Question about Hamilton Beach 80355 Custom Grind Coffee Grinder
Grind button seems to be stuck - Hamilton Beach 80355 Custom Grind Coffee Grinder
Machine grinds and grinds but never brews
Want serial number and activation code of mavis beacon deluxe 17
Dec 09, 2013 | Saeco Vienna De Luxe Espresso Machine
Hotpoint HCM15 - grinding but not dispensing coffee.
When my grinder does this it is usually a Hard Bean stuck in the grinding wheels. I adjust the grind setting to min and max and it normally clears.
Nov 21, 2013 | Coffee Makers & Espresso Machines
My brakes are grinding and even when im not pressing the brake petal i hear a grinding noise..
That's probably why the caliper may be hanging Si the pad or what's left of it will remain in contact rather than retracting.
Jun 18, 2012 | 1995 Oldsmobile Cutlass Supreme
My Saeco Magic Deluxe machine just stopped grinding. Everything else seems to be working just fine. I'm assuming it's mechanical and something simply broke but want to ask first and if something broke...
Does it sound like it is trying to grind or is it silent? Listen carefully after pressing the coffee button. If it is silent then the motor has most likely died or the thermal fuse on the motor has blown due to motor overload and overheating.
If you can hear a faint humming, then the grinder may just be blocked (or the dosing chamber located between grinder and brew unit (above brew unit) may be blocked). First try backing off the grind to the coarsest setting. Even if you can't hear the motor, it is worth backing off the grind anyway (easy to do) as you may be lucky. To clear doser, remove brew unit and look up. You shold see a curved trap door like thing that you can swing up to release or poke out stuck ground coffee.
If the machine instantly makes that 'tuka tuka' sound after hitting the coffee button (like it does when it is dumping the coffee after grinding) then the flap or micro switch in the dosing chamber is stuck. Move the dose (grind quantity) adjustment lever back and forth a few times.
If these suggestions don't help then take it to an authorised or expert repairer.
Dec 11, 2010 | Saeco Magic De Luxe Espresso Machine
Stuck with this problem
The front axle isnt disengaging completely. You need to probably replace the vaccum solinoid located right above your distributor on the firewall. To test you simply disconnect the two vaccum lines and splice them together. Then turn the 4wd on and see if all is normal.
Mar 16, 2010 | Chevrolet Blazer Cars & Trucks
Grind Off light blinking
Mine was doing that for the past week. I think it was indicating there had been a power outage but that the clock had not reset to zeros. I changed the time a couple of minutes and it stopped.
Sep 24, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Grinding noice when printing
Most likely problem is the Fixer Gear, seems to be an issue with these printers. Part number is LJ7416001 but does not look to be the easiest to Replace
Apr 29, 2009 | Brother HL 5170DN Laser Printer
Door that opens the filter basket gets stuck!!
I bought one at a thrift store for $8.00 and it had the same problem. All I did was put some cooking vegetable oil on the open basket door where it stuck, using a q-tip. It has worked great for over a year now.
gramma5
Feb 22, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Stuck grinder
make sure you not get any damp into the grinder. If you have damp in the grinder then it do not grind the beans.
/Mirran
Aug 30, 2008 | Saeco Incanto Classic Espresso Machine
Hamilton Beach 80355 Custom Grind Coffee Grinder Logo
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
80stech
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
