Question about Sony KDF-E60A20 60 in. LCD HDTV
Hi I need to buy and install the thermal fuse
Do you or do you know where I can purchase it online?
Thanks
Marc Daniels
  • 298 Answers
The Thermal Fuse can be found at the website below.
Sony KDFE60A20 Thermal Fuse Replacement
Posted on Jun 18, 2008
A slide got stuck in the projector, and when I took it out the projector just died. No power. Any ideas about what's happened? Thanks
If this is a Kodak Slide Projector, there are 2 thermal fuses (1 is in the motor and NOT replaceable and 1 is in the area of the lamp). Almost ALL Kodak projectors had 2 thermal fuses as described. You need to determine the model, as that will determine which fuse or motor assembly you will have to buy & install to fix your projector. If its a Kodak, let me know the model and I can help you further! You can buy parts for Kodak projectors at: www.micro-tools.com.
Good Luck! Jim
Feb 04, 2013 | Office Equipment & Supplies
My grandmothers dryer wont heat up. It is a Kenmore, (model) 86870100, with (serial no.) MX1661182. Would like to know how i would know for sure if it is either the element or a fuse.
you will need to open the dryer and look at the element, if you have a meter you will need to ohm it out, but more then likely the thermal fuse is bad. In order to test, test only after test disconnect the bypass, you will need to bypass the fuse: take the two spaded ends off the thermal fuse and tape them together then turn dryer on if you have heat you will need to replace fuse, can be purchased online. eBay is the cheapest but can be purchase from a appliance sales/repair shop, Tim:
http://www.ehow.com/how_5044534_open-kenmore-dryer-panel.html
http://www.ehow.com/how_6746180_bypass-fuse-kenmore-drying-machine.html
May 27, 2011 | Dryers
My control panel went dim at first and eventually wnet completely out. Oven still works and so does oven light. Whirlpool suggested thermal fuse or control panel problem. Any thoughts?
I would replace the control panel...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Jan 19, 2011 | Whirlpool RBD275PD Electric Double Oven
My dryer needs the Internal Thermal Fuse, I work from 7am to 5pm where can I find this part after work. I Tx, Dallas
How to Buy
heatman101
Dec 07, 2010 | Kitchen Ranges
Where to buy and how to replace the thermal fuse?
That is not that hard to fix and you can easily buy the parts yourselfonline...
How to Buy Appliance Parts Online
heatman101
Sep 18, 2010 | Bosch Axxis WTA 3510 Electric Dryer
The top of my 500ml/0.6qt thermal vacuum flask is broken and i'm not sure if i can get a replacement as the thermos is still okay. i would be grateful to know if i can get a replacement top so i don't have...
Well yes you can purchase a separate flask for your thermal vacuum, you may purchase them from the dealer or you can please post the brand of your thermos so we can help you to find the part.
Good Luck!!
Thanks
Aug 04, 2010 | Vacuums
Hi, My Windows XP detects new hardware, installs it, says it's ready to use. Cannot open it. After a little while, a pop-up arrives telling ''USB Device Not Recognized....'' What can I do ?? Thanks in...
Try Control Panel, Administrative Tools, Computer Management, Storage, Disk Management.
Check there to see if the drive is listed, "online" and has a "Healthy" Partition.
Dec 17, 2009 | Electronics - Others
Resister
Hi, how did you get on with identifying markings. It is more likely to be a thermal fuse, but if you can get me the markings, I can tell you what to get.
robotek
May 13, 2008 | Rival RC100 10-Cup Rice Cooker
Crosley dryer-model # cde6500w
I believe that you probably purchased a kit of fuses which provides fuses for several different types of dryers. That way the parts store can sell you the kit without knowing exactly what type of dryer you have. If I am right about this, there is no yellow fuse in your dryer, you will need to buy a new one to replace the red dot fuse. Also, you will want to find out what is causing it to blow again so quickly, probably your exhaust duct is a little plugged, causing the inside chamber to get too hot.
Dec 27, 2007 | Dryers
Sony KDF-E60A20 60 in. LCD HDTV Logo
406 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
