Question about Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Removing lens from barrel
i have a pair of EF-S 18-55 usm lenses, one is badly worn and wont focus well (focus barrel is loose), the other has a scratched lens (filter end)
There are two holes that would suggest the ring unscrews, I have machined a tool to fit but it wont budge. I don't want to put too much force on it with it being plastic. Can the ring be removed or do I have to dismantle the lens from the other end?
Thanks
cammedic
  • 667 Answers
SOURCE: I have a Canon EF 300mm f/2.8L USM Lens
Here is a link to many Canon products in PDF form: Canon Parts Lists
Unfortunately, the only 300mm 2.8 lens listed is the IS version
The procedure is not that complicated, but you need to pay attention to the connections on the circuit board. The mount is removed, and you need to remove the small screws that hold the connector board to the mount ring first.
I cannot do live chat due to I use a Mac, but I will monitor the thread if you have questions,
Kevin
Posted on Mar 24, 2008
SOURCE: My camera lense will not focus automatically or manually.
There is no battery in the lens.  The lens receives power from the camera. Whether or not the lens is getting power, though, you should be able to focus manually.
When you say you can't focus manually, do you mean that you can't turn the focusing ring on the lens, or that when you turn the ring the image does not come into focus?
If you decide the lens needs to be repaired, I recommend sending it to Canon.  You can go to their website (canonusa.com if you're in the US), click on support, and follow the links.
Posted on Dec 26, 2008
SOURCE: EF 24-70 lens droop...
The zoom creep is an easy fix for Canon. I really do not recommend trying to tighten it yourself, since that would void your warranty.
It is usually free to tighten the zoom ring.
/Chris
Posted on Jan 19, 2009
  • 421 Answers
SOURCE: Canon EF 75-300mm f/4-5.6 III USM Lens
If your AF motor is hunting then the lens probably needs to be looked at. I wouldn't recommend this as something to do at home so you will need to either find a repair shop if it is out of warranty or return it to Canon if it is in warranty.
Posted on Jan 17, 2010
  • 102366 Answers
SOURCE: how to take apart Canon EF 28-135mm f/3.5-5.6 IS
Having gone over a month with no response, I assume this is no longer a problem.
Posted on Aug 08, 2010
Very loose lens 75-300mm canon zoom
If it is loose on the camera mount, try to avoid using it. If it causes your camera mount to distort, then you won't have much luck with any other lenses!
If it is "loose" meaning: it rattles and there's a bit of play in the 'barrel'...yuuup - get used to it. She's an oldie but a goodie.
Oct 24, 2013 | Canon 75-300mm f/4-5.6 III USM EF Lens
My lens is really loose when I zoom out , how can I fix it, I have a canon ef 75mm to 300mm
There's a screw located on the barrel of the lens. This may help tighten things up, but don't count on it. Don't try to take it apart unless you know what you're doing. There are a series of sleaves within the barrel which need to match up and you might have to fork out more than the lens is worth just to get it fixed
Oct 16, 2013 | Canon 75-300mm f/4-5.6 III USM EF Lens
Canon EF 100-400 not auto focusing
It is probably a broken ribbon cable in the lens. It will need to be replaced.
Dec 18, 2012 | Canon EF 100-400mm f/4.5-5.6 IS USM Lens
Canon EF 70 -200mm F2.8L IS USM will not auto focus sometimes (using a 2x converter)
Check out the Canon guide for converters Some will not auto focus with a converter and you can only use manual focus
Nov 28, 2010 | Canon EF 70-200mm f/2.8L IS USM Autofocus...
Conon powershot A450 lens error
Try to use fresh batteries, and push the barrel in and out when it turns on to see if the 'binding' of the focusing gear can go away when you do this manipulation of the barrel.
If the error continues, maybe the camera needs service by Canonusa.com.
I could not, unfortunately, find a reference for an a450 on the website, though. Is that an older model?
Jul 29, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Cannot auto focus
It sounds like the circuit board flex has gone bad, It folds back and forth when you zoom the lens, And needs to be replaced by a repair shop and readjusted. Tony
May 26, 2010 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Canon EF 75-300mm f/4-5.6 III USM Lens Auto focus motor keep working back and forth but lense is not able to stop on focus right. Had eror 01 also sometime with manual focus.
Jan 17, 2010 | Canon 75-300mm f/4-5.6 III USM EF Lens
Dec 20, 2008 | Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
Canon EF-S 18-55mm f/3.5-5.6 USN Lens Logo
296 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
