Question about Minolta Office Equipment & Supplies
I AM BUING THE KONICA C220 /C452 PRINTER - Minolta Office Equipment & Supplies
  • Minolta Master
  • 6,161 Answers
Yes sir/mam what is wrong?
Posted on Mar 01, 2015
3 Suggested Answers
  • 132 Answers
SOURCE: I have a Konica Minolta
Toler leak from yellow cartrigde. Change cartridge and carefully clean paper path.
Posted on Nov 13, 2010
  • 24 Answers
SOURCE: there is an error code
Abnormally high toner density detected Black TRC sensor-
1. Correct the TRC Connection on the underside of the imaging unit if faulty
2. Reinstall black image unit
3. Change image unit
4. Change PWB-M
5. Change PWB-MFP
you can try # 2 then run 20-30 sky shops (copies with lid up to make black copies) put a white piece of paper over lead edge section of copy glass so you are only making 1/2 black copies if you don't the copy may jam in the fuser due to excess toner. after running copies turn machine off for 10 secs to reset and power backon. if problem continues I would change the image unit.
Posted on Aug 21, 2011
After changing my bizhub C452 developer the machine refuse to print what is the solution?
You do not change developer in that machine you replace the entire developer unit
Mar 16, 2017 | Konica Minolta Bizhub C452 Color Copier,...
Tip
Problem in turning on the konica c452
i have konika c452, after a while it doesn't turning on , service man check all the boards but it wasn't enough . please help me to find a soloution
on Feb 26, 2014 | Konica Minolta Bizhub C452 Copier
Nvram.flash KONICA MINOLTA c452
Will need to get a tech out, as the NVRAM holds Proprietary Software and or the firmware needs to be flashed. all held on a secure web site at Konica Minolta.
Apr 16, 2016 | Konica Minolta Office Equipment & Supplies
I have Konica c220 a maassage : replace the Drum unit Black. There no broblem in print quality so how it reset
you replace the image unit when asking for a new one do so if not it will cause problem when you need the machine most
Feb 19, 2015 | Konica Minolta Bizhub C220 Color...
How to clear the display error on konica minolta c452
Sir there is a lever in the rear of the machine when you lift the document feeder it is not jam or broke, also there is a small magnet and sensor in the front of the Doc feeder right side and the copier it self ensure the document feeder is properly aligned. Does this happen on the document feeder or on the big glass? Also mite want to have a technician run alignment & tray adjustment.
Dec 06, 2014 | Konica Minolta Bizhub C452 Color Copier,...
Error c-3425 on bizhub c452
hi
in table number vg blak unit image is 914
i replase unit image blak developing tank
please help me
Nov 15, 2012 | Konica Minolta Bizhub C452 Color Copier,...
Konica Minolta bizhub c452 makes clicking / ticking noise. also has color streaking.
The ticking noise your hearing is VERY common on the C452, C552 & C652 models. Normally it is accompanied by a slight squeak that will get worse as well. There are numerous articles that cover this but the ticking is either coming from the fuser drive assembly (just inside the right hand door on the right below the exit drive assembly) or the exit drive assembly itself. If your mechanically inclined the problem can be found with one of the gears being worn on the shaft it turns on and becoming oblong. You will need to contact a service tech or dealer for parts since you can only get them from Konica. I hope this helps!
Sep 14, 2012 | Konica Minolta Bizhub C452 Copier
Error code EA3226 when I try to scan to e mail on Konica Bizhub C220
this error code is not listed in any of the konica c220 books or on the konica minolta service tech internet site
Nov 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
88 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
