Question about Car Audio & Video
I need help/instructions for installing a subwoofer to my 2005 Acura TL. it has a factory stereo and does not have sub/RCA outputs in the rear. I purchased a Speaker to RCA converter i order to tap in the wires and than send the signal to the amp. the Car comes with a small bose sub in the rear and i was wondering if i could tap in those wires, or it had to specifically be the wires for the right and left speakers. also doest it have to be the wires that branch off right behind the stereo? Thanks for your help.
  • 1 more comment
  • Daniel Dolin
    Daniel Dolin Nov 09, 2010
    Thank you for your help man. i seem to be having a problem though. the Amp will not turn on. I ddont know if its my connections are bad/wrong or what but heres what i have done. I routed the power witre from the battery to the amp-secure. The ground wire is on a good ground and than routed to the amp-secure. I read the the amp with a mulitmeter from the power terminal to the ground and it read 14V. I than have rca cables going from the amp to the converrter and than the converter going to the cars original sub wires. Does it matter how i connect those wires? Also do i need a remote wire (i think its a blue wire normally) that signals the amp to turn on? or should that not matter since the wires going to the car sub are already getting a signal. Thanks for any advise/help.
    Danny
  • Daniel Dolin
    Hey Man,
    thanks for the help, i am still a little unsure about what to do with the remote wire, do i route a remote wire from the amp to the toggle switch and than to the remote wire behind the stereo or what? where do i route the other end of the wire to? also there are 4 wires for my RCA converter, a R, -R, a L, and a -L, but there are only two wires going to my sub, how should i splice them? THanks again man,
    Danny
  • Daniel Dolin
    Daniel Dolin Nov 11, 2010
    finally figured it out, thank you bro
    President:
  • 2,777 Answers
It can be any wires that carry a signal. The ones that are going to the BOSE sub currently in there will definitely work, they are already producing sub-range frequencies, so it will work best. If there is the equivalent of a sub out on that deck then these wires will be it, if not they will be the same as any other wires in the car.
You can attach it anywhere, behind the stereo is just as good as right in front of any speaker... the signal is the same. The only time it wouldn't be is if the cables were hundreds of feet long, which of course they are not.
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Posted on Nov 09, 2010
  • Tim Grayson
    Tim Grayson Nov 09, 2010
    Ah that is the problem, the remote wire I would bet:
    You have to purchase a toggle switch that fits your fancy, find a cool
    place to mount or hide it, from here you want to attach the remote wire
    to your amp, run it to your toggle, cut it, attach it to one terminal,
    then attach the end you just cut to another one. Then run the remote
    wire back to the amp and cut it there leaving a foot or so of extra
    cable.
    Then use the toggle switch to turn on and off the amp...
    Essentially something like this, but they make fancy ones out there... you should be able to get one at radio shack:
    http://soundsgreatusa-online.amazonwebst...
    If you want to reply please hold off until the morning, it only gives me a few hours to respond once you reply, and if I don't it locks me out of the problem.
    Please wait until no sooner than 5 AM Eastern Time to reply if possible.
    Thanks sir, I think we have it figured out though, but please reply tomorrow if need be...
    Tim
  • Tim Grayson
    Not sure how to splice them, checking on that for you. But I think both L's go to the Left channel wire and both R's go to the right channel... not sure where else they could go. I am checking on this for you.
    Here is a step by step for how to install the toggle:
    http://i.ehow.com/images/a04/ap/mm/insta..." class="h_mi" />
    A properly installed toggle switch should give years of service.
    Derek Odom
    Most automotive toggle switches are three-prong
    units that are really quite simple to install and wire up, once you
    understand exactly what it is you are doing. A well-placed and properly
    mounted toggle switch will give years of trouble-free service. There
    are many styles available, from simple paddle toggles to rockers and
    push-button switches.
    Difficulty: Moderately Challenging
    Instructions
    Things You'll Need:
    • Toggle switch
    • Wire
    • Wire strippers
    • Terminal connectors
    • Drill with appropriate bit
    • Voltage meter (optional)
    • Electrical tape (optional)
    1. 1
      Locate a hole at or close to the desired location of the
      switch, or drill one yourself, making sure it is big enough for the
      toggle switch to mount into. Be mindful of what is behind where you are
      drilling, so you don't short out existing wiring or go through other
      important components.
    2. 2
      Route the wire to be used through the back of the hole,
      coming out to the switch side, with the terminal connectors already on
      it. Connect the wire that is to be the hot, or power supply wire to the
      appropriate prong. On many toggle switches the positive side will be
      bigger, requiring a bigger connector. Do the same with the negative
      side. Connecting these before the switch is mounted negates the need to
      fight with them in hard to reach places.
    3. 3
      Mount the switch into the hole using the supplied nut, which
      is normally a round, ring type sealer that screws onto the threaded,
      male end of the toggle switch. Do your best to make this very snug,
      because it may be hard to get to at a later date, and also because
      allowing the switch to wobble in the hole may cause a dangerous short.
    4. 4
      Connect the power wire to the battery or a fuse block, making
      sure the fuses used are the correct amperage for the application.
      Using the middle outlet on the toggle switch, connect a wire to the
      accessory to be used such as lights, an amp, a horn or a cooling fan.
      Connect the ground wire to the negative side of the battery, or any
      available good ground such as screws to the chassis, the frame or
      sometimes the ground to another accessory.
