Question about RCA HD52W56 52" Rear Projection HDTV
Convergence is off and cant find it in the menu... just got the tv from a friend and didnt have the remote
    Genius:
  • 1,030 Answers
Sounds like the comm http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in on fl231 fuse problem. read this it might help
Posted on Nov 09, 2010
Cant aline green bulb using convergence menu
There are two or three convergence modules in the TV that have to be replaced. They solder to the circuit board. You can get these parts at shopjimmy's web site if you feel you can fix it yourself. Otherwise prepare to spend $400 plus parts to have a shop do it.
Nov 19, 2014 | JVC Av-56wp30 Iart Pro 56" Widescreen...
Colors are seperated on toshiba 50A61
Go into menu and with original remote call up convergence--either it has a problem(will not adjust) or you may with the remote be able to manually adjust the convergence back: sometimes if a power outage/surge it scrambles the convergence memory.
Aug 28, 2012 | Toshiba Televison & Video
Need to know to set the convergence
Have you tried going to the service menu?
Do this by holding "MENU" on the TV set while it is on, then pressing "Menu" on the remote. You may have to do this a couple times for the menu to appear.
There should be a option on the appearing screen for Convergence, which has more options the the standard menu. To work this under the "9" setting for convergence, each of the + on the screen is the corresponding button the the TV remote (3 if top right, 5 is center). Use your volume or arrow keys then to move the selected + in the desired direction.
Jun 17, 2010 | Zenith R40W46 40" Rear Projection...
Rca d52w27d no convergence in the set up menu cant run the convergence
some rca models have the convergence as a seperate button on the front or side of unit. sometimes if unit has guide plus+, unit wont have that option. try on your tv factory remote, with tv on, push menu, 7, 1, go back, tv. that is the code to reset your computer in tv.
Nov 14, 2009 | RCA Televison & Video
R56w36 convergence adjustment
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
Mar 13, 2009 | Zenith R56W36 56" Rear Projection...
Apex GB43HD10 Convergence
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 10, 2009 | Apex Digital GB43HD09 43" Rear Projection...
After replacing the convergence the three colors are still not aligned
there should be a menu button on the tv itself go to picture setting and reset all three colors to the middle. if that doesn't work then you'll need a new regulator for the convergance which is about 25-50 dollars
Oct 22, 2008 | Sony KP-57WS500 57" Rear Projection...
Projection lights
You need to take the Toshiba remote that came with the machine and go into a menu area that deals with convergence. Here's what the manual says:
This TV used 3 separate TV tubes, red, green, and blue. The R, G, and B images are pojected onto the screen wheree they converge to form a full-color picture. You can see a clear picture only when the three images converge correctly. Corvergence my drift over time, or if yo move the TV. I you can see clear images on your TV screen skip this procedure.
Make this adjustment only after the TV as been on for at least 30 minutes.
Press the TOUCH FOCUS (auto convergence) button on the front of the TV at the bottom.
The TV will enter into the convergence mode and adjust the converge automatically (that's what it says.)
TO ADJUST IT MANUALLY:
Press MENU, and the press < or > until the PICTURE menu appears.
Then press UP or DOWN to highlight CONVERGENCE.
Press < or > to display the Center Convergence menu
There's a lot more the book says, but, I can say from experience that you just go through the different sub areas of this menu and converge each color separately, and bingo, it's fixed.
Good luck.
Sep 06, 2008 | Toshiba 43H71 43" Rear Projection...
Samsung Tantus HCM 22 convergence problem
Check this website to buy the entire convergence amplifier board. Replacing the entire boars is a DIY since there isn't any soldering involve only open back cover of the TV and unplug a few wires to remove the old board and install the new one. Keep in mind that this board could be used or reburbished.
Samsung no longer has the assembly.
If you need more info let me know.
Aug 28, 2008 | Samsung HCM422W 42" Rear Projection...
Convergence without a remote control
you will need the origional remote you can get one fast through this link just enter the model number www.replacementremotes.com
its normal after an IC change for the convergence to need adjusting, universal remotes can sometimes do it, but i have only seen that happen once or twice usually they wont have the right feature to adjust then save the settings.
Mar 29, 2008 | Toshiba 43H70 43" Rear Projection...
RCA HD52W56 52" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
