My whirlpool 6th sense awod 5726 is flashing an f26 code
3 Suggested Answers
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
  • 6277 Answers
SOURCE: getting FE error on our
I suspect that stands for 'Filter Error' so I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 19, 2011
Testimonial: "I can only say a big Thank You for your kind help and prompt assiistance..it s a flter problem and cleared it off..back to working..Thanks a ton John."
The display stopped showing temps and displayed a "6". The actual temperatures dropped to freezing. I unplugged the unit a few times for up to 2 days but the same issue developed.
Whirlpool Refrigerator Error Code: Flashing 6 on the fridge display
Condition: The 6th Sense technology is activated - If you put warm food in the refrigerator or leave the door open, the 6th Sense technology kicks on to return the refrigerator to the set temperature. The flashing 6 should go away once it gets back to the right temperature.
Part or Parts: Allow fridge to get back to temp on its own (no parts required)
Whirlpool Refrigerator Error Code: 6 on the fridge display
Condition: Computer error
Check: Remove power for 5 minutes
Part or Parts: If code returns replace mother board
Apr 29, 2016 | Avanti Refrigerators
Tip
Tumble dryer not heating how to fix heater, thermostats, Ntc sensor.
We have all these tutorial guides that will help you with your Whirlpool 6th sense
How to clear error codes
How to service a pump unit on condenser tumble dryer.
How to replace belt, motor or bearings.
Tumble Dryer Not Turning, How To Replace Capacitor
We have all repairs guides on these Whirlpool 6th sense Tumble Dryers
http://www.how-to-repair.com/help/tag/6th-sense/
on Jan 21, 2015 | Whirlpool Dryers
HI, WE'VE GOT A WHIRLPOOL 6TH SENSE WASHING
washers are very expensive to fix they cost more to fix then to buy
Aug 09, 2013 | Whirlpool Washing Machines
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
My Whirlpool Washing Machine 6th Sense 10kg Dreamspace has stopped washing mid-cycle and has a F09 warning flashing
my whirlpool 6th sense dreamspace has a red ligth lit indicating water tap closed can anyone explain why?
Mar 15, 2010 | Whirlpool Washing Machines
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
There is a flashing #6 in a circle above the temperature indicator. What does this mean?
Mine did the same thing today and I just got off the phone with Whirlpool and they said it just means that the 6th Sense technology is activated. If you put a bunch of warm food in the refrigerator or leave the door open for a while, the 6th Sense technology kicks on to return the refrigerator to the set temperature. The flashing 6 should go away once it gets back to the right temperature.
Nov 21, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
May 25, 2009 | Dryers
Replace door seal on whirlpool model857037015500
Whirlpool AWOD 5726. How do you replace the door seal?
Jun 07, 2008 | Whirlpool Washing Machines
Washing Machines Logo
170 people viewed this question
Top Washing Machines Experts
