Question about DigiWeigh 100 X 0.01 Gram Digital Jewelry Pocket Scale
My scale is frozen displaying f--h how do I fix this? I tried holding mode and tare and turning it onon and that doesn't work any other suggestions?
  • 7,733 Answers
Reset it!
Turn off the scale. Press and hold the MODE button and turn the scale on. Release the MODE button you will see the scale's internal count.
Press and hold the TARE button then press (don't hold) the MODE button you will see the full capacity is changing. Keep pressing the MODE while holding the TARE button until you see 100.00 on the screen. The reset is completed. You may need to recalibrate the scale after the reset.
Posted on Nov 12, 2010
I bought a pierre cardin digital kitchen scale YHC1407C online including battery.is the battery inserted properly when u packed or should we insert it.the machine is not responding on pressing TARE...
If the scale is ''on'' then the battery is in correctly. ''Tare'' is used for making the scale read ''zero'' when a ''holder'' (such as a cup or plate) is placed on the scale and you want the scale to be at ''zero'' with that item on top of the scale. With nothing on the scale, the tare button will not do anything. Also, you have to hold down the tare button until the scale actually displays ''zero.'' (Perhaps you are just ''pressing the button'' and releasing it? You need to press and _hold_ the button down until the scale actually reads zero).
Jan 01, 2015 | Cameras
How can you fix error on screen can it be reset
It often just needs recalibrating. Try turning the scale on while holding the mode/tare button with nothing on the scale. Then press the tare button again. It should show a calibration weight which you should put onto the scale. Then it automatically calibrates.
Nov 30, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
My digital gram scale does not work. the screen has some kind of word. Please help
Try recalibrating it by turning it on while holding the "tare" or "mode" button. It should show a raw data from the sensor then. Press the tare button again and it should calibrate the empty weight. Then it will show a specific weight you should put on, usually 100g. It should automatically finish calibration now. Hope this helps. The words before calibration on my scale was OUt2
Sep 24, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
I have a DigitZ DZ3-600 and when I turn it on the word FULL in the display screen . What can I do to clear this and start using it?
My search is telling me that this is a scale. Is this correct? If so - this is the manual. \'FULL\' is not an error, but this is the correct model. If this is not a scale, please write again and provide more information:
The manual is short and PASTED after link to same here:
http://digitzscales.com/index.php?option=com_content&view=frontpage
Digitz DZ3-600 Manual
I. Operation
1. Place the scale on a flat, level surface and press the ON/OFF key to turn the scale on.
2. Once the start-up process completes and the scale goes to zero you are ready to weigh.
3. Place the quantity to be weighed onto the weighing platform.
4. Wait a couple seconds for the display to stabilize before taking a weight reading.
II. Changing the Unit of Measure
1. Press the MODE key to change the scales displayed unit of measure.
2. If the scale is turned off then back on, it will default to the last unit used.
• DZ3-100 Units: g (gram) oz (ounce) ct (carat) gn (grain)
• DZ3-600 Units: g (gram) oz (ounce) ozt (troy ounce) dwt (pennyweight)
III. Using the Tare Feature
You can use this scale\'s tare feature to subtract the weight of an empty container or vessel for net weight determination. NOTE: The weight of the container will subtract from the available capacity.
1. Place the empty container or vessel on the weighing platform.
2. Press the TARE key once. The display will then reset to zero. If the container is removed, it\'s weight will be displayed as a negative number.
3. You may now fill the container with the quantity to be weighed. The display will show the net weight of the contents.
4. To return to normal weight display (gross weight), remove any items from the weighing platform and
press the TARE key again to re-zero the scale.
IV. Calibration / Adjustment
1. Turn the scale on by pressing the ON/OFF key.
2. Wait for the display to show "0.0g" or "0.00g" then press and hold the MODE key until the display shows "CAL", then release.
3. Press the MODE key again. The display will flash "CAL" followed by the required calibration weight.
4. Place the required calibration weight on the center of the platform. The display will show "PASS" then return to normal weighing mode. Calibration is complete! You may now turn the scale off.
