Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Gas range control pannel
My hotpoint gas range control pannel doesnt light up at all. i checked the cercute bracker and it looks fine,not triped..could it be a fuse? i need a diagram of the control board, for my oven ,clock,cleaner,and broiler.
  • 5 more comments
  • lori25 Jun 16, 2008
    does this happen alot? when i push the clock it does nothing. its just blank. if i have to change it my husband will try if he has some one to tell him how. thank you,can you show us how please? ge wants 99.99 to just come look at it. thank you!
    my range is a hotpoint.gas range model #rgb745weh9ww
  • lori25 Jun 17, 2008
    OK Sorry....
    I didnt mean anything agenst your experience.I am new to parts and appliance names saying on thing and meaning another. i do want your help and i will pay the 9.99 for you to help me.I thought i was to rate your request. i cant push a button if there is nothing lite up to push,sorry. can you help?
  • lori25 Jun 20, 2008
    no body? i really need help...
  • robert samples May 11, 2010
    some times if you push clock on some models they will light up and i think what she is trying to say i fixall is she rated you by acci dent now do the surface units light when you turn it on we are trying to determine if its a power promblem can your husband use a volt ohm meter and ifixit all if you post as a clairfication request you cant be rated till you post a soultion and mamn will you post your model number off the serial plate on the oven pull the bottom drawer out and see if its there
    try pushing clock let me know what happens
  • 868 Answers
You have a Bad Clock.In some cases its called Control Electric, no matter how they name it is the Clock and its price can vary also.It's not hard to change if you do the job your self. And i'll be here to show you how if you need me to.
Posted on Jun 16, 2008
  • Archie Ferrarini
    Archie Ferrarini Jun 17, 2008
    GE Profile Spectra JGBP90..... .
    I have 26 years experience in Appliance Service ,I must not of sounded convincing enough to rate me before you state the solution.I'm here to help, and, I don't guess.
I got a single phase capacitor motor is is 22-11 amps it keeps triping my bracker one to two min of running now my bracker is fifteen amp do i need to get a higher amp bracker?
You need to determine the following: what else is on that circuit? You might have a 15 am circuit but you need to calculate what else is running. Please clarify... is it 22 amps at 120 volt and 11 amps at 220 volt? The motor will draw more amps when starting and reduce while it is running. Do not just toss in a larger breaker, that cold potentially lead to a fire or damage to your equipment.
Aug 25, 2011 | HP Color LaserJet 2600n Printer
I have a rangemaster 110 and yesterday a gas engineer came out to my boiler . He may have switched the gas off, im not sure. However, today neither of my ovens will come on and my clock has gone out too??...
make sure you dont have a circuit breaker triped in your electric pannel if the power went out it seems to be the culprit and does the range come on at all because the ingnition on it should be an electric ingnition as well hope this helps
Jun 11, 2011 | Rangemaster 110 (Gas) Kitchen Range
The panel wont light up, it stopped working in the middle of cooking
There are several possibilities here, could be thermal fuse, failed transformer, failed control board. If you post the full model number we may be able to look up the wiring diagram and see which looks most likely. The thermal fuse is a relatively inexpensive repair. If it turns out to be the transformer or control board we repair these at which can save you some dollars.
Best Regards,
Jun 21, 2010 | Hotpoint 30" Self-Cleaning Freestanding...
I have an gas stove Hotpoint model RGB524PEA2WH and Im trying to use my oven but doesnt work.I can see the ignator working, but the gas does not come out. I check the parts and seems to be fine. What can I...
What do you mean "checked the parts?" If you are not a qualified tech DO NOT TOUCH ANYTHING! Check to see if there is a separate knob by the thermostat that turns on the gas.
Dec 28, 2009 | Hotpoint RGB745 Gas Kitchen Range
Ac control pannel doesnt work and hot air only come out vents
You might want to check and see if you can find any inline fuses going directly to the control panel. I had the same problem on a different car. Just in case.....there should be fuses under dash and under hood. Maybe a relay is even out.
Sep 18, 2009 | 2003 BMW 325
Replacing Igniter on Hotpoint RGB528PEAWW Gas Kitchen Range
you should have a broil glow coil at tol and one on bottom. to access the bottom, open the door and look to the back on the oven floor. ther should be a srew one on each side remove and lift bottom up. you should be looking at the glow coil. i would also remove the pan drawer for would be abnormal for bth the broil and bake to fail at the same time. if this is the case i would confirm power is leaving control to the selected glow bar. they shoul pull about 3.2 amps. then i would focus on the valve. which is opened by the amp draw of the bar. one wire on the valve is common and the other feeds from the control through the valve to the glow bar
May 18, 2009 | Hotpoint RGB528PEAWW Gas Kitchen Range
Hotpoint Gas oven doesn't light
Is the gas valve easy to replace on a gas oven?
Nov 14, 2008 | Hotpoint RGB745 Gas Kitchen Range
HOtpoint Electric stove/oven
You have not responded to my clarification request, so I'm guessing that you have resolved this issue. If not, let me know if I can still be of assistance.
Aug 26, 2008 | Hotpoint RGB745 Gas Kitchen Range
Sounds like the oven ignitor is weak.  If everything else is working it must be a bad ignitor.  These are usually easy to replace and can expect to pay $70-$100 for the part.  Check to see if it glows when in bake mode first.  If it does then replace the ignitor.  You can look at the ignitor,  when not on, if it is white-ish then it needs replace or if it doesn't have a full glow, can compare to broil ignitor, then it needs replaced.  Let me know if you have further questions.
Oct 12, 2007 | Hotpoint RGB790SEHSA Gas Kitchen Range
Samsung RGSF5330DT Range dead.
try checking control panel connections they might be dirty if not then board is proberly bad
Aug 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
74 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
