Question about Logitech Z Cinema 2.1 2.1 Speakers
How do i connect my logitech z cinema speakers directly to my lcd hdtv. I know you have to use an RCA y cable adapter or sumthing like it, but what are the steps?
5 Suggested Answers
ioant27
  • 63 Answers
SOURCE: how do i conneect logitech speaker to a vizio flat screen?
Well these speakers, as you said, are designed for PC, not TV. Even if they work with one TV, that does not mean they will work for another TV! I am glad to help for a Premium Question!
Posted on Mar 02, 2009
djnick989
  • 1067 Answers
SOURCE: Convert d9 to rca connection
its not worth it 1st off to run off tv and it need sit corrosver from main unit to understand 1650 hertz lower otherwise be outtta control best bet to buy mtx 12 100 on ebay have a real nice quilty sound dont waste time with that even the way u wnan do it will still sound pooor i run for my buddies these off his tv rca outs to mini jack steri works ok not greatest not for movies for pc even then low line not worth your time to rug it that way just use front green mini sterio jack to a female mini sterio to rca cables from rca out of tv that way u get fronts and sub ok
Posted on Jan 09, 2008
info2u
  • 596 Answers
SOURCE: Will my Logitech X-230 speakers work in a country with 220-240 V
Check the back of your sub to check your voltage range. You will see something like this: 110V-120V or 110V-220V. If you see the later, you are ready to go. If you see 110-120V only, you will need a power converter to power your speakers as well as any other 110-120V equipment. But no matter what, if it is 110-120V DO NOT PLUG DIRECT TO 220V!! It will blow your speakers. (I lived in Germany for 11 years.)
Posted on Aug 12, 2009
  • 29 Answers
SOURCE: Logitech Z-Cinema Speakers.
I have these. Just hook up via usb cable. However, to make them work, you have to get the driver for them off Logitechs website. Here is the link : http://www.logitech.com/index.cfm/439/3712&hub=1&cl=us,en just click on the "downloads"button and select your operating system and you can find from there.
Posted on Dec 07, 2009
Testimonial: "Thank you so much for your efficient, quick ,and easy to understand answer to my question!"
How to get the internal connection layout circuit of Logitech X-530 5.1 game console adapter?
You would only get this from Logitech direct. Go to their web page and click Support or Contact. If the device doesn't work as you expect, more reason to contact them.
Mar 16, 2016 | Logitech 5.1 Game Console Adapter Convert...
How do I connect external speakers directly to the t.v.
It will depend on the speakers. If you have computer speakers with a 3.5 mm plug, use a RCA audio (M/M) to 3.5 mm (F) adapter. Plug the RCA end to the audio out on the TV (to the right of the HDMI ports and below the digital audio out).
If the speakers do not have a built-in cable then use an RCA audio (M/M) to 3.5 mm cable or the adapter with the 3.5 mm audio patch cable. Alternatively, you could use an RCA audio cable with the reversed adapter (RCA (F/F) to 3.5 mm (M)).
I hope this helps.
Jan 23, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
How to connect logitech X-540 to LG 42
Hi, You should have an Audio outpout RCA behind your TV. Plug it 2 RAC then the cables to an RCA/ 3 mini JACK adapter. Plug the 3 mini jack to the X-540. You have your audio output settled up on your X-540. Thanks and have a nice day !
J -
Jan 23, 2010 | Logitech X-530 Computer Speakers
Can i connect a coby 5.1 dvd home theater system to a 32 inch vizio and be able to watch tv with the surround sound on. I know the surround sound can play while im watchin a dvd but i would rather just...
you need a logitech sound adapter or game adapter that costs 4-10$ on ebay.
Connect LR channels using an RCA cable and hook up the speakers on the other end of the game adapter
Jan 10, 2010 | Vizio VW32L 32 in. LCD HDTV
I want to connect 2 speakers(left and right) to lcd.how can i?
Please follow the steps below:
Step 1: Connect the two RCA plugs on the Y adapter to the right and left Audio Out jacks on the back of the LCD TV.
Step 2: Insert the mini-plug on the cable attached to the right-channel PC speaker into the mini-plug jack on the Y adapter.
Step 3:Connect the mini-plug on the audio cable attached to the left-channel PC speaker to the mini-plug jack on the back of the right-channel speaker. This completes the PC speaker connections to each other and to the television. The TV sends an audio signal to the right PC speaker, which separates the signal and sends the left-channel stereo information to the other PC speaker.
Step 4:Connect the AC power plug to the back of the right-channel speaker and plug the other end into an electrical outlet.
Step 5:Switch on the speakers and the television to enjoy audio from both the TV's built-in speakers and the external pair of PC speakers.
Regards
BEADHZ
Dec 30, 2009 | LG 37LC7D 37 in. LCD HDTV
Logitech Z-Cinema Speakers. How do you connect them to a PC Desktop? If bythe USB Cable Supplied does this bypass the PC Soundcard?? Are they compatible with Windows 7? Many Thanks, David
Dec 06, 2009 | Logitech Z Cinema 2.1 2.1 Speakers
I want to connect the z2300 speakers to an LCD tv. Do I need a special cable?
try to check your speaker if what type of cable your speaker have...your LCD tv i think its a RCA connector, so you have to insert the RCA connector to the output audio label,,,then the cable which is also an RCA output must be connected to a RCA female connector ....again the output the your female connector will depend to what your speaker output have....it its minijack or RCA then the output must be female RCA of mini jack also.
Oct 19, 2009 | Logitech Z-2300 Computer Speakers
X-540 speakers no sound rear speakers
rear speakers are not designed to put out the same output as fronts. They are for supplemental sound only, to make it seem like there's something happening behind you.
Dec 02, 2008 | Logitech X-540 Computer Speakers
Connecting Logitech X-530 speakers to TV flatscreen.
It really depends on what the Tv is capable of, and how you want to strategize the connection, but yes, it can be done.
According to the X-530 User Manual , the speaker system comes with an included video game adapter, for hookup with a console. if your LCD TV has stereo RCA output jacks, you could hook up your speakers to it in that fashion. If not, you may have to buy an adapter that converts whatever you have to RCA.
Another way you could attempt to connect it, is to buy a stereo RCA-to-3.5mm (g9) adapter, and connect to your computer's line in (if it's stereo). Your computer would be doing all the speaker sound positioning, and would have to be left on while you're watching TV, but that would work, as well.
Jan 01, 2008 | Logitech X-530 Computer Speakers
Logitech x-350 speakers
Well i have the X-540 and i use my speakers for my tv. but the it shouldent matter, first you should have a docking station with the RCA cables ( red, white and yellow). Connect the green audio plug connected to the back of the subwoofer to the green plug Videogame adapter(as seen in picture.) Then plug the RCA cables from the docking station to the game adapter. (Red) (Vid. Game Adapter) / (Green)____________/ \ \(White) Hope this helps. p.s if u are connecting the speakers to the computer, remember u must have a sound card that has at least 6 channels ( 8 channels is best) if your do not have one for your comeputer, ask for an 8 channel sound card from your local computer/electronics store or type in "8 channel sound card" in ebay, its where i got mine
Sep 06, 2007 | Logitech X-530 Computer Speakers
Logitech Z Cinema 2.1 2.1 Speakers Logo
599 people viewed this question
Top Logitech Audio Players & Recorders Experts
Paul
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
