Question about Milwaukee Tool Milwaukee 1/2" D - Handle Drill 0 - 600 Rpm - 1001 - 1
How do you remove spindle from front gear housing ?
  • 7,733 Answers
How to gear spindle from housing
The unit is retained by two or three screws surrounding a retaining ring on the saw blade side, and I believe there are some screws holding the gear housing on the motor side that need to be removed as well. I just replaced the bearing on mine a week ago, and even though the situation is obvious once you figure it out I was not smart enough to do so, and wasted an hour trying to figure out how to remove that retaining ring over the bearing. Good luck
Apr 05, 2013 | Makita 5007MG Factory Reconditioned 7 14...
Replacing the gear on makita angle grinder
Are you replacing both gears? The armature gear (pinion) is usually held on with a nut or else is pressed on. The spindle gear is also pressed on. Most spindle gears will come as an assembly with the gear and spindle and housing all together.
If yours doesn't, then the spindle will need to be pressed out of the housing, and then the gear pressed off of the spindle. (Always replace the grease as well when replacing gears.)
Mar 31, 2012 | Makita Saws
How to replace a front wheel bearing
You'll need to remove the wheel, seperate the tierod end from the wheel spindle, remove the cailper and carrier from the wheel spindle, remove the axlenut, and unbolt the 2 bolts holding the spindle to the strut housing. You need to press out the wheel hub and remove the clips on either side of the bearing and press out the bearing from the spindle.
May 02, 2010 | 1996 Volkswagen Golf
Milwaukee Polisher model 5460. Gear Case Replacement
you need to remove the pad first and then you will find 2 torx screws about a 25, remove them and the plate next if you have a dead blow hammer tap on the side of the gearcase where the screws were and the spindle assembly and bearings will jump out of the housing, then remove the 4 screws holding the gearcase to the motor housing and it will come apart. To reinsert the spindle assembly gently tap back into place with the hammer to reset the gears. Let me know if you need more assistance.
Nov 25, 2009 | Milwaukee Tool Milwaukee 5460 - 6 7/9"...
How to change the power steering on 96 ford explorer
Section 11-02C: Steering Gear, Power Rack and Pinion, Explorer 1996 Explorer with Power Rack and Pinion Steering Workshop Manual REMOVAL AND INSTALLATION Steering Gear SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Pitman Arm Puller T64P-3590-F
Removal
  1. Start engine.
  1. Rotate steering wheel from lock-to-lock (entire gear travel). Record n umber of rotations.
  1. Divide the number of rotations by two. This gives the required number of turns to place system in the on-center position.
  1. NOTE: Verify the front wheels and steering wheel are in the straight-ahead position.
    From the lock position, rotate steering wheel the number of turns determined in Step 3. This places the gear in the on-center position.
    Steering Gear, Explorer
  1. NOTE: Do not rotate steering column when intermediate shaft is disconnected or DAMAGE TO CLOCKSPRING will result.
    Remove bolt retaining the lower steering column shaft to the steering gear input shaft.
  1. Disconnect the lower steering column shaft from the steering gear.
  1. Remove stabilizer bar attachment from frame for clearance to remove gear.
  1. Unscrew the quick connect fittings for the power steering pressure hose (3A719) and power steering return hoses (3A713) at the steering gear housing (3548).
    Power Steering Hose Connections
    Item Part Number Description 1 3A674 Power Steering Pump 2 3A719 Power Steering Pressure Hose 3 3F780 Power Steering Cooler and Hose Assembly 4 3504 Steering Gear 5 5005 Frame
  1. Plug ends of fluid lines removed and ports in gear to prevent damage and entry of dirt.
  1. Remove two (2) nuts from P/S cooler.
  1. Remove P/S cooler from vehicle.
  1. Remove and discard the cotter pin retaining the nut to tie rod end (3A130) and remove nut.
  1. Separate tie rod ends from front wheel spindle (3105) using Pitman Arm Puller T64P-3590-F.
  1. Remove the two nuts, bolts, and washer assemblies retaining steering gear (3504) to front crossmember (5019).
  1. Remove steering gear from vehicle. If required, remove steering gear mounting bracket housing insulators (3F640) and steering gear insulators (3C716) from steering gear housing.