    5. 5
      Test the circuit. When the switch is off, there should be no
      activity from the accessory, and if tested with a voltage meter, it
      should read zero at the accessory. When the switch is flipped on, it
      completes the connection, allowing current to flow from the positive
      wire to the accessory, activating it.
    Tips & Warnings
    • When
      drilling a hole for the toggle switch, consider starting with a smaller
      bit and making a "pilot hole," to ease the drilling of a larger hole.
    • Route
      the wires carefully; stay away from extremely hot places and sharp
      places as well, which could cut the wire and cause a short.
    • If
      routing the power wire directly to the battery, include an in-line fuse
      to ensure safety and prevent fires or the destruction of switch or
      accessory.
    • If a wire passes through a hole in the body, for instance, install a grommet or heavily tape the wire with electrical tape.
    • A two-prong switch simply gives or cuts power to something; a three-prong one is for external accessories.
Why is rear stock subwoofer not working?
I need to have more info about how you installed it, did you use rca wires from the radio to the amp.? Make sure the sub setting on radio is turned on. Make sure rca wire are in the input connection and not output, also check you connection from radio that they're in rite place. I really need more info about the map of your wireing
May 10, 2014 | 1998 Ford Expedition
I have a stock stereo and two subs with an amp in the trunk. Also two alpine speakers in the rear. Whenever I turn my balance to the left my subs don't play. What's wrong?
Hello.... I am sorry to hear you are having problems. The reason for this is that since you have a stock stereo, the shop (or person) whom installed the amp and subs used a line out converter. What this part does is allows the connection of RCA cables to the factory head unit. Almost all bass signals are always in stereo, so since you were only hooking an amplifier for just subs, you can actually just connect to just one of the rear speakers instead of connecting to the right and left. Just makes the install a little quicker. There is nothing wrong with this as I usually do the same thing in our shop. However, if you are going to be using the balance control, then you will need to go back to the shop and have them hook the converter up in stereo (to both rear speakers). Hope this helps!
20 year car audio/video installer
Bay manager
Mar 15, 2011 | Alpine Car Audio & Video
Does a 2002 acura tl factory radio have rca jacks behind the unit
No, but you can easily add a line output converter to your system, I do recommend spending a few extra bucks on one with a built in line driver, so you can bet a much better signal, but if you only plan on running one amp either one will be fine..
Aug 20, 2009 | Acura Tl 2002 Stereo/radio Dash...
Have stock radio # F75F-19B131-AA its in a 1998 F250 need to know how and if i can hook up one Amp for the two door speakers, and if i can hook up an additional Amp for some subs. Ofcourse if radio can do...
You will need a line level converter for starters (takes speaker level signal and converts it to line level/RCA signal) you connect this to the speaker left/right wires and it has a RCA left right on other end to connect and run to your amps, (you need this box because factory radios don't have RCA outputs on them) At that point all you have to do next is run the power/gnd/rem for your amp and then speaker wires to your front/rear speaker and then sub (if using). You can use one of these converters for your front/back speakers so you will still have use of your front/back/left/right fading options. make sure you disconnect th factory plug/harness at each speaker since the amp will be powering them and you will run speaker wires to each speaker. If you only want one converter it will be on your front channel and your sub will be power by the front. (you will fade to front for more/less sub bass unless your amp has a separate volume/bass control). If you want your sub to fade with rear speakers you will need to install another converter off of the rear speakers. Found a site with some photos that may help you with your project.
http://www.redlineforums.com/forums/howto-section/15003-how-sub-stereo-amp-install-factory.html
Aug 18, 2009 | Car Audio & Video
Do not have a sub output on receiver /do not know which wire to plug into the amp sub input/5 channel amp /have rca output for front and rear speakers
Hello southernbike,
With a 5-channel amp (stereo L/R front, stereo L/R rear, and subwoofer) you only need the two pair of stereo inputs.
You do not say which brand and model of amp you have, but most have an output configuration similar to the Alpine shown in this link. Connect the front and rear RCA's from your receiver, your vehicle speakers to the respective output terminals, and your subwoofer to the 5th channel terminals.
Hope this helps.
Jul 29, 2009 | Dual Car Audio & Video
Installing self amplified sub to factory stereo
Hello Jax GS300,
Yes, you can use RCA cables. Just wire in a "low-level" converter.
Using RCA's is really the best way, allowing you to run shielded wiring to the sub, making it less likely that the wiring will pick up electrical interference. I'd install the converter on the rear speaker wires behind the dash.
If you do not want to convert the speaker output, you can drive the Kenwood directly from the speaker wires. The diagram in the install manual shows the connections coming off the rear speakers.
Here's a link to one output converter. This one will convert all 4 speakers.
http://www.crutchfield.com/p_142SLC4/Scosche-SLC4.html?search=level+converter
Hope this helps.
Apr 09, 2009 | Kenwood KSC-WD250 Car Subwoofer
Subwoofer istalation into a clarion DXZ375MP stereo
The DXZ375 has two sets of RCA outputs (1 red plug, 1 white plug) located on the back of the unit. The set with the white main wire is for a front amplifier, and the one with the black main wire is the rear. You want the black one.
I'm assuming you also have an amplifier for your subs and the necessary wiring. You will need to run a 12v+ from the battery to the amplifier, splice a power-on signal wire from the ACC Power wire on the stereo's wiring harness (red wire) as well as connect the amp to the stereo via the RCA outputs.
Mar 11, 2009 | Clarion DXZ375MP CD Player
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    Car Audio & Video Logo
    244 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