V. Error Codes
1. OUTZ - Zero range has shifted. Perform calibration adjustment. If the problem persists, the load cell may be permanently damaged due to overloading.
2. 88888 - Maximum capacity exceeded. Remove the extra weight to avoid damaging the load cell.
3. L - Batteries are low. Replace the batteries.
VI. Specifications
DZ3-100 DZ3-600
Max. Capacity 100g 600g
Readability 0.01g 0.1g
Min. Weight 0.03g 0.2g
Power Two (2) AAA Batteries
Dimensions 3.0 x 5.0 x 0.8 in.
Platform Dimensions 2.5 x 3.0 in.
For warranty and support, please email
warranty@digitzscales.com
Aug 20, 2014 | Office Equipment & Supplies
Pocket scales read hhh turn
Try this - While it is off, press and hold both the mode and the tare* keys at the same time and press the On/Off key - Release the keys and observe the display - cycle through a series of numbers. Press the mode key once and observe the display "CAL 0" "100.00" then similar numbers as before. This step calibrates
Check here - http://wiki.answers.com/Q/How_do_you_calibrate_digi_weigh_scale_DW-100AX_or_fix_errors_such_as_F--H_or_ERR?#slide=1
Apr 12, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
My digiweigh keeps reading out 2 i changed the batteries but it still is reading out 2 what does out 2 mean
it needs to be cal turn on hit tare hold down until number show mine went crazy -628.2 anyways now hit mode an hold it down if it dont work an keeps turning of be quick turn on hit tare an hold down keep doing it till u get it took me about 3 times till i got it
Dec 04, 2010 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
I need a manual for a Berkley fs50 scale
Operating Instructions1
A. Powering-on the scale
1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
B. Normal Weighing
1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
C. Switching between unit weights
1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
D. Taring Weights
1. Weigh a bag or container till its weight is steadily displayed on the screen.
2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
E. Holding a weight
1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
F. Storing weights into memory
1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
G. Resetting the memory
1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
H. Powering-off manually
1. Press and hold the POWER button for 6 seconds.
Dec 09, 2009 | Berkley Twist Lock Rod Rack
When i turn on my digiweigh dw 100ax scales F--H appears on the screen how do i fix that and calibrate the scales when done
I thought the scale was just completely broken, I was able to fix by doing the following.
1. turn unit off
2. hold down the on/off/tare AND the MODE button.
3. The unit will come up with a bunch of numbers on the screen. Release the buttons
4. Press MODE once, you will see "100" flash on the screen. if you don't press the button a second time.
5. place 100g of tare weights on the scale.
6. Press MODE button again. After this my scale said PASSED and shut off.
7. remove tare weights and turn device on. It should now register properly.
In my case. the scale was misregistering the 50g weights as 75. I shut it off. I pulled up ever so slightly on the scale plate on the hinge side of the plate are repeated steps 1-7.
I have no idea why they don't have a 3 part calibration on these.
It is working like a charm now!
Sep 04, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Scale displays OUT2
you need just to recalibrate it:
The procedure is standard for semi-all models of pocket scales, but the way how to get to calibration mode differs from model to model (or vendor to vendor).
In brief:
1.While turn-on get to the calibration mode (by pressing and holding the ON button, or holding TARE while turinig on) You should hold this "magic" combination until the LCD will show a number (large number - it was more than 2000 in my case). This number is a raw data from the sensor.
2.Now release the "magic" button.
3.Press it one more time, the display will show 2Ero and then 100.0
4.Now put calibrated weight of 100 grams on the scale and wait 3 seconds.
5.Press "magic" button again.The display will show CAL and then PASS.
6.Now remove the weight and turn off the scale.
7.Thats all - now you can use your scale as usually.
Jul 26, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
F--H APPEARS WHEN TURNED ON AND FREEZES
that dosent work in the case of an f--h display at least in my case i think the f--h stands for f**king hopeless
Jun 17, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
DigiWeigh 100 X 0.01 Gram Digital Jewelry Pocket Scale Logo
2,189 people viewed this question
Top DigiWeigh Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a DigiWeigh Measuring Tool and Sensor Expert? Answer questions, earn points and help others