    Item Part Number Description 1 N807881-S60 Bolt 2 385935-S36 Washer 3 3F640 Steering Gear Mounting Housing Insulator 4 3504 Steering Gear 5 N800255-S60 Nut 6 5019 Front Crossmember 7 3C716 Steering Gear Insulator
Installation
  1. If removed, install steering gear mounting insulators into the steering gear housing.
  1. Push the steering gear mounting insulator and steering gear insulator in until there is no space between the lip on the insulator and steering gear housing.
  1. Position steering gear on front crossmember. Install nuts, bolts and washers retaining steering gear to front crossmember. Tighten to 128-172 Nm (94-127 lb-ft).
  1. Position power steering cooler onto bolts and install nuts. Tighten nuts to 68-92 Nm (50-68 lb-ft).
  1. NOTE: The fittings design allows the power steering pressure hose and power steering return hose to swivel when properly tightened. Do not attempt to eliminate looseness by overtightening, since this can cause damage to fittings.
    Connect power steering pressure hose and power steering return hose to appropriate ports on steering gear housing. Tighten fittings to 27-34 Nm (20-25 lb-ft).
  1. NOTE: Make sure the tie rod ends (3A131) are seated in the tapered spindle holes to prevent rotation while tightening nut.
    With the steering gear, steering wheel (3600) and wheel (1007) in the on-center position, attach the tie rod end to front wheel spindle and tighten to 56-76 Nm (77-103 lb-ft).
  1. If necessary, advance tie rod nuts to the next slot. Install cotter pins.
  1. NOTE: Verify that no rotation from the on-center position has occurred.
    Position steering column lower intermediate shaft over steering gear input shaft. Outer input shaft dust shield must be in place. Replace pinch bolt and tighten to 41-56 Nm (30-42 lb-ft).
  1. Replace the front wheel and tire assemblies. Refer to Section 04-04 .
  1. Replace wheel covers.
  1. Lower vehicle.
  1. Refill power steering oil reservoir (3A697) with Premium Power Steering Fluid E6AZ-19582-AA or equivalent meeting Ford specification ESW-M2C33-F.
  1. Purge air from steering system. Refer to Section 11-00 . Verify absence of any unusual power steering noise.
  1. Check and adjust toe alignment specifications. Refer to Section 04-00 .
  1. Make sure steering gear operates correctly and is not leaking.
  1. Check and adjust fluid level in power steering oil reservoir.
Jul 10, 2009 | 1998 Mercury Villager
Bosch Random Orbitol Sander - model 1370 DEVS. Could you please tell me how to remove the vertical spindle(part # 3 603-523014. After removing the C clip does the fan unscrew or is it fasten by friction...
After the snap ring is removed you must put it in a press and press the spindle out of the housing. The gear is very tight because there are no keys, it is held on sticktly by the interference between the shaft and the spindle
Jul 08, 2009 | Bosch Tools & Hardware - Others
How to change inner tie rod ends?
if fluid is flowing out the bellows, you need to replace the steering rack assembly. There is no fluid in the area of the inner tie rod. The seal is just before the tie rod.
Steering Gear
The power rack and pinion steering gear is serviced as a power steering short rack (3L547). The front wheel spindle tie rods (3280) and tie rod ends (3A130) are serviced individually. -------------------------------------------------------------------------------------------
  • The power rack and pinion steering gear incorporates quick connect fittings for the power steering pressure hose (3A719) and power steering return hose (3A713) that allow the lines to swivel. This is normal and does not indicate loose fittings.
  • If the fittings leak, check to make sure they are tightened to 14-20 Nm (10-14 lb-ft). Do not overtighten.
  • If the leak is not corrected, replace the fitting seals.
