Question about EliteGroup P4VXASD2 Motherboard
My motherboard power on but no beep or booting
  • EliteGroup Master
  • 27,725 Answers
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Nov 09, 2010
PC Freezes During Boot and at the BIOS Screen, EVGA P55 Classified 200
Beep Code Descriptions
1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
Aug 30, 2012 | Evga P55 Classified 200 (160LFE659KR)...
I am using a intel Dh61ww board with intel i3 2100 processor. When i switch on the pc the cpu fan rotates and halts.no display. pls help me.
The steps I would take would be : 1 make sure you have a power supply with the proper power connections and at least 500 Watts 2 remove and reset the power connections, try to boot 3 disconnect all hard drives and cd/dvd's, try to boot 4 remove all ram/memory sticks, try to boot and listen for the beep or beeps if it doesn't beep and still shuts off, you have a bad motherboard and/or cpu if it does beep, you need to try different ram
Aug 23, 2011 | Intel Motherboard
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
GA-7DPXDW-P motherboard will not boot or beep
Make sure that power cord from the power supply is seated in good. If that don't make it boot or beep sounds like your board got toast by some surges.
Nov 15, 2009 | Gigabyte GA-7DPXDW-P Motherboard
NO POWER
If you have changed the power unit and the computer is still not powering up, then it is quite likely there is a motherboard fault - probably in the power management circuitry, which expects the power_good signal from the power unit at a precise moment in the boot up process. A fault in the power management circuitry would prevent the computer from beginning its boot-up process.
Do the fans in the power unit come on when the computer is switched on? If they don't - this suggests a power unit problem. If the power unit fans do start working but the computer still doesn't boot, this suggests either a faulty or 'dry' connection (easy checked) or a motherboard fault.
If your computer 'works' but nothing is displayed, try pressing Control+Alt+Delete. If it then boots up it suggests a power unit problem. If not .. we come back to the motherboard again.
A low wattage power unit can cause the problem you describe. Every 128 Mb of Ram needs 4 watts of power. Add more for the motherboard (up to 30 watts..) then the floppy/hard drive/dvd etc .. If the power unit can't supply the necessary wattage, it won't boot. The older 250-300 watt power units aren't suitable for modern computers with XP/Vista. Ideally, you should be looking at 400 watts plus -it will tell you on the power unit.
Though to be honest, it does sound like a motherboard fault.
The only other thing that can cause a computer not to boot up (though it will begin the boot up process) are other faults ... When you switch on does it actually display anything on the screen .. and are there any 'beeps'? 1 beep indicates everything is ok .. 3 short beeps and 1 long beep indicate a memory problem (and the computer won't boot..). 8 beeps indicate a video problem (and nothing will be dislayed on your screen). Same with 9 beeps .. which indicates a bios fault - and the computer won't continue the boot process.
If you have nothing .. no power whatsover ... it comes back to the power unit/mainboard. If you're happy that the new power unit you have put in is ok ... suspect the motherboard. If you have access to any unwanted or 2nd hand motherboard ... connect that. If your computer boots up ... its the original motherboard at fault.
Alternatively, rather than replace bits and pieces at random to cure the fault, take your computer along to a computer shop. It will take them minutes to test it for you and identify the fault.
May 17, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
A770m-aboot problem
Check the power supply, if its working right you should hear a beep on this motherboard.
Mar 30, 2009 | EliteGroup MB ECS A770M-A 770 SB600 AM2+...
Machine will not boot up
This could be several problems in order of cheapest to most expensive:
Memory: Take out the RAM and re-seat it, apply even but firm pressure. Try to boot again. If this does not work...
Power Supply: Your power supply might be dead, try to pick up a brand-name one and boot once more...
Motherboard: This is the worst case scenario, your motherboard went poof buying a new computer might be better than buying a replacement motherboard.
Dec 21, 2008 | E-Machines T6532 PC Desktop
Boot failure
samuel,
if you don't here ok beep or any error beep:
  1. First check out speaker is connected properly to motherboard.
  2. Remove all component from motherboard like HDD,FDD, RAM etc..
  3. Just put only processor to your board and power-up
  4. There must be a long beep for missing RAM, if not means you have problem in Motherboard or CPU. Try out another board and another CPU to find out which one is faulty.
  5. If you got missing RAM beep, then power-off and add RAM. Then power-up there must be ok beep (only one beep) or missing RAM beep. If missing RAM beep, then your RAM might be faulty try to clean the connection point with pencil earaser and try out again. If no success then try with another RAM.
I think this will help you.
Please post your feed-back. Or ask me if any question.....
Gud luck
Iqbal
Apr 21, 2008 | Computers & Internet
Motherboard pc chips m810 lmr v7,1
The beep codes are not universal, but there are a few popular BIOS's and you can figure out what 2 beeps means if you can find your BIOS listed here:
http://www.computerhope.com/beep.htm
The name of your BIOS should appear on the monitor as you're booting.
Nov 20, 2007 | Asrock M810LMR Motherboard
My serial and password will not register my dvdxcopy
Check
Click on underlined items for further information
1 Beep
If the PC boots properly, then this beep is normal. It is an audio cue that the PC has passed the POST and started to boot.
  • (AMI) Memory problem
  • (AWARD) Memory problem
2 Beeps
3 Beeps
  • (AMI) Memory or motherboard problem
  • (AWARD) Video problem
  • (IBM) Keyboard problem
4 Beeps
  • (AMI) System timer failure
  • (AWARD) Video Problem
5 Beeps
  • (AMI) CPU or motherboard problem
6 Beeps
  • (AMI) Keyboard or motherboard problem
7 Beeps
8 Beeps
  • (AMI) Video card or video memory problem
9 Beeps
  • (AMI) Motherboard problem
10 Beeps
11 Beeps
  • (AMI) Cache memory error
Continuous Beeping
  • (AMI) Memory or Video Problem
  • (AWARD) Memory or Video Problem
  • (IBM) Power problem or loose card
Oct 28, 2007 | 321studios DVD X Copy Platinum (200000)...
EliteGroup P4VXASD2 Motherboard Logo
54 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
