Question about Panasonic Lumix DMC-FZ20 Digital Camera
Flash not working
I cannot get the flash to work - even when I pop it up manually and go into a dark room it doesn;t flash - and I don't find anywhere to change the settings to Force it on.
Help please!
Thanks
  • msmithako Oct 09, 2008
    I have the same problem with my Lumix DMC-FX500. I bought it several months ago and starting 2 weeks ago the flash just won't work even when I select the forced flash setting.
    Sergeant:
    Champion:
  • 248 Answers
Pop up the flash and you can select flash mode by pressing the arrow like button press right to select the flash mode....
Posted on Aug 05, 2008
SOURCE:
Canon 60d internal flash not popping up
Check the metal tabs inside the notable rails as they need to touch the upper part of the rails to allow built in flash to work
Use a micro screwdriver to push the tabs up to the rail
GENTLY as that was what was wrong with my canon digital body
Jun 21, 2015 | Canon EOS 60D Digital Camera with 18135mm...
My Canon EOS rebel t3i's flash isn't working properly. It will flash, wait a second, then take the picture, making it come out very dark or completely black since the flash happens so early and I'm at
The multiple flashes are the camera attempting to autofocus on a subject that is too dark - it is trying to compensate for underexposure. Are you taking photos outside at night? Another thing to check is your lens. It is possible you have a poor connection between your lens and the camera which may be interfering with the focus and exposure (aperture) setting by the camera. Take and alcohol pad and wipe the contacts on both the lens and the camera body and dry them thoroughly with a lint free cloth. I have seen the oils from finger prints cause problems with contacts like this, so make sure they are clean and if you are in doubt, clean them twice. You should try to pop the flash open and not use the simple exposure settings on the mode wheel. If you are using the "easy" mode - stop. Use the portrait or night exposure setting. The other possibility is the processor in the camera is bad. If you have eliminated all the possible things then the camera is the culprit. I hope you have a warranty if that is the case.
May 10, 2017 | Cameras
The flash on my Panasonic DMC-FZ100 doesn't work, I've tried 'forced flash' and thats not working either?
Hello Ray, This is not something a user wants to attempt !!! The camera really needs to be repaired by a tech. You will do more harm than good by trying to fix it yourself and will cost even more if you damage something.
Best Regards, Russell
Jan 22, 2013 | Panasonic Lumix DMC-FZ100 Digital Camera
GE 27998GE6-C cordless phone with answering machine handset doesn't work
I can be of help please email me [email protected]
An upgrade can be offered, with lower call rates.
Jun 13, 2017 | Lands Phones
Flash will go off even if i have it turned off
select manual icon of the dial,then flash will not give u trouble.if u use auto,program,etc auto system makes flash pop up.
Mar 25, 2010 | Olympus EVOLT E-500 Digital Camera
Same as posted - picture is way too dark when using flash. Help!
Try a camera reset. Go into the setup menu and scroll to "reset" and follow the on-screen instructions.
Sep 23, 2009 | Canon PowerShot A630 Digital Camera
Have a nikon d60 and the flash will not go off even when in a dark situation. Pops up but no flash?
if it pops up then the sensor is working and the mechanical parts are working,
Next is manual force flash test, if is manually flashes, the bulb is good else replace the bulb.
Sep 05, 2009 | Nikon D60 Digital Camera with 18-55mm lens
When do i use the flash pop up and when not. I was told that the camera would ask for this.Will it automatically go off in intel.auto or do i have to open the pop up. Do i leave this open and will it only...
It should work when you need it. Go in a dark room and try it. If it does not work then, you need to pop it out. Whenin doubt, use flash. It almost never hurts :>)
Jul 05, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Keep getting err 05 stating that the flash is obstructed
does the flash pop up?
Try this in a dark room with the setting on automatic.
If it does NOT pop up, the problem is that the flash is stuck in some way. Try gently prying it up if you can. if not, take it into a camera repair shop to get it fixed.
Nov 18, 2008 | Canon EOS 40D Digital Camera
Panasonic Lumix DMC-FZ20 Digital Camera Logo
891 people viewed this question
Top Panasonic Cameras Experts
Ekse
skyblue007
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
