers
Check the following steps :
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
Posted on Nov 09, 2010
Magicolor 7300 print window says Ink/toner waste bin full! but it's new
The clear section of the waste toner box where that goes inside the machine check that area sensor located there might have toner on it so the printer thinks the waste toner box is full
Apr 16, 2012 | Minolta magicolor 7300 Laser Printer
Green and amber light on together
You're almost out of toner (depending on where the light flashes, that toner needs to be replaced soon). It also can be the waste bin, that is full, in that case you have to replace the waste bin by an empty one.
Sep 27, 2011 | Samsung CLP 315 Laser Printer
Getting a false error message that the ink/toner is empty and wastebin is full when i print to my phaser 8860 from a macbook on 10.6 (networked printer)
The waste bin full error can occur if the waste bin was not removed from the machine for over 10 seconds when it was emptied. Please remove the waste bin and wait for a full 10 to 20 seconds before replacing the Waste bin.
If the message still displays turn off the machine and leave it off for 1 minute then turn the machine back on.
Then run software update to make sure you have the latest OS updates.
Then delete the printer and re-add the printer.
Aug 04, 2011 | Xerox Phaser 8860MFP Printer
I get error message "waste
Open the right side door. there at the bottom is a long plastic bottle full of waste toner. If you have no spare bottle then carefully (dont create dust) empty toner into a bin liner. Now tap the bottle on the table to allow any toner on the sides to fall back to the bottom. now refit and all should be well.
May 10, 2011 | Lexmark C544dn Laser Printer
My Samsung CLX-3175 printer will not print - the message is replace/install toner waste bin. I have emptied the waste bin of all the ink and replaced it and still the message will not go. I have a stack...
open the cover and now remove the waist toner container (you say it is empty) check the conection to the drum unit sometimes if the waist toner is verry full there is a pille of toner closing this connection, now clean it and all the sorounding from the toner and mount the waist container back in his possition, close the front cover and try, it should work now.
Apr 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung clp 315 printer shows "replace/install
Hi there your printer wast toner drum is full. So just remove that and make empty the drum & then refill the toner box. now use. Thanks.
Dec 22, 2010 | Samsung CLP 315 Laser Printer
How to solve the problom of 'install/replace toner waste bin'?
Laser printers "print" by throwing toner onto a electrostatically-charged drum. The ink that sticks is then heated, and melts into the paper. The ink that does not stick falls into the "waste-bin".
Eventually, that waste-bin gets full, and needs to be removed, and emptied.
Aug 24, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
CLP 510 error
Sir,
Inside the front cover of the Samsung CLP-510 printer is a "Waste Toner Bin" - this bin collects any toner which is not fused to the paper during the printing process. The photo at the left shows the waste toner bin installed in its correct position.As you print, the waste toner bin "fills up" with wasted toner, and you have to replace it on a regular basis. Other printers send waste toner back to a separate compartment in the toner cartridge, however Samsung prefers to sell you and additional "consumable" - apparently the $130 cost of the toner cartridges (x4 cartridges = $520/refill) just isn't sufficent revenue.
In the photo below, we see the waste toner bin removed from its operating position, and lying down on the printer door - Just tipped down from its normal place.
Note (1) - this is an optical sensor which detects when the waste toner bin is full - A "bump" on the bin (2) fits into the sensor notch when the bin is in position. An optical sensor looks though the "bump" and is supposed to detect when the toner reaches this level.
Note that one of the inlets for waste toner (3) is just above the sensor "bump" (when the bin is in it normal position). You can also see the round feed which goes into this hole, just above the sensor notch (1).
The problem occurs because the waste toner being injected into the bin "runs down the side" through the sensor "bump" - after a little while, this dirties the walls of the "bump", and although this is nowhere near as opaque as the actual toner, the sensor is sensitive enough to decide the bin is full and shuts down printing. In my opinion, this represents two fundamental flaws in the design:
  • The toner inlet should not be positioned such that toner entering the bin runs through the sensor area.
  • The optical sensor should not be so sensitive that a little dirt is detected as a full bin.
It is interesting to note that Samsung explicitly advises that you not empty and reuse the waste toner bin - The overly sensitive sensor pretty much guarantees that you cannot do this, as it is virtually impossible to empty the bin without getting toner into the sensor bump, after which the printer will refuse to print and direct you to replace the bin.
The Cure The first time this happened, I noted the dirty sensor notch and cleaned the area - It lasted only for a few pages, at which time I contacted Samsung to report the problem - No matter how I tried to explain the situation to them (over several days of correspondance) the only response I could get from them was "the bin must be full - change it".The new bin lasted for perhaps 100 pages, at which point the dreaded "replace waste toner bin" message appeared. Samsumg responded that I should clean the external sensor (I had advised them that I had tried cleaning the external sensor in my first contact with them).
TO DATE - SAMSUNG HAS REFUSED TO ACKNOWLEGE THAT THERE IS A PROBLEM IN THE DESIGN OF THE WASTE TONER SYSTEM.
To confirm my theory that toner entering the bin via the inlet was dirtying the sensor area, I added a baffle made from tape as shown on the left - This cured the problem - Note how dirty the tape has become! (It WAS clear tape)... a LOT of toner was passing through this area!
Worried that the hot toner might melt/burn the tape baffle, I have since replaced it with one made from aluminum foil - Using only a single layer, with a fairly thin part that passes through the hole and is taped in place on the outside. It is important to get the part passing through the hole to be as flat against the side as possible, as it has to fit in beside the inlet from the printer - too much thickness or wrinkles here could cause a messey leak. It is also important that the baffle NOT be so long that it would prevent the sensor notch from filling from the bottom - this could cause the printer to overflow the bin - which would not be good... I recommend that you check the waste toner bin every time you change a toner cartridge.
This link will be useful.check out the link....
https://www.office.xerox.com/partners/products/Phaser6100/Phaser6100Series.html
Don't forget to rate the solution
Good luck
Mar 11, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP 300 Laser Printer Logo
209 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
