Question about Sharper Image Ionic Breeze GP SI730 Air Purifier
Sharper image Ionic Breeze germicidal protection, professional series
The unit does not come "on" when plugged to the outlet. It has been regularly cleaned, both the removable collection grid as well as the grills. Have even changed the UV lamp. Never made any noise, but now does not come "on". A similar unit bought at the same time is working fine. Sharper Image is in liquidation and they are unable to provide any help. Can someone advise me as what should I do, short of dumping it. I purchased these units in 2004.
Raj Bhalla
email: rajbhalla@aol.com
  • 2 more comments
  • Bhalamanas Jun 16, 2008
    Unit plugged directly to the wall outlet
    I am a lay person, please advise how to access the "ON" switch that should be rewired. A little step by step instruction will be greatly appreciated.
  • Bhalamanas Jun 17, 2008
    Cleaned the back grill latch and the contacts, but it did not help, The ionic breeze still does not come ON when plugged.
  • Bhalamanas Jun 19, 2008
    Is there a repair place where I can send this ionic breeze air purifier for repairs? Thanks
    Sergeant:
    Champion:
  • 310 Answers
Check the power supply of ur board
Posted on Jun 16, 2008
  • khader ibrahim Jun 16, 2008
    Power supply is coming from wall outlet....no power supply means replace the wall outlet.....or try it in other wall outlet...
    Guru:
  • 1,894 Answers
Hello
if it does not come ON then there must be some problem in power board
is the green light glowing?
  • dewan nafees ahmed Jun 16, 2008
    because if the green light is glowing and remaining unit is not getting turned On means it can be a different issue.
    so please provide me us a detailed reply of what is happening
    that can help us serve u better
    Master:
  • 555 Answers
Is it plugged directly into wall power, or into a power strip?
  • Matt Jurach
    Matt Jurach Jun 16, 2008
    Some have found the power-on switch to be defective. The switch is constructed of two contacts on a printed circuit board. Over the years, the surface of the switch contacts became oxidized
    and no longer makes a connection when depressed. Rewire the switch andyour Ionic Air Cleaners should be
    working again.
  • Matt Jurach
    Try this step-by-step guide.
Hi, I have the ionic breeze germicidal air purifier floor model. One of the wires inside has broken. Can I get this fixed?. Thanks for any help you can give. Joyce Turner
Joyce, according to Sharper Image, if you purchased it online from Sharper Image after 2008, they will assist you with the repair. Call Customer Service 877-714-7444 . If that is not the case, you can either return it to the place of purchase for repair or take it to a small appliance repair shop,
Apr 21, 2011 | Sharper Image Ionic Breeze® Quadra® 4.0...
I need 2 new UV-C Germicidal Lamps for GP and GP Pro.
Hi.
Both Ionic Breeze purifier and replacement parts had been retired from the market because of health concerns related to ionic technology. Parts are sometimes available on ebay, but I suggest not carrying any repair on this unit.
Please read the brief article that I wrote here: http://www.fixya.com/support/r5303535-ionic_breeze_parts_repair
Sep 13, 2010 | Sharper Image Ionic Breeze GP SI730 Air...
I have 2 ionic breeze air purifiers sharper image.(germical )
I have the same problem as gerardperez7. One of my germicidal light quadras won't turn the light on and doesn't appear to be cleaning the air at all. I even put a new light bulb in it and it doesn't fix the problem.
Dec 19, 2009 | Sharper Image Professional Plus Ionic...
I need to replace the bulb for ionic breeze air purifier S1830
G15T8 15W 15 Watt UV Germicidal Bulb IONIC BREEZE GP
this bulb is available on ebay for under $11.00. The release tab for the cover is at the bottom of the cover and it comes off pretty easy. Once the cover is off you turn the lamp 1/4 turn (two clicks) and slide it from it's fixture.
Jul 01, 2009 | Sharper Image Professional Plus Ionic...
Where can I buy replacement grid for ionic breeze professional series model S1831?
Item number on ebay is: 220444965077
$10.99 plus around $5 to ship.
Pull up on the tab on the bottom of the front filter and pull up. You then should be looking at the bulb, which you will turn 1/4 turn (2 clicks). You should then be able to pull the bulb out.
Hope this was helpful.
Jun 10, 2009 | Sharper Image Professional Plus Ionic...
Ionic Breeze - Press Blue - Press Geen button
The blue means the germicidal lamp is operating. Re: green light - Normal operation at all power levels involves a pre-programmed cycle of altering high and low air movement. Press the the green to override the regular power control setting and run the unit at maximum power for five minutes. Your previously selected power level will resume after the five minutes has elapsed.
Dec 11, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Unit stopped working. Do you have a customer service number for the Ionic Breeze company? 2 units one stopped working checked outlet moved to different outlet still not working other had a wire inside...
The product is no longer supported because Sharper Image recalled the units after losing a lawsuit against Consumer Reports forcing them into Chapter 11.
There is a thread on this site with further details.
Sep 08, 2008 | Sharper Image Professional Plus Ionic...
I have a sharper image Ionic Breeze GP still under warranty. One of the blue lights on the Germicidal lamp is out and needs to be replaced. Where can I purchase this part, now that Sharper Image is no...
If the warranty you are counting on is a Sharper Image Warranty I need to advise you that it was voided in the buyout on 30 May, 2008 when everything at Sharper Image was liquidated by Hilco Consumer Capital, Gordon Brothers, and Bluestar Alliance. If however it was a warranty company outside of Sharper Image you need to contact them.
You can purchase a bulb for the GP on ebay for under $11, which is really a good price considering what you would have paid from Sharper Image. Installation is easy, you just pull up on the tab on the bottom of the filter and pull up. When you are looking at the bulb, turn it 1/4 turn, (2 clicks) and pull it out. That is all there is to it. Hope this helps you.
Aug 23, 2008 | Sharper Image Professional Plus Ionic...
I have the Ionic breeze Professional Series GP. It wont turn on...like its getting no power, but it is plugged in. It has no lights nothing!
Ionic Breeze is no longer being supported by Sharper Image. They did have a recall program on the product but I believe it has been discontinued.
The product was proven not to clean the air by Consumer Reports as well as EPA studies. Sharper Image tried to sue but lost.
Consumer Products Safety Commission is reviewing all ionizers and will make a decision by the end of the year. Due to health issues with using the machines themselves, these machines may disappear for good.
Aug 18, 2008 | Sharper Image Professional Plus Ionic...
Professional Series Ionic Breeze Tabletop
There isn't one. The reason why Sharper Image went out of business is because the Ionic Breeze was proven to be ineffective product and harmful to use in some cases based on Consumer Reports data as well as data from the EPA. They sued Consumer Reports, lost the case, and had to pay all the legal bills.
The Consumer Products Safety Commission is going to making decision on all ionizers by the end of the year. It's quite possible that no one will be selling them anymore.
There is thread I left in the Ionic Breeze section about the EPA data on ionizers and the harmful effects of using them as well as a link about what happen to Sharper Image.
This product should have been regulated a long time ago. Orek and few others are going to be pulling the plug on them real soon.
Jul 29, 2008 | Sharper Image Professional Plus Ionic...
Sharper Image Ionic Breeze GP SI730 Air Purifier Logo
179 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
