Question about Conair Weight Watchers Glass Digital Body Fat Analysis Scale - 1 ea
My scale keeps fluctuating between 4 or 5 pounds each time I use it. In the past, it's always been soooo accurate. Suggestions?
2 Suggested Answers
ptooshar
  • 19 Answers
SOURCE: scale appears to be inaccurate
this type of less resoluted scale hasn't repeatability. if you wish to repair it, change the loadcell. use 2 x scale capacity of load cell.
Posted on Dec 02, 2008
I have a Penn Scale CM 101. On the net weight it registers -1.23. WE can not get it to zero out. Any suggestions?
1 Have the scale turned off
2 Turn it back on
3 While it’s counting down press the Tare button
4. Asks for passcode enter 0000
5 Keep pressing Tare until it says Load 30 pounds
6 load the thirty pounds
7 turn scale off
8 remove 30 lbs
9 turn back on
I hope this works for you as well
Sep 16, 2017 | The Health & Beauty
Why does my temperature gauge keep going up and down
An accurate temperature gauge will always fluctuate because the temperature in the engine fluctuates.
Usually the only time this is really noticeable is when the engine has been working hard and suddenly has to wait at a junction or similar and the gauge can rise considerably.
You didn't mention by how much the gauge fluctuates?
As long as it remains approximately in the normal zone it is acceptable but if it climbs into the hot zone or falls into the cold zone it is not acceptable and the cause should be investigated as soon as possible.
May 02, 2016 | 2008 Peugeot 308 1.6
Vivitar scale accuracy
Why do you think it should be off?
Did you put on a known weight? Personal scales, come with a certain tolerance the is much more then the digits suggest. Most of the time the tolerance is printed in the manual. even 1% is a least 2 pounds plus or minus for a full grown person.
There is one plus in this, the deviation, is most of the time the same over a long time. So don't look to the absolute figures, unless poi did calibrate, just see if you are making progress over time.
Feb 14, 2014 | Vivitar Cameras
Have had the BS 365 scale for 6 years and love it. However, it has stopped giving accurate data and instead registers different weights that fluctuate and are much lower than accurate. Would love to...
Not sure if you knew this but you can change the batteries. I had the same problem and had forgotten to change the batteries. However, the weights may still fluctuate because you need to reprogram the settings. Unfortunately, i do not remember ever having an instruction manual...
Jan 16, 2011 | Rowenta BS 350 Ultra Slim Bathroom Scale...
My scale keeps giving me an err2 message. How do
1. Take out the battery
2. Put scale on hard surface
3. Stand on scale for five seconds
4. Put battery back in
5. Tap your foot on scale to make 00000 appear
6. When the 00000 disappear tap your foot on scale again and then stand on scale till your weight appears
If this does not work the first time (it has always worked the first time with my scale) the repeat the steps a second time. If the second time does not work call the company because something else is wrong.
Dec 16, 2009 | Taylor Body Fat Analyzer & Scale, Model...
Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Mar 13, 2009 | Tanita 2204 Body Fat Scale
Scale appears to be inaccurate
Nov 26, 2008 | Conair Weight Watchers WW-87 Body Fat...
Scale not accurate
This link allows you to trouble shoot directly with the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
Nov 10, 2008 | Taylor 7321 400 Pound Lithium Scale
Conair Weight Watchers Glass Digital Body Fat Analysis Scale - 1 ea Logo
48 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Steve Allison
Steve Allison
gbob59
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
