Question about Refrigerators
My Frigidaire side by side icemakeer and water dispenser was not working. I took out a contract with a local company. They diagnosed the problem as needed a new circuit board. They wanted $224.00 to fix. I ordered the part (I installed once before) and replaced the circuit board. I took the plastic connector and ran between the new circuit board and other circuit board in door. I'm not getting any lights on the door panel? I don't understand why there's no juice to the panel?
  • erskinea Dec 21, 2008
    the refridgerator is not dispensing water nor ice.
  • 473 Answers
SOURCE: Water Dispenser Drips
A common problem I see is people have the wrong kind of saddle valve on their water line. Make sure you don't have a self-piercing saddle valve. You should have a drill type saddle valve on the cold water line. Reason why, not enough water pressure to the water valve on the fridge. This will let the valve on the fridge hang slightly open which will cause a drip. Check this first. You will find info on this in the installation section of your owners manual.
Posted on Oct 05, 2007
  • 473 Answers
SOURCE: when icemaker is filling water comes out door dispenser
I need the entire model # from the sticker inside the fridge section. My guess is this is the model that has a diode in the wiring harness that directs power to the valves and has gone bad letting power go to both valves. I would look and see if you also have water going into the icemaker when you press for water out of the dispenser. If there is no diode then the water valve is bad. I need the model # so I can look at a wiring diagram. You can look at the wiring to the water valve and see if it has a diode. It is black block and has two wires in one end and one out the other. If so the diode only can be bought and spliced in. Let me know so I can help.
Posted on Nov 03, 2007
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
SOURCE: icemaker only dispenses crushed ice, not cubes
yea! I have been without cubes for 2 years. I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck. I am soooo happy!
Posted on Aug 10, 2008
  • 3 Answers
I had a problem with my icemaker not drawing water or making ice, I did a full defrosting of my freezer taking everything out leaving the door open for about 1.5 hours It appeared that the inlet water supply had an ice blockace up in the water outlet, defrosting it cured the problem, it has been workinf fine for the last day tub is full of ice!!
Posted on Jan 29, 2009
My 7-button Frigidaire Gallery ice/water module is not lighting up and not functioning. No ice or water is being dispensed. Wiring harnesses seem to be all intact.
If freezer door switch is not working, dispenser won't work. Does the freezer light go off & on when door is opened & closed? If you have a voltmeter, check that water valve is getting 120 volts when dispenser is pushed in. If no voltage, I would suspect the micro-switch that you hear clicking when you push in with a glass. Even though it clicks, the contacts could still be bad in it. However other than that loose/off wire, ribbon cable for front buttons off/loose, bad board, child lock are something that can make the dispenser dead.
Please check the bellow link if it helps:-
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Mar 29, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire FRS24ZRHW0 Icemaker/Water Dispenser problem
See if your water solenoid might be the problem. Your water supply line from the house will connect into a solenoid. I just recently solved a problem for someone on this site who had a solenoid that was sticking. Try tapping the solenoid gently to get it to activate or take it apart and depending on what type it is, manually move the spring loaded plunger a few times.
Hope this helps
Feb 25, 2010 | Refrigerators
Loud ticking noise when i close freezer and lights on icemaker flash like a stobe light. fridge and freezer wont hold temp. ice amker and water dispenser dont work?
if your lights burned out recently and the digital temp read-out is now dark also,burned out lights will cause a power surge and will destroy the main-board circuit trace(mother-board), it is located in the back side of the refrigerator, in a small plastic case,when you remove it you will see a burned spot on the circuit board and the loud clicking sound is a relay on the board trying to latch to light the bulbs and operate the unit
Feb 21, 2010 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS26ZSH -ice & water dispenser panel lost power
I think you will need to unplug the pin plug under the cover at top or bottom hinge. Check the voltage and if OK leave unplugged until you can remove the dispenser and I will try to help you from the power source. Sounds like a short in the board and related to the light socket. The fuse only stopped the short from doing further damage, You may need to locate the short before replacing the fuse or board. I have looked over the wiring diagram. If you find the short without my help just be sure to replace the fuse with the correct size. The only things are the chute heater or something in that area of the board went to ground. Do you have a voltage meter? Contact me later when ready, Sea Breeze
Jan 20, 2010 | Frigidaire FRS3R5EMB Side by Side...
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire ice maker not working
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Aug 11, 2009 | Frigidaire FRS6R5EMB Side by Side...
Water dispensing by itself without anyone touching the dispenser!
Reverse the wires you took off the solenoid, I think you have the icemaker wires on the water disp side and the water disp on the icemaker
Feb 28, 2009 | Frigidaire Refrigerators
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
10 yr old Frigidaire ice maker stopped making ice
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Oct 30, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
222 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
