Question about Epson Stylus NX515 All-In-One InkJet Printer
What is enter key for AES for an epson printer
2 Suggested Answers
  • 1566 Answers
SOURCE: what is enter key for
The AES key is the encryption key for your wireless network connection. I would suggest you to ask the guy who setup your wireless network. He surely knows what the passcode is. If not, you can revert the settings of the wireless router back to factory defaults.
Posted on Jul 14, 2011
Tip
Setting up Epson Stylus SX515w on a PC.
0 false 18 pt 18 pt 0 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin; mso-ansi-language:EN-US;} This guide will show you how to setup the Epson Stylus SX515w, without using the setup CD & USB cable.
1) Using the Control Panel on the printer, press the Spanner/Screw driver button.
2) Scroll though the menu until you see Network Settings & press ok.
3) In the following menu select Wireless LAN Setup.
4) Then select Advanced Setup.
5) Then select manual Setup & press ok.
6) This guide assumes you are connecting through a router via Wi-Fi, in which case you will need to select Infrastructure Mode and then press OK.
7) Select Search SSID & this will search for your wireless network.
8) If your wireless network is showing, make sure it is highlighted then press OK.
9) Now you will need to enter the encryption type, this will depend on the length of the wireless key. WEP 64 Hex (10), WEP 64 Alpha (5), WEP 128 Hex (26), WEP 128 Alpha (13). Any router that has 8 characters I would normally recommend selecting WPA PSK TKIP UNLESS you know that the key is WPA PSK AES.
10) Now you will need to input the security key depending on which type you have, as advised above.
11) Once the key is in correctly you need to press OK. You will then see a Confirm Settings screen. Press OK on this screen and YOU MUST WAIT 30 SECONDS for the printer to establish a wireless connection with the router. After the 30 seconds please go down to Confirm Settings and press OK. This will tell you if it has successfully connected to the router. At this stage you need to make a note of the IP address. This normally starts 192.168.x.x
12) On the PC the printer will need to be installed, I recommend downloading the driver from here:
13) Once installed go to Start > Control Panel> Printers (This will vary slightly depending you version of Windows).
Right click on the printer, select properties (Printer properties for Win 7). Select the ports tab and add a new port.
When adding a new port select Standard TCP/IP, then click add new port.
NB The Standard TCP/IP port is recommended when assigning static IP address to the printer. (See router documentation on assigning static IP address).
If using a dynamic IP Address I would recommend downloading and installing the Epson net printer port. You can use a Standard TCP/IP port, however when the IP address changes communication between the printer and PC will be lost.
Setting up both port types are the same, once you select add port you will need to enter the IP Address, which we noted down previously from the printer. Once entered keep clicking next, then finish.
You should now be able to print over the network. To use the scanner over the network you will need to open Epson scan settings, (a separate utility to Epson scan) this will need to be set to network and contain the same IP address noted down earlier for the printer.
If you still have issues check your firewall and router settings, i.e. mac filtering etc.
on Dec 11, 2009 | Office Equipment & Supplies
End of service for epson wf 7610
If your Epson WorkForce WF-7610 printer shows error message "The Printer's Ink Pads at the end of Their service life" and Epson WorkForce WF-7610 printer has a red light blinking problem: You should be download and reset Epson WorkForce WF-7610 printer Waste Ink Pads Counter with Epson WorkForce WF-7610 Resetter.
Go to this link, you should be able to download the resetter and follow the procedures step by step.
Reset Epson WorkForce WF 7610 End of Service Life Error message Wic Reset...
Jul 22, 2017 | Epson Office Equipment & Supplies
What is enter key for AES mean on printer?? trying to connect to the network with o success.
Jul 14, 2011 | Epson Stylus NX515 All-In-One InkJet...
Printer won't go wireless
You should have received a CD with the installation software. This will guide you through the process of setting it up as a wireless printer. Make sure it is near to the wireless router when you set it up to ensure a good signal.
The wireless function only works via a wireless router, not directly from a PC with wireless capability.
Feb 20, 2011 | Epson Stylus CX4800 All-In-One InkJet...
