Question about Samsung Microwave Ovens
We purchased microwave oven GW73BD-B of Samsung co.on 16-10-2010 and many times requested to the customer care of the co.as well as to the dealer to give demo and the customer care asked me to talk on phone no.9896156566 and i talked to Mr.Hanuman on this number but all my efforts gone in vain and no body came to give the demo and the articleis lying as showpiece.Kindly redress our problem. Gurnam Singh 09416793138
MicrowaveSvc
  • 9098 Answers
SOURCE: Instruction manual for 1986 Amana Radarange microwave
I think it will use a standard generic probe for the Accu-Temp. Sorry I couldn't help. Take care.
Posted on Jan 28, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Keypad for Samsung microwave
To find out about Samsung recalls, please call Samsung's Service Division at 800-932-3837.
Please let us know what you find out so others can benefit.
Posted on Aug 20, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Sharp Microwave Oven Timer Counts Down Very Fast (Demo mode)
Here is where you can download the manual
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Yes the problem can be undone also.
Posted on Feb 09, 2009
asnowman
  • 788 Answers
SOURCE: Set clock time on microwave oven
I have consulted the Owners Manual and there is no mention of the demo mode. I would suggest that you unplug the unit or disconnect power if it is hard wired in, and try to set the clock then.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Jul 04, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: The microwave oven starts and runs for a number of
This problem is almost always due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
Details covering some previous models are in GE's bulletin here. Even if your model is not on the list, the same problem can occur.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
NOISY MAGNETRON TEST (c) 2009 William E. Miller prototech@usa.net
One way to test it is to do the following:
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. )If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.)
3. Plug the microwave back in.
4. Make sure neither you nor anyone else reaches in behind the control panel. There will exposed high-voltage connections.
5. Put a few cups worth of water in a microwave-safe container and place it inside the microwave.
6. Shut the door.
7. Run the microwave for about 1 minute or so on full power. (Time Cook > 1 > 0 > 0 > Start, e.g.)
8. If it does not fail, try it several more times.
9. When the water boils, change the water and try again.
NOTE:
If your model does not have a door handle, you will need to unplug the oven and reattach the control panel to be able to open the door.
If it still does not fail, I would recommend that you put it all back together and keep using it until it fails more consistently, then repeat this test.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions
here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help
here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it's under magnetron warranty, GE will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the magnetron warranty, you can find links to helpful exploded view diagrams and part ordering help here.
If you prefer to arrange service by an authorized service center, GE Customer Service is here.
Posted on Nov 29, 2009
Button pad on microware NN-A872 not working
Customer Care Centre 08705 357357
Selected Spares and Accessories:
Order direct on line at www.panasonic.co.uk or by
telephoning the Customer Care Centre number above.
Dec 20, 2011 | Panasonic Microwave Ovens
My is working with slow with out pressing any time
BASICALLY, the microwave works using magnetron for generating the MICROWAVE signal.
So if your system is slow the wave generated for any amount of power input and time will be less .This may be due to fault in your timing circuitry.
your MW became time independent,so the proplem lies there.
please contact service through Samsung, please submit an online service request through the link below, or call 800-SAMSUNG to speak with an agent who will be happy to assist you.
Feb 06, 2011 | Samsung MW1030WA Microwave Oven
Samsung microwave model gw73bd-b usermanual
You can download and print the instruction manual in PDF format by clicking this link.
http://downloadcenter.samsung.com/content/UM/201007/20100730153228015/GW73BD_XTL-03796G_EN.pdf
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Feb 04, 2011 | Samsung Microwave Ovens
I have a samsung microwave oven with model no. C1113 purchased on 19th April 2006. Last month it stopped working when I registered my complaint with the customer care after nearly 15 days the service...
I need to know what is wrong with the appliance.
Does the display work?
Does the machine appear to work but with no heating?
Is the machine dead?
Feb 02, 2011 | Microwave Ovens
I am having a microwave ovan "Magicook 20g (M) (I), but I am not familier with the options given in it. Request to advise from where I can get the user manuel. Can you provide me the E-copy of user...
http://www.espares.co.uk/search/whirlpool/p/0/278?utm_source=google&utm_medium=cpc&utm_term=whirlpool&utm_campaign=Spares_Whirlpool
or log on to the manufacturer's web site, whirlpool.com, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, and a list of Dealers as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Nov 20, 2010 | Whirlpool GH7155XHS Microwave Oven
Hi have hoover dishwasher hd96m...does any one know where i can purchase the lower part on the front as it is broken. all usual channels have been exhausted. ty
I am sure what your part is I guess it may be the kick plate.
If you go on the Hoover site you should be able to earch the site for the part or request help on the site.
www.4Hoover.co.uk
Regards
Alan Hood
ami-man
Apr 05, 2010 | GE JES1142SJ Microwave Oven
Hinari mx310 microwave setting the clock i lost instructions
Here is the latest contact info for Hinari:
Hinari by Alba
Pulse Home Products Limited
Customer Care Department
Vine Mill
Middleton Road
Royton
Oldham OL2 5LN
Customer Support 0161 652 1211
Fax number 0161 652 0538
E-mail: alba-accessories@twelectronics.co.uk
Oct 23, 2008 | Microwave Ovens
Microwave Ovens Logo
134 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
