Question about Tomtom GO 910 GPS Receiver
Help How can I test the battery?
    Guru:
  • 1,894 Answers
Sir remove the battery and test it with a voltmeter
Posted on Jun 16, 2008
  • dewan nafees ahmed Jun 16, 2008
    dont forget to accept the solution in the premium advice if u go by my advice sir
I have a strikers st#1blue scooter brand new it won't drive at all and the lights only come on when the charger is connected then the red orange and green lights are all on can anyone help?
Sounds like a defective battery. If you have a volt meter you need to measure the battery voltage, if you don't, you need to have the battery tested. AutoZone and Advance auto parts will test a battery and charge a battery free of charge, but you would have to remove battery or load scooter and take to have the battery tested.
Sep 20, 2015 | Health & Beauty
Starter location
Its in engine compartment under hood.
On the lower side.
First test the starter before directly replacing it.
It can be faulty starter or there is loose connection from battery to starter. The starter assembly gets power from battery. Check voltages at starter wires and see if you are getting 12 volts or not. If not then its no power issue due to low battery volt or no connection between battery to starter.
To solve these problem, I suggest you to refer these direct help links:-----
Click the link below: ------
How to test starter solenoid?
http://schematicsdiagram.blogspot.com/2011/06/how-to-test-starter-solenoid.html
How to test cars starter?
http://schematicsdiagram.blogspot.com/2011/06/how-to-test-cars-starter.html
How to replace starter in car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-starter-in-car.html
These will help.
Thanks.
Dec 10, 2012 | 1998 Chevrolet Blazer
My KIA Spectra 2004 battery charging system problem I need step by step help thank U.
The first step is to check all of the battery cables and their connections. Insure that they are CLEAN and TIGHT (visual and physical inspection should ALWAYS be FIRST).
When you are satisfied that there are no problems with corrosion or loose connections, then you must use a battery load tester to load test the battery. On modern batteries, It is also recommended that you use a battery analyzer that can test the battery impednce. Sometimes a battery will show High impedence - even if it can pass a "load" test. Replace the battery if tests indicate it is necessary.
Please note that the rest of the charging system cannot be properly tested until the battery and the cables are all in good working condition.
Any attempts to check the alternator and its circuits with bad cables or battery are going to be, at the very best, inaccurate
Once the battery connections and battery are in good working order, then the alternator output must be tested. It should be tested for voltage output both at idle and at high RPM with a load applied. It should be tested for maximum amperage output to see if it coinsides with the alternator's amperage rating. It should also be tested for AC current or "ripple", indicating shorted diodes.
If the alternator fails any of the tests, then either the alternator should be replaced or the alternator control and output circuits must be diagnosed and repaired (it depends on WHICH test or tests it fails).
Apr 21, 2012 | 2004 Kia Spectra
I have the same problem.... i got a new battery but still with the same problem, only start with a jump cables. There's something on the car that's eating the batttery .. alternator that's what i think too...
there is a way to do a draw test on battery electrical system. heres how. with car off, remove negative battery cable from battery. hook a test light to cable end then other end to battery. after this, hold cable clamp on negative p[ost of battery without breaking test light connection. hold it there for 2 minutes. then remove clamp from battery. do no break test light connection yet. if there is a draw then test light will light up. but before doing this you have to have a charged battery. just jump start and let run for a few minutes. have a good day !!
Feb 05, 2011 | 2006 Mitsubishi Eclipse
I have a Toyota previa 97, and the battery drains completly overnight. I need a wiring diagram, help. if a connect connector 1 or 4 the battery drains, but if i connect connector 2 or 3 it does not drain....
Ok you have to do the next test with a test light disconnect the positive battery cable connects the jaws of the test light on the battery cable and the tip of the test light to battery positive light should turn off the fuse and fuse when the light turns off the circuit that is where you cut that way if I can help to saver exactly where the problem lies. Thanks
Mar 24, 2010 | 1997 Toyota Previa
Nicad battery for makita want charge
For NiCd and NiMH batteries - check the battery voltage (for a good battery it is ~ 19, V); each battery contains 15 units 1.2 V each; you can test each unit after disassembling the battery case (my have 4 screws each, and the case has bottom and top parts). First charge the batteries; second, disassemble cases and check each unit voltage (shouldn't be less than 1.2 V); then take any battery tester (for AA, AAA and other batteries and accus for home usage), attach 2 long (~10 inches) wires to tester's testing contacts, and test each 1.2V unit for current - if it is in "yellow" or "red" zone - the unit is dead and needs replacement
Feb 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
My car wouldn't, but when help from other car
you have a bad battery or alternator take it to auto zone for a battery test and alt test or even could of broken the belt for alternator, it's free to test and they can tell you whats wrong at no charge and can give you a price for what you need.
Jan 27, 2010 | 1996 Chevrolet Cavalier
Battery charger not working
make and model would help, general help do you have voltage tester? if so look at charger and find voltage output, test contacts and if lower than listed charger has gone bad, also clean all contacts with pencil eraser to make sure they are clean on battery and gun, if charger is good and contacts clean either battery is bad test in another device or test voltage, if battery good the drill is bad
Jul 08, 2009 | Drills
Tomtom GO 910 GPS Receiver Logo
20 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
