Question about Raymarine C80 GPS Receiver
Raymarine G series radar
New install of G series radar. Radar and 15 " monitor work fine while under sail with motor off. Once I switch to the diesel motor, the radar operates fine for about 5 minutes and then the radar and the monitor shut down. I've tested the voltage while the engine is running and it is between 13.2 and 13.8 volts. Any suggestions? Sorry there is no category for this unit so I'm putting it in with GPS
    New Friend:
  • 132 Answers
Your problem is likely noise from the motor. Modern diesels use high speed networks, so it could be interference. Next likelihood would be a software issue. Is the diesel set up to display info on the G display?
Solution could be re routing cables, grounding or un grounding devices. First step is to send your processor to Raymarine, sorry, necessary step to eliminate hardware failure. This is a tough symptom, so do the easy stuff first.
Posted on Jan 29, 2010
Can't get radar on the screen
do you have the radar receiver or you just clicking on radar and wondering why you cant see it
Sep 01, 2013 | Raymarine C80 Multifunction Display
Even after double checks on settings Iam still getting weak echos on Raymarine E120 radar. On higher ranges picture is non existant. Where could my problem be?
How old is the radar antenna? When the echos are weak that is a sign of a failing or weak magnetron. Have you gone into the system diagnostics page to read what the signal strength of the radar is?
Jun 11, 2010 | Raymarine C120 System Pack C120 Raystar...
I Have a Raymarine Radar RL70CRC HSB2 the
If both plotter works but they have no comunikation
RESET the RL 70 AND L760
This is how it works
press the powerbutton when you have picture press the menu bottom
than systemsetup and than four seconds the menu bottom.
Do this on both plotter normaly after this it works again
Jun 11, 2009 | Raymarine RL70CRC GPS Receiver
Antenna not rotating
It sounds like voltage loss could be your issue. You need to find the "Y" cable under the dashboard and measure the voltage at the point where it connects to the main 12V supply. Keep the meter on and then spin up the radar. If there is a fuse (there should be) make sure you are measuring on the radar side of the fuse. If the voltage drops off as the radar slows, you have found your problem. If the voltage stays constant and the connections are sound at the terminations in the radar pedestal, I would recommend you send the pedestal in to Raymarine.
May 11, 2009 | Boating
Plotter Rl70c no image
sounds like it died...i happen to have one for sail with 4k dome
Sep 19, 2008 | Raymarine RL70CRC GPS Receiver
Raymarine 41xx - Message "bearing pulse error"
More than likely your motor is going bad. Inside the motor is your bearing pulse generator. Replace the motor and you should be ok.
Apr 28, 2008 | JRC 1500 MKII Radar
Raymarine SL70 Radar; Unit switches on normally, but there is no radar image appearing. The cable is ok, the scanner is rotating...
I have the same problem. All functions and settings appear to be working OK but no image. After startup time about 3.5 amps are drawm When I turn on power [transmit] amps goes up to 4.5 approx.
I have the scanner head spinning but no target images
Ian
Apr 07, 2008 | Raymarine RL70CRC GPS Receiver
Ray Marine c120
Send unit back to Raymarine. Two year warranty. I just talked to the factory about a communication error between the E series and the radar. Radar just stopped communication between radome and E unit.
Jan 31, 2008 | Raymarine E120 GPS Receiver
Raymarine C80 GPS Receiver Logo
135 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
