Question about Canon imageRUNNER 8500 Copier
My ir6020 having the problem e602 001 then i change the hard disk ,after that come out the error e602 003
SOURCE: E602
Turn on holding down 1 and 9 keys. will go through a long complete format. If blocks do not fall down through screen left to right, HDD is completely gone.
Posted on Jan 04, 2007
SOURCE: E602 0001 - ir8500 Canon
she need a new system software or a new hard disk with a new software
Posted on Nov 23, 2007
SOURCE: PLEASE HELP ERROR CODE
E602-003this code means Canon’s hard disksystem have some problemsthe only solve way is change the hard diskThe hard sisk form our company just need connect to the printer then can usewithout any unconventionalitytill now our hard disk we selt to everywhere in China not found any trouble . if client’s machine already have print function,only need add our company’s print system then can get back the print function.(this print system need add RMB100)。If client’s machine don’t have print function,only need prepear the ROM card and network card from our company then can have the print function.(the ROM card and network card need add RMB600)
Our major disk:IR 2200IIR 2800IIR 3300IIR 3320IIR 5000IIR 6000IIR 8500I kprice as following
IR 5000I hard disk+system 500 +100 +600
IR 6000I hard disk+system 600 +100 +600
IR 8500I hard disk+system 850 +100 +600
*Period of validityall the year*
ADD:
201, West block, Shang bu commecial building , Hua Qiang south road, Fu Tian district, Shenzhen China.
Tel:0755-81677725 Mr.Lin
QQ: 870530595
Posted on Aug 19, 2008
SOURCE: I am babykaruna from india. i have ir3300 copier
hi karuna,what you can do is....press * 2 8 *,copier,function,system and HDD clear,ok......ann wait untill the process drop to 0% and switch off your machine,after 5 second on it back,thanks
Posted on Jul 30, 2010
canontech
  • 1219 Answers
SOURCE: my problem is the error
yes you can change the hdd, but you need service support tool because you need to upload system, language, rui,...
So... call service.
Posted on Aug 14, 2010
Canon IR3300 Hard Disk Error e602 - 003
You need to have 20GB hard disk (IDE) and update the firmware thru parallel cable via SSST
Jan 10, 2014 | Canon Office Equipment & Supplies
Tip
Xerox machine ir 3320, error 602-003 and 602-004\r\n
The E 602- 003 is due to hard disk system error but you can scan it ;run check disk its can fix that problem. try this, hold on 1 and 9 (from the machine key board) then switch on the copier; then wait around 1 hour all screen will be white then the copier will display download mode. then switch off and put on the copier.
on Nov 02, 2010 | Office Equipment & Supplies
I need a list of erro codes and definations for xerox workcentre 7232 serie. and I want the solution to my xerox workcentre 7232 copier. when switched on it shows erro 093-311
When a fault occurs, the touch screen displays a message on how to clear the fault. Some faults indicate customer maintenance, while others require the attention of the Key Operator and/or System Administrator. The following table represents some of the fault codes and their corresponding corrective actions. These may appear in the Print Queue or Faults List available in the Machine Status mode.
002-770 The job template could not be processed due to insufficient hard disk space. Delete unnecessary data from the hard disk.
003-750 No document was saved for the double-sided Booklet Creation feature. Check the setting of the double-sided Booklet Creation feature.
003-751 The specified document area is too small. Select a higher resolution or a larger scan area.
003-754
003-755 An error occurred in the document scanner. Reset the document, and scan again.
003-756 The fax document is completely white. Check that the original is not white, or that the front and back sides have been reversed.
003-760 Incompatible features are selected in the document scan conditions. Check the selected options.
003-761 The paper size in the tray selected by auto tray switching, differs from the paper size in the tray selected at the tray selection. Either change the paper size for the tray, or change the paper type priority setting.
003-763 An error occurred when reading the Gradation Adjustment Chart. Place the chart properly on the document glass.
003-780 Compression of scanned data was unsuccessful. Lower the resolution or reduction/enlargement ratio to reduce the data size, or send the document in
smaller segments.
003-795 The reduction/enlargement ratio exceeds the setting range when the scanned document is enlarged/reduced to the specified paper size. Directly enter the reduction/enlargement ratio, or change the paper size.
003-981 Stapling mixed size documents is available only for documents with the same width. Cancel the staple feature or reset the documents with the same width.
005-210
005-275
005-280
005-283
005-284
005-285
005-286 An error occurred in the document feeder. Contact the Xerox Welcome Center.
Jan 16, 2011 | Xerox Office Equipment & Supplies
I have a xerox machine ir 3320 i have facing a error 602-003 and 602-004\r\n and printing are coming zigzag type
try this,
then wait arround 1 hour all sceer will be white then the copier will display download mode.
Oct 31, 2010 | Canon Office Equipment & Supplies
E000602-003
This error is related to the hard disk. do hard disk check or replace the hard disk
Aug 26, 2010 | Office Equipment & Supplies
Ir3100 : E00070-003 error code
canon ir 3100 error code E00070-003
Oct 23, 2009 | Canon imageRUNNER C3200 Copier
Need a hard disk recovery software for canon ir3300
hi i am form India i have canon ir 3300 i am getting error for E602-003 pls no technician
Jul 08, 2009 | Canon Office Equipment & Supplies
Error Code description
The Canon is coming on with a code E602-0003 can somebody please help it is only 9 months old and the company we bought it from is out of bussiness. Please email me @ reception@biscayneroofing.com
Thanks
Madlyn
Feb 25, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon imageRUNNER 8500 Copier Logo
134 people viewed this question
Clive
Clive
old marine
old marine