Section 11-02: Steering System, Power 1997 Windstar Workshop Manual
REMOVAL AND INSTALLATION Tie Rod End Steering Gear Installed
Removal
  1. Remove and discard cotter pin and nut from worn tie rod end (3A130).
  1. Disconnect tie rod end from front wheel knuckle (3K185), using Tie Rod End Remover TOOL-3290-D or equivalent.
  1. Hold tie rod end with a wrench and loosen tie rod end jam nut.
  1. Note depth to which tie rod end was located by using the jam nut as a marker. Grip tie rod end with a pair of suitable pliers and remove tie rod end from front wheel spindle tie rod (3280).
REMOVAL AND INSTALLATION Steering Gear Removal
  1. Raise vehicle on a twin post hoist and remove wheel and tire assemblies. Refer to Section 00-02 .
  1. Support vehicle with jackstands under front jack pads.
  1. Remove tie-rod end cotter pins and nuts and remove tie rod ends (3A130) from front wheel knuckle (3K185). Refer to Section 04-01 .
  1. Remove front stabilizer bar (5482). Refer to Section 04-01 .
  1. Disconnect heated oxygen and catalyst monitor sensors.
  1. Support flex pipe.
  1. Remove bolts and disconnect flex pipe from the converter.
  1. Raise dash opening steering column opening weather seal (3513) (secondary) above the steering gear housing (3548).
  1. Remove pinch bolt retaining steering column intermediate shaft coupling (3A525) to power steering gear input shaft and control (3D517) and disconnect the shaft.
  1. Remove nuts from steering gear-to-front subframe retaining bolts. Remove bolts.
  1. Remove rear subframe-to-body retaining bolts.
  1. Lower twin post hoist carefully until rear of subframe (5R003) separates from body, approximately four inches.
  1. Remove heat shield band and fold shield down.
  1. Rotate power rack and pinion steering gear to clear bolts from front subframe (5C145) and pull left to facilitate line fitting removal.
  1. Place a drain pan under vehicle and remove line fittings.
  1. Remove power rack and pinion steering gear through LH wheel well.
  1. Remove and discard the O-rings.
Installation
  1. Install new Teflon® O-rings on line fittings as outlined.
  1. Place steering gear retaining bolts in steering gear housing.
  1. Install power rack and pinion steering gear through LH wheel well.
  1. Install power steering line fittings to power rack and pinion steering gear.
  1. Position power rack and pinion steering gear into front subframe.
  1. Install ******** heat shield.
  1. Install tie-rod ends to front wheel knuckle. Install nuts and new cotter pins. Refer to Section 04-01 .
  1. Install LH front stabilizer bar. Refer to Section 04-01 .
  1. Install steering gear to subframe mounting nuts. Tighten to 115-135 Nm (85-99 lb-ft).
  1. Raise hoist until rear subframe contacts body.
  1. Install rear subframe to body retaining bolts. Tighten to 113-153 Nm (83-112 lb-ft).
  1. Install exhaust system flex tube to dual converter Y pipe (5F250) and remove flex tube support.
  1. Connect heated oxygen and catalyst monitor sensors.
  1. Install tire and wheel assemblies. Tighten lug nuts (1012) to 115-142 Nm (85-104 lb-ft).
  1. Using a new pinch bolt, install the steering column intermediate shaft coupling on the power steering gear input shaft and control and the lower steering column shaft. Tighten the pinch bolt to 34-46 Nm (25-33 lb-ft).
  1. Position steering column opening weather seal (secondary) over the steering gear housing. Tighten nuts to 4.5-6.3 Nm (40-55 lb-in).
  1. Remove jackstands and lower vehicle.
  1. Fill power steering oil reservoir (3A697) with Premium Power Steering Fluid E6AZ-19582-AA or equivalent meeting Ford specification ESW-M2C33-F. Refer to Section 11-00 .
  1. Check system for leaks and proper operation.
Apr 15, 2009 | 1997 Ford Windstar
How do i change inner tie rod , do i need a special tool.
i think steering gear has to be removed to get rubber bellows off to access tie rod.
