Question about Fujitsu LifeBook A6020/C Notebook
Error 00410001 on fujitsu FMVFB70T - Fujitsu LifeBook A6020/C Notebook
How to fix FUJITSU fi 5900C e18 error code Fujitsu fi-5900C Pass-Through Scanner
you need the detail code to e18 to determine the exact error.
First generate the error code again , then hold down the document thickness keys together.
The display should change to a two digit numeric .
You need this code.
Jun 15, 2015 | Fujitsu fi-5900C Pass-Through Scanner
Fujitsu 6130 background switching mechanism error
Hi how do you fix Fujitsu 6130 F4 error? Thanks
Mar 20, 2012 | Fujitsu fi-6130 Flatbed Scanner
I have a fujitsu AOTR30LCT, when turned on the green timer light and the red power light blink 3 times. Only the fan works and does not cool.
Error c0de-3.Return air thermistor short circuit.
This sensor when it's defective, will not command for compressor for working.
Replace it.(Room air sensor). Helpful?
Jan 24, 2011 | Fujitsu Heating & Cooling
When I ran the test on the computer it says error code 00410001 "may be hardware error on HDD"? The computer barely stays on, it shuts off randomly, wont even start up and just has a black screen with a...
Go into the BIOS and reset it to defaults. Then reboot it and see if the message goes away. If it doesn't then try another hard drive in the laptop, if the message doesn't go away at that point then the controller on the motherboard is bad. In that case the motherboard would have to be replaced.
Jun 02, 2010 | Fujitsu LifeBook A6020/C Notebook
Fujitsu error message
From service manual -
Error message condition one = fan protector operated.
Check:-
Fan,
Main Power pcb,
Main digital pcb.
Feb 21, 2009 | Fujitsu (pds42trs) Monitor
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu LifeBook A6020/C Notebook Logo
229 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
