Question about LG GC900F Cell Phone
Hi how to remove call barring and network lock
    President:
  • 1,010 Answers
You can get the network unlock code through online..........give your IMEI number and get the network unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Posted on Nov 09, 2010
Will master reset remove network lock
Hi. Doing a master reset wont remove the network lock from a mobile phone. You need to enter it's unique unlock code to remove the network lock. You can get the network unlock code for a mobile phone from www.classicunlocking.com at affordable cost with easy unlocking guide. Good luck.
Jun 28, 2013 | Cell Phones
My nokia C6 is not supporting sim
May be the phone is locked with any particular network and you are trying to insert a different network.To unlock from the locked network approach Superunlockcodes.com and remove the restriction in your Nokia C6-01.
Jun 27, 2013 | Nokia C6-01 Smartphone - Wi-Fi - 3.5G -...
Mobile unloking
To get Unlock code for SAMSUNG Mobile phones from network lock...You can use unlock code...Specify the network ,country it is locked now ,Mobile phone brand and model also...Visit the site
Superunlockcodes.com get unlock code at low cost and unlock your SAMSUNG phone.
Nov 08, 2012 | Samsung Cameras
Hi, I would like to remove the network lock of my samsung E 1150
Hi you can use codes to unlock the mobile .to get the unlock codes visit here
onlinegsmunlock
Here they ask the following details before rendering the unlock codes they are
1. Mobile model
2. Country from where you brought the mobile
3. Provider to which the mobile is locked
4. Imei number of the mobile
Finally they will send you the unlock codes .once
you entered the code in your mobile as for the instruction
given by them .your mobile get unlocked and it accepts any network sim.
Aug 26, 2011 | Samsung Galaxy S GTI9000 Smartphone
Unable to complete secure transaction.
hi , always exit browser when you are unable to complete a secure transaction of any kind. check the address bar for the gold lock icon ! right click on lock and read the certificate off website supplier! its safer to type in https: rather than http ! if you are told cert not available on http bar DO NOT ENTER ! clean ur browser , exit refresh address bar and if the website info not available report the website as unsafe and try a different search bar ! hope i could help a little ; ) good luck hun ;)
Aug 06, 2011 | Facebook Social Network
Our back door (double glazed with locks at top, middle and bottom) has become permanently locked from the inside. It would appear that the lock at the top has bolted shut. (We have safestyle doors and...
Hi, W/D here.
Easy fix. Your upper locking bar has slipped. While someone is holding the door handle in the open position, you'll need to push the upper lock bolt back far enough to get the door open. You can slide it back carefully with a screwdriver or knife, a little at a time, while holding slight tension on the door with the handle. OK, door's open. Remove the inner door lock cover plate. The lever and locking knob will come off with it. Remove the mortise cover plate, on the edge of the door. Insert a small, thin bladed into the upper alignment slot in the lock behind the mortise cover plate, and loosen the upper allen screw behind the inside lock cover plate. Use the screwdriver to engage a slot in the locking bar, and raise or lower the bar until you have it level with the alignment slot. Tighten the allen screw.
Sometimes, the bar is so far out of alignment that you will have to gain access to the other end of the bar, in order to raise or lower it. This is done by removing the plastic cover on top of the door, and using needle nosed pliers to move the bar.
This should fix you up.
Best regards, --W/D--
Jan 28, 2011 | Locks & Locksmithing
Add New Network Card and remove slot bar
hi, the procedure how to remove the network:
1. You must pull out the RJ45.
2. There is a screw their in upper side of the card
3. pull out slowly the card then change it new network card make sure it is proper connected to the PCI port..
4. turn on the your computer then install the driver of your network card..
That's all....
regards
Mar 18, 2010 | E-Machines eMachines Desktop PC
Call barring
Call barring code is operator dependent code and not cell depepndent code..
This code works with PIN2 code, and it works only if your network supports, IF your network doesnt support call barring service cont use this PIN2 code, beacuse once you lock PIN2 by giving wrong number, it cnt be unlocked again
Default PIN2 is 12345, you can sheck the mnaual came with your service or call your operator tech support
Rate this solution
RNJVINODKUMAR
Sep 25, 2009 | Nokia 1650 Cell Phone
Need to unblock a c905
The answer is that there used to be a connection before O2 and Vodafone started blacklisting handsets! Orange and T-Mobile have been blacklisting handsets for a long time (It is only recently that O2 and Vodafone also started blacklisting handsets).
NB Orange & T-Mobile always lock their handsets!(e.g. an Orange handset will only accept an Orange SIM and will not accept an O2, Voda or T-Mobile SIM)
So if you reported your Orange or T-Mobile handset missing to your network it became barred/blacklisted! BUT it was only barred on your home network. Therefore unlocking the barred handset would enable it to work on every network except the one it was originally locked too! Therefore the phone still had some commercial value, as it would function on at least 3 out of the 4 networks.
It wasn't long before Orange and T-Mobile began to combine their individual blacklist databases. Therefore a phone barred on Orange was also barred on T-Mobile and vice versa. Even at this point the barred handset could be unlocked and used but only on 2 out of a possible 4 networks (O2 & Vodafone).
The government eventually stepped in and forced O2 and Vodafone to update their systems and introduced the CEIR. Now that all the networks share a central blacklist database, even if a barred handset is unlocked it still remains useless on ALL UK networks!
Hope that helps.
Mike
Jul 12, 2009 | Sony Ericsson Cyber-shot C905 Cell Phone
Network lock code for samsung d900i
IMEI has reported to barred,so contact Service provider to unlock the Code.
May 03, 2008 | Samsung SGH-D900 Cellular Phone
LG GC900F Cell Phone Logo
118 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