486d579.gif Section 11-02: Steering System, Power 1997 Continental Workshop Manual
DISASSEMBLY AND ASSEMBLY Tie Rod and Bellows SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Bench Mounted Holding Fixture T57L-500-B
Disassembly
  1. NOTE: Drill out mounting holes in holding fixture with a 9/16 inch drill to allow the power rack and pinion steering gear assembly mounting bolts to fit.
    Mount power rack and pinion steering gear assembly in Bench Mounted Holding Fixture T57L-500-B.
  1. Remove tie rod ends (3A130).
  1. sve~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care not to damage bellows. If bellows are damaged, this will allow contamination into the steering gear and cause leakage.
    Remove four clamps retaining bellows to steering gear housing (3548) and front wheel spindle tie rods (3280). Discard clamps if damaged or excessively corroded.
  1. NOTE: Steering gear does not use rivets or roll pins between the inner front wheel spindle tie rod and rack.
    Remove bellows along with power steering gear rack tube (3K762).
  1. Position power rack and pinion steering gear so that several steering gear teeth are exposed. Hold steering gear sector shaft (3575) with an adjustable wrench on end teeth only while loosening ball joint nuts.
Assembly
  1. Expose several steering gear teeth and hold steering gear with adjustable wrench.
  1. Tighten each front wheel spindle tie rod separately to 90-110 Nm (67-81 lb-ft).
  1. Thoroughly clean steering gear and steering gear housing bore of any foreign material. Any abrasive material is extremely harmful to high-pressure oil seals.
  1. Apply Steering Gear Grease C3AZ-19578-A or equivalent meeting Ford specification ESW-M1C87-A to groove in front wheel spindle tie rod where tie rod bellows clamp to front wheel spindle tie rod and uniformly to inner diameter of tie rod bellows before installation. This allows for toe-in adjustment without twisting tie rod bellows.
  1. Install tie rod bellows and power steering gear rack tube. Make sure power steering gear rack tube is positioned as shown.
    Power Steering Gear Rack Tube and Tie Rod Bellows Installation
Apr 04, 2009 | 1997 Lincoln Continental
My tall Cinni standard fan isn't working. When you switch it on you can hear the motor trying, but the fan blades don't move at all. It's boiling today in my office, so we'd like to know what might be up...
Stage 1: unscrew 2No. top and bottom nut/bolt put to one side, lift 4No. hinge clips and remove front cage.
Stage 2: partially unscrew spindle screw on fan body then slide fan off spindle.
Stage 3: plug in fan turn to setting '1' (lowest setting, the motor will hum but not rotate) now with a hammer 'carefully' tap the spindle so that it is aligned within the housing, it may need to lo left, right, up, down whatever direction it needs to sit centrally withing the bushes of the front and rear housings. Then tap the end of the spindle which sometimes re-engages/realigns the spindle within the rear bush.
Stage 4: reverse of stage 2 & 1
Good luck
Jul 01, 2008 | Heating & Cooling
Beaters Misaligned
If this is one of the later-model Sunbeams, the housing has an upper half and a lower half. By removing the upper half, you can see the motor and the gear train. You will have to take out one of the beater gear posts and reinsert it to align properly. I suggest you look at both gear posts and check for worn or broken teeth. In which case, you will need to replace the bad part[s].
Older model Sunbeams have a gearbox housing that mounts onto the front of the motor housing. When you remove the gearbox housing, you will see the gear posts inside. Check for worn or broken teeth and replace as necessary. To insure proper alignment when reattaching the gearbox housing, align the two gears relative to each other then push the gearbox housing back onto the motor housing. The motor spindle will slightly turn both gearposts simutaneously during this process but will keep the proper alignment. You may have to repeat this process a number of times until you get it right.
Feb 02, 2008 | Sunbeam 2350 Heritage Series Mixer
Milwaukee Tool Milwaukee 1/2" D - Handle Drill 0 - 600 Rpm - 1001 - 1 Logo
108 people viewed this question
Top Milwaukee Tool Drills Experts
Mike
andrew-loeb
Level 1 Expert
Are you a Milwaukee Tool Drill Expert? Answer questions, earn points and help others
