Question about Sport & Outdoor - Others
How to replace battery on Burris Speed Bead sight?
AR536 reticle won't illuminate. It used to. Changed batteries - didn't help. I'd hate to have to take it off and send it in - and have to re-zero it. Any thoughts.
Contact them direct. And yes, you will probably have to send it in unless they can send you the light source.
For general help, questions and information on any Burris products, please call 1-888-440-0244, or email us at customerservice@burrisoptics.com
Our hours of operation are 8 am to 5 pm MST, Monday through Friday.
https://www.burrisoptics.com/sights/ar-sights-series/ar-536?bvrrp=Main_Site-en_US/questions/product/2/119.htm
Dec 03, 2017 | Optics
Sorry front sight broke loose can this be fixed Remington 1100 ribed barrel
I assume this is a bead front sight.
The broken stub needs to come out (a few are pressed in, but most are screwed in).
Then a new one can be installed.
Brownells has replacement beads and the tool to install them:
http://www.brownells.com/shotgun-parts/sights/front-sights/index.htm?psize=96
http://www.brownells.com/gunsmith-tools-supplies/shotgun-tools/shotgun-sight-tools/shotgun-sight-installers-prod879.aspx
May 10, 2014 | Optics
Will the rings that come with aim point H34L fit a ruger guide rifle?
No, Ruger uses custom rings which clamp onto the receiver in machined groves. You can get Burris "Weaver to Ruger" adapters for about $33.00 at Brownells. Mfr Part: 410990
BURRIS RUGER TO WEAVER BASE ADAPTERS
Aug 17, 2013 | Aimpoint Hunter H34L with rings
I want you to explain how to site in the burris signature scope properly, with the posi lock system....
Check out this video by Midway, watching my help you with your problem. Click this link Midway video.
Jan 10, 2011 | Burris Optics
How to use that front yard adjustment on Burris fullfield II
That "front yard adjustment" is called the "Parallax adjustment ring". In order to get the sharpest image, and to reduce slight movement of the view when your head is out of alignment with the centerbore of the scope, set the yardage indicator at the distance you are shooting. You can fine tune the sharpness of the image by turning the ring slightly in either direction once you have made the initial setting. Most distance indicators are off slightly from the actual best setting.
Jan 17, 2010 | Optics
No problems.
I think CheaperThanDirt.com sells them. 1-800-421-8047
Dec 14, 2008 | Burris Optics
Sport & Outdoor - Others Logo
57 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
