Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Paper jamming is occur during processing with A3 pages
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 247 Answers
Check with the width and thickness
Posted on Nov 09, 2010
My mix 434 is not printing clearly after a paper jam .how do I solve this problem
1, This issue occurs due to the jams that are stuck on the Printhead. If you are facing any issue even after removing the paper jam and cleaning the ink cartridge, some missed out or bits of paper may be stuck on the printhead.
2, Before cleaning the printhead try turning Off your printer overnight and try printing. If the issue dosen't get resolved, then go further with the printhead cleaning. Make sure you have the appropriate printhead cleaning software.
3, During the process of cleaning the printhead, it uses ink or in other words the ink may be wasted. So attempt the cleaning process only if the print quality is not good.
4, Ensure that you have loaded the correct size papers. Now tap the Maintenance tab and then the Head Cleaning button. Follow the instructions that are displayed onscreen and wait until the printhead cleaning progress is complete.
5, During the printhead cleaning process, do not turn Off your printer. After the completion of cleaning select the option Print Nozzle Check Pattern, which will notify you about the completion of the printhead.
For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220.
Oct 11, 2018 | Office Equipment & Supplies
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
The copier experienced repeated paper jams
Pl. mention make/ model and where it jammed. if possible the photo of the jammed paper inside the machine. Also mention the total pages printed in A4 and A3 size.
Thanks.
Dec 13, 2014 | Office Equipment & Supplies
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
Page is not loading during printing
Occasionally, paper cannot be load during a print job.
Some of causes include:
• The tray is overfilled.
• The front cover has been opened during a print job.
• Paper that does not meet paper specifications has been used.
• Paper that is outside of the supported size range has been used.
If a paper jam occurs, the On Line/Error LED on the control panel lights red.
Find and remove the jammed paper. If it is invisible, look inside the printer.
Note: U would find the complete instructions along with the screen shots in the below link
http://tinyurl.com/notloading
Best of Luck
Dec 05, 2010 | Samsung ML 2010 Laser Printer
Make A3 Copy (Toshiba Studio 206)
If your copier didn't set any A3 drawer, then u need to insert A3 paper on bypass unit, on left panel select A3 (Original) to A3 (copy) b4 u press the start button. Otherwise paper jam will occur.
Apr 05, 2010 | Toshiba e-Studio 205 Copier
I have a Canon Image Runner 3230 which we also use to scan PDF files into our snap drive. When scanning a large job build, if the machine jams, the documents already scanned in the job build are lost. Is...
Hi mail. Let me tell you a workaround for this problem.First of all I understand every aspect of your question and problems as the document feeder for the ir 3220 is about the biggest piece of **** I've ever seen and I have been working on copiers since 1988.And when you use the "Universal "SEND" " function I also realize that for example if you have scanned a 500 page document and it jams at 499 you have to start all over again.That because the copier has established communication with the server directly during the "send" process and when an error {document paper jam} occurs, for whatever reason the error cannot be reconciled on the fly. BUT!!!!! :-) If you scan the same document(s) to the "Mailbox" function the copier can and will allow you to recover from such a mishap as the process you are conducting is all happening "on board" the device so if a jam or misfeed occurs in the document feeder during the scanning process the copier will tell you to put the stack of originals back in the feeder with page 1 on top.Then the copier will begin to feed the originals quickly merely to count the pages till it finds the the one it jammed on.Once it counts to the original it failed on it will resume the scanning process.THEN...... no matter how many failures have occurred during the process, once you are done the "SEND" function will appear as an option.At this point you will be viewing the "batches " of documents in the display because if it is a large document you will not have been able to put the entire bulk in the feeder at once.Now highlite all of the"files/batches" and hit EDIT. Under edit will be the "merge" option. Select merge and all the batches you have highlighted will be merged together into one big document.NOW selest SEND and designate the location you wish to send it to.Since the document in its entirety resides correctly in a "mailbox/hardrive" storage area it can be sent with no fear.I have many customers with this same difficulty and this has been a lifsaver. hope this help,and have a better day! :-)
Feb 10, 2010 | Canon imageRUNNER C3200 Copier
How can fix the jammed paper situation?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-17
Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
LJ3700 page tops half- way through fuser. Bob
13.01.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. 13.02.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. these are areas that you mentioned and fixes to them http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00047478#A3 this is the link to all error codes for your printer you might want to print these out and keep safe
May 07, 2008 | HP Color LaserJet 3500 Printer
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
Clive
Clive
old marine
old marine