Installed my SX515 Epson printer and it will not connect with wifi
Oct 19, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Need to know how to install printer cartridge in my Epson Stylus Printer Cartridge 73/73N Have not done this before Can you help
All you need to do is visit the following website and enter your printer model number. Here epson will have a section called Top Frequently Asked Questions - as well there are references to manuals that will give you step by step process. The key is to have the Model number of the printer, not the number on the ink cartridge to find the right documentation.
Epson Printer Support Selection Page
Mar 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I am attempting to secure my network through this router which at this time is open for the whole neighborhood to see
Here are the diffenent types of Security Settings possible with a wireless router: (how to set this depends on the brand of router)
Security Mode: You may choose from Disable, WEP, WPA-Personal, WPA2-Personal, WPA-Enterprise, WPA2-Enterprise, or RADIUS. All devices on your network must use the same security mode in order to communicate.
Capture(wlansec.wpapersharekey) WPA Personal:
Capture(helpwpa.phase8) WPA Algorithm: You may choose from TKIP or AES.
Capture(helpwpa.phase9) WPA Pre-Shared Key: Choose a unique key to authenticate with other devices on your network. The Pre-Shared Key must be between 8 and 63 characters in length.
Capture(helpwpa.phase10) Group Key Renewal: This settings determines how often your group key changes.
Capture(wlansec.wpa2persharekey) WPA2 Personal:
Capture(helpwpa.phase11) WPA2 Algorithm: You may choose from AES or TKIP+AES. Choose TKIP+AES if you have both WPA and WPA2 devices on your network.
Capture(helpwpa.phase12) WPA2 Pre-Shared Key: Choose a unique key to authenticate with other devices on your network. The Pre-Shared Key must be between 8 and 63 characters in length.
Capture(helpwpa.phase13) Group Key Renewal: This settings determines how often your group key changes.
Capture(wlansec.wparadius) WPA Enterprise:
Capture(helpwpa.phase14) WPA Algorithm: You may choose from TKIP or AES.
Capture(helpwpa.phase15) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase16) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase17) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase18) Key Renewal Timeout: Determines how often your keys should be renewed.
Capture(wlansec.wpa2radius) WPA2 Enterprise:
Capture(helpwpa.phase19) WPA2 Algorithm: You may choose from AES or TKIP+AES. Choose TKIP+AES if you have both WPA and WPA2 devices on your network.
Capture(helpwpa.phase20) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase21) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase22) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase23) Key Renewal Timeout: Determines how often your keys should be renewed.
Capture(wlansec.wep) WEP:
Capture(helpwpa.phase24) Default Transmit Key: The key you would like to use for transmitting WEP keys.
Capture(helpwpa.phase25) WEP Key Bit: You may select from 64-Bit or 128-Bit encryption.
Capture(helpwpa.phase26) Passphrase: You may enter a passphrase consisting of any keyboard character to be used to generate a hex WEP key. Passphrase option is only supported when you are only using Linksys devices on your network.
Capture(helpwpa.phase27) Key 1-4: You may enter a WEP key manually. You must use only hex characters (0-9 and A-F). 64-Bit WEP requires 10 hex characters. 128-Bit WEP requires the use of 26 hex characters.
Capture(wlansec.radius) RADIUS:
Capture(helpwpa.phase28) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase29) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase30) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase31) Default Transmit Key: The key you would like to use for transmitting WEP keys.
Capture(helpwpa.phase32) WEP Key Bit: You may select from 64-Bit or 128-Bit encryption.
Capture(helpwpa.phase33) Passphrase: You may enter a passphrase consisting of any keyboard character to be used to generate a hex WEP key. Passphrase option is only supported when you are only using Linksys devices on your network.
Capture(helpwpa.phase34) Key 1-4: You may enter a WEP key manually. You must use only hex characters (0-9 and A-F). 64-Bit WEP requires 10 hex characters. 128-Bit WEP requires the use of 26 hex characters.
Jul 03, 2008 | Computers & Internet
Epson Stylus NX515 All-In-One InkJet Printer Logo
3,246 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
