Question about Amana Refrigerators
We are in Australia and have had an Amana XRSS287BW fridge freezer with ice maker for 5 years. The freezer is icing up near the ice maker, the condensor is not icing up. It appears to ice up and the fan hits the ice making a noise? We have had a repairman fix it, he has been back 3 times and now believes the problem is with the ice maker. He has advised we will need a complete new ice maker. I find it difficult to believe that the ice maker cannot be repaired. Regards, Bob Beck
  • 1,998 Answers
They do not repair icemakers for the simple fact it is cheaper to just buy a new unit aka icemaker in fact the icemaker when the repairman buys it costs him between 47-90 dollars at which for him to disconnect the three bolts and reinstall the icemaker the charge usually starting around 189.00 first thing to do would be to look at the tube where the water is going into the icemaker and observe if you have a leak from the tube the next step would be to inspect the icemaker for cracks in the ice making tray if this is also ok has your repairman checked the t-stat this is a small two wire round disc like object located behind the back panel this is what regulates your temptreture and turns the heater on when your freezer gets to cold another thing to check would the drain tube that goes from the bottom tray under the condensor sometimes this also gets blocked with ice.In turn when it does get blocked the ice just builds up the t-stat is located as part number 3 on this diagram from this link http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-XRSS287BW0/1268/0165000/M0610184/00014?blt=06&prst=&shdMod= lastly if your fan is not spinning at the addequate speed that it is supposed to be spinning at then the amount of cold air would not be leaving your freezer to go into your fridgerator and when the heater kicked on the water that melted off the condensor coils would build up also as ice if your repairman is saying its the icemaker visually inspect the icemaker yourself here is a link also showing how to remove your icemaker http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-XRSS287BW0/1268/0165000/M0610184/00008?blt=06&prst=&shdMod= please message me back with your finds after you have visually inspected for yourself. i hope this opinion has helped in your appliance situation please remember to rank how this opinion has helped in your appliance situation and i await your reply
Thanks
Rick
Posted on Nov 09, 2010
Testimonial: "Thank you for the assistance, unfortunately I will not be able to check it for about a week and a half when we are back at the holiday house. Bob Beck"
Why does my ice cube maker quit working and temperature in freezer is the same as fridge.
ice maker will not work if freezer is too warm . it must be 15 deg or lower and if fresh food is that cold then the food is frozen. the freezer needs to be 0 to 5 deg and the fresh food side 38 def is best . / you may be having a defrost problem and the cold coil is packed with ice and prevent ing air flow .. ck for ice in back of freezer .. mm
Oct 22, 2010 | Amana Refrigerators
Ice maker freexes ice together
maybe too much water going in to the ice maker
Jun 30, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer Ice Maker Won't stop filling with water
The water solenoid at the back where the water line attaches to the fridge has failed
Jun 29, 2009 | Refrigerators
Amana fridge ice maker not working
need to check water valve. probally need to replace valve. not letting water through. if valve is ok then ice maker module is bad
Jun 21, 2009 | Amana Refrigerators
No water to ice maker or despencer
Since you said it was "used" you should check the water filter if so equipped. It could be plugged. Also, and obviously, be sure the water to the unit is turned on.
I'd look for a plugged water filter first. Check the manual for the location (usually near the bottom front of the appliance) first.
Try these steps first.
Apr 04, 2009 | Amana SXD524VW Side by Side Refrigerator
Amana Bottom Freezer
either you ice maker is overflowing,(not likely but possible) or you have a clog in your drain behind hte rear cover, not allowing defrost water to drain away in to the pan under refrig instead flowing to bottom of freezer area. rempove the rear cover and thawe all ice, especially near the middle of hte aluminum oan yull find a clogged/frozen drain tube
Nov 10, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
Amana ARB9058CS Bottom Freezer - tremendous frost build-up in freezer on left side near ice maker at top of drawer
  1. I am not expert but this exact same thing happened to me - same model of fridge. The line which brings water in is frozen. I don't know how to solve it permanently, but if you take out the two produce drawers you can see where the water comes through. Put a hair dryer blowing on it for a few minutes and it will get it going again.
Aug 17, 2008 | Amana ARB9058CS Bottom Freezer...
Refrigerators Logo
244 people viewed this question
Top Amana Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
