Question about Nokia 3110 Cellular Phone
It doesnt turn on. it starts and then auto restart about 3 times and then shuts down.
Posted on Nov 09, 2010
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
Our requaired is without any in puts(remote start and Manula Start) AC staret after power restart,please gaide to me.
first you need to check if your A/C has Auto Restart function. How?- turn power On from the circuit breaker, if the A/C unit start working at your last-time program you have the Auto Restart function. In that case you never shut it down by the cutting off the current, forever turn it on/off by the remote controller.
Feb 23, 2011 | LG Heating & Cooling
I had a problem start with error code E000-0120. I easily found this was an overheating problem. The room where the printer was located had gotten very hot, so I shut the printer off and left it until...
these means that thermistor still reports the temperature problem or that copier was memorised the error code and keep reporting it. Auto shut off is sign of fixing trouble.
To be sure if the thermistor or lamp is faulty, first try under service mode to clear the error.
If that doesnt help you you need to call service to locate problem in fixing section.
Procedure to clear error:
Clearing E000
1) Start service mode, and select 'FUSER' under 'FUNC'.
2) Press 'E000RLS'.
3) Turn off and then on the power switch.
SERVICE MODE:
1) Press the "*" key on the control panel.
2) Press "2" and "8" on the keypad at the same time.
3) Press the "*" key.
Hope that helps!
Aug 10, 2010 | Canon CLC 4000 Copier
My HP web cam not working, there is no imaging device in "Device manager"
this can be a right pain some times the cam does not load up when you start the computer up only thing you can do is to shut it down and start up again do not restart though it must be shut down If that doesnt work and it doesnt always work you might want to consider getting a usb cam that u can simply plug in
Jul 28, 2010 | HP Computers & Internet
Favorites keeps getting wiped out
your prety much just fucked on that bro every time it doesnt shut down properly you get an error or the batery goes causeing it not to shut down properly it wippes all settings favorites equalzer shuffle mode everything just dont buy rcas they allso have a tendancy to crash permenetly the procesers burn out easely and have the worst tech support EVER
May 19, 2009 | RCA M4204 MP3 Player
My powermac g4 startup problem - grey screen and folder+blinking
when booting immediately after the first chime before the grey screen hold down keys (apple,option,p,r) allow the computer to restart if it still goes to that blank screen restart again and this time hold down only the (option) key or maybe (option,s) on that model try option key first then select the main start up disk from the menu and click the arrow underneath
Apr 21, 2009 | Apple Computers & Internet
Auto restarting,
I think a general cleaning including the contact points of the RAM and checking that all wires are snug tight including all jumpers are properly seated. If required clean the PC power switch with a spray of alcohol/spirit. After all these I hope your problem disappears.................sodeep
Apr 17, 2009 | MSI /865PE NEO2 PLATINUM ED. Motherboard
Power issue
plz check if there is any disc in the drive?
if not this time the system restart keep tapping on f 8
and go to safe mode type msconfig in run clk ok
new win will *** up go to startup tab down at bottom disable all
apply ok restart teh computer clk on the chk box dont show this mesg again once the computer will boot let me know if teh thing doesnt work
May 22, 2008 | Compaq Presario 700 470024-192 Notebook
Assasin's Creed
Try holding down the power button. if that doesnt work unplug it for a minute and try again. if that doesnt work either its probably the game.
Feb 12, 2008 | Sony Playstation 3 (PS3) Console
Nokia 3110 Cellular Phone Logo
96 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
