Question about Whirlpool Washing Machines
Model STA PL5 MACHINE not working .Local service center personnelp says electronic circut board required to replace.Let us know tentative cost and place from where I can purchase. Or your service engineer can check the machine. give your contact number Y S Rawat
  • 1,998 Answers
If you would like to buy the circuit board from where the technicians buy there parts from goto marconeappliance or allbrandsappliance they also have a 1800 number on both those sites that you can call and get a price on the circuit board and they will mail you the part directly. I hope this helps please remember to rank how this opinion has helped in your appliance situation. And if you have any further questions please message me back.Thanks again
Rick
Posted on Nov 09, 2010
Servicing and cleaning my sewing machine
Hello Hazel
The Memory Craft 9000 is a computerized sewing machine. In removing the casing precautions must be taken to prevent damage to the electronic boards which are costly to replace. As a result it is recommended by the manufacturer (Janome) that this work be performed only by qualified technicians with the required equipment to prevent any damage.
What is the reason for requiring the casing to be removed?
Feb 16, 2015 | Janome Memory Craft 9000 Computerized...
My Toshiba 65HX83 was hit with a surge from the power company and the repair man at the local shop said that there is no available parts for repair. Is this correct or is there hope for a little more life...
This is not 100% correct. There are parts available. I do not believe that the "power board" is available anymore. As a matter of fact, I don't believe that there is a specific power board. These units have a main board with signal, tuner and other boards attached to it. This unit will require component level repair. Saying that, the cost will not be small. These take time to repair. Also, power surges are perhaps the most difficult to repair. There are often parts that appear to work at repair time only to fail shortly thereafter. Many shops will declare this type of damage beyond repair because of this.
At this point, take the insurance coverage for the set and apply it to a replacement. You will be happier in the long run.
Dan
Mar 30, 2011 | Toshiba 65HX83 65" Rear Projection...
Is there any service center of INDESIT in kerala my washing machine is not working now and local repair centers are telling a huge amount.
Please confirm the details of the estimation , the details of the parts required before the cost can be justified.
Now if there is failure of high cost spares I would advice you not to proceed further as you can obtain a scrap value for the washer with which a new one can be purchased with added warranty unless the repairs are guaranteed.
Your feedback please.
Jan 20, 2011 | Indesit Washing Machines
Pansonic TH-42pz700u television stopped working. Just falshes seven times, stops then repeats. Cant acess menu or any functions from the tv or remote
the blinks indicate what part is fualty if your trying to fix this set your self use a serivce manual for blink codes, count the blinks and you will know what board is fualty. usually it is a safety feature with panasonic this happens when a circut if fualty and the board affected is bad. i have the same set i had a similar issue i replaced the affected board and it works excellent now.. find a service manual site it should be available for download, may cost you a few buck but youll be sure what to replace..for parts you can search auction sites and electronic parts sites i would recomend a auction site they sell for a lower price than electronic parts supply site..hope this helps
Mar 07, 2010 | Panasonic TH-42PZ700U 42 in. Plasma...
Rapidly blinking green sleep timer light, cannot reset tv. Will not turn on.
The Chassis will need to be sent to Mitsubishi to be refurbished. I would call Mitsubishi at 1800-332-2119 to see if they would help in the repair cost and also to refer a Service Facility local to you to do the work. I would estimate the cost of about 300.00 to 400.00 if Mitsubishi helps with the cost. If they don't, I would estimate the cost to be around 700.00 to 800.00.
I hope this helps,
skyassoc
Aug 25, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Whirlpoop AWM9000-WM1100 Displays fault code 11F? any ideas greatfull
F11 on a Whirlpool AWM9000:
Service manual says "Communication error between Control board and Motor control unit (MCU)".
-Check control board
-Check MCU
-Check wiring to MCU
Basically, there are two electronic boards in this machine- the one up the top that you use to operate the machine (control board), and a power board in the base of machine (MCU). F11 fault is indicated a communication error between these boards ie one of the boards may be faulty, or wiring connection between them may be faulty.
It is impossible to know which electronic board may be at fault, as there is no way of testing them. Would advise calling service technician, but would advise you use an actual Whirlpool technician rather than a local service man, as Whirlpool tech has access to technical info required to solve your problem.
Good luck !!(be wary- might pay to ask for an estimate of what repair might cost when booking service call, as some of the control boards can be expensive)
Aug 11, 2009 | Whirlpool WFW9200S Front Load Washer
Haier hdn305 dehumidifier does not turn on
Had the same problem with two HDN455's and took them to a local electronics repair shop. They replaced a Zener ZD2 diode for a total cost of $53 and now is working fine.
Jun 03, 2009 | Haier HDN455 Dehumidifier
Electrolux EW 1005f washing machine trouble.
http://jaipur.justdial.com/washing-machine-part-electrolux_Jaipur.html
click this link for eltrolux parts in jaipur
http://delhi.justdial.com/washing-machine-part-electrolux_Delhi.html
click this link for parts in delhi
http://machines.exportersindia.com/cleaning-equipment/washing-machine-parts.htm
click for all other leading part suppliers
http://govindenterprises.tradeindia.com/
click the link
GOVIND ENTERPRISES RZA/337, Nihal Vihar, Near Guru Harkrishna Nagar, Delhi - 110041, India
Phone:91-11-25943604
floating-close.gifContact Now
floating-sendmail.gifSend E-mail floating-callmefree.gif Call Me Free
Key Personnel Mr. Bhupender Singh (Proprietor)
Mobile:+919212646376
Mar 26, 2009 | Electrolux Washing Machines
Capacitor and Power board
follow the power cord to the board. that is the main power board. the capacitors are near the top center (aprox 3/16" diamiter and 5/8" long ) three of them. replace all three . firemarshel@yahoo
Dec 25, 2008 | Hisense TL-3220 Television
Flashing red light 7 times on our panasonic th-42pz700u
hello you have what you call a "shut down circut" it is for safety and when one of the internal boards gets shorted or is not working properly, service doc reads as follows
7 Blinks SOS:
Pin 93 of the MPU IC9003 monitors the status of the SC, SU, SD board. During normal operation, the photo-coupler PC6480 outputs a low to pin 93. If the SC, SU, or SD board becomes defective, a high is provided to pin 93. As a result, the unit shuts down and the power LED blinks 7 times
thiera blinking 7 times is cuase by a fualt in sc,su,sd boards
10th generation plasma service manual info
Dec 08, 2008 | Panasonic TH-42PZ700U 42 in. Plasma...
Washing Machines Logo
165 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
