Question about Haier Heating & Cooling
A/C Cooling is not happening - Haier Heating & Cooling
  • 478 Answers
I'll need more than that. Is it runing at all?, blowing air? or Nothing! If Nothing check for power to unit.
Posted on Nov 09, 2010
My dodge intrepid over heatz when my heat dont work every few dayz
Hi David, I'm glad to help. 3 Things could be happening here. (1) There could be air trapped in the cooling system somewhere, which you can remove with thye bleeder screw near the thermostat housing. Try this first. (2) The cooling fans may be trying to go out for the radiator. The next time the problem occurs raise the hood and see if the cooling fans are working, if not replace the cooling fan module from the dealer. (3) Blown Head Gasket. This is not very likely because you say it happens ever few days and if it were a head gasket then it would happen after running a few minutes everytime. Hope this helps and have an awesome day David.
Apr 26, 2014 | 2004 Dodge Intrepid
I have 3 Fujitsu heat / cooling multi split ductless units connected to one rooftop unit. Only in heating mode and only coming from the same indoor unit is a loud almost screeching/vibration sound. It can...
If it happens in heat it must happen in cooling. The indoor unit has nothing to do with if it's heating or cooling. You likely have 2 moving parts in the machine, the blower wheel and the swing fins. Turn swing option off, eliminate that. You get the rest...
Jun 04, 2017 | GE Zoneline AZ38H12DAD Split System Air...
When we turn on our heater on the temp is fine but when we turn the heater off the van overheats.
You may have an engine cooling fan that isn't working. When you run the heater you are removing some heat from the cooling system which aids in keeping the engine cool. If the cooling fan in front of the radiator isn't working then the engine can overheat at slower speeds when there isn't any air being forced through the radiator by the forward motion of the vehicle. If this problem is happening only at slow speeds then I would suspect a cooling fan BUT if it happens at steady speeds over 35 mph you may have a different problem.Hope this helps and good luck!
Mar 07, 2011 | 1999 Dodge Caravan
Cooling fans will not come on my 1997 olds aorura
This could be a lot of things,check the fuse for the cooling fans,then check the coolant level,and if there is air in the cooling system this will happen,and of course the coolant sensor could be at fault,and the cooling fan relay.
Jun 05, 2010 | 1997 Oldsmobile Aurora
Won't Stop Cooling
thermostat is stuck. try buying a water cooler control from a local supply house.
Apr 24, 2008 | Hamilton Beach Water Cooler with Storage...
Heating & Cooling Logo
44 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
