Question about Uniden BC780XLT Base Scanner
I have a new in box BC780XLT scanner that I just purchased off of ebay. I may have discovered why it has never been used ! The volume is much to HIGH, and seems to have very little variation from all the way up to back down to the off posistion. I have tried hooking another speaker into the earphone jack, but the results were still the same. If I hook earphones into the jack and leave the earphones lying on the counter (not on ears) I can still hear the scanner at a much more desirable volume, without disturbing other members of the family in the house. I orrignally thought that it must be some computerized problem, that I could set with ease. Unfortunately I do not seem to find the solution to this problem. Thanks, for any assistance you may be able to provide me with to resolve this issue !Sincerely Richard
    President:
  • 2,761 Answers
The BC780XLT is a 2000 model, so your "new" scanner is actually about 10 years old. Your lack of volume control indicates that the ON/OFF/VOLUME control "pot" is defective and needs to be replaced. It looks to be on the same shaft as the SQUELCH, so the Uniden part is likely a combination of the two controls. I suggest that you contact Uniden Customer Service (see link below) and inquire about parts availability and/or factory repair. Due to the age of the unit though, there's a good chance that the control is no longer available -- unless it's being used on a newer model as well. Your other option is to try to work out a return or file an eBay/PayPal claim. Sorry to be the bearer of bad news.
http://mycusthelp.net/UNIDEN/_cs/QuestionAsk.aspx?sSessionID=&
Bill B.
Listening in since the 60's
Posted on Nov 09, 2010
Testimonial: "Thank You, Bill for your quick response to my BC780XLT scanner question ! Your opinion is much appreciated and helpful. The "OH NO BIRD" chit on me !!"
Can a bearcat bc780hlt be made digital?
Sorry, but there is no APCO-25 (digital) card/adapter available for your scanner. If all or some of your local services have switched to digital, you'll need to purchase a different scanner - such as the Uniden BCD996XT or the brand new Uniden HomePatrol-1.
Bill B.
Nov 08, 2010 | Uniden BC780XLT Base Scanner
Bearcat 780xlt firmware 1.19 need to update due to rebanding
Take a look at radioreference dot com. Search for similar problems, or join up and post your problem there.
Oct 11, 2010 | Uniden BC780XLT Base Scanner
How to reset my uniden 780xlt scanner
There is no "soft" reset for the BC780XLT, and the following "hard" reset will erase all programmed data and return the scanner to its original factory settings.
- Power the scanner OFF.
- Press and hold the 2, 9, and MANUAL keys and power the scanner ON.
Need the manual for your scanner? You can download/print it here:
http://www.uniden.com/pdf/BC780XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Jun 30, 2010 | Radio Communications
Just look for the hand book for my bc780hlt uniden scanner
You can download/print your scanner manual here:
For a comprehensive database of active frequencies in your area, visit:
Bill B
Apr 03, 2010 | Uniden BC780XLT Base Scanner
Where do I find a replacement power supply for my bc350 scanner?
The original power supply for your BC350C, Uniden part number AD-140U, has been discontinued, but you can purchase a new one by following this link to eBay:
http://cgi.ebay.com/New-Uniden-A-C-Adapter-Bearcat-Scanner-power-AD-140U_W0QQitemZ390088996359QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5ad31db607
Uniden has designated a replacement for the AC supply, but the new unit, part number BADG0845001, is backorderd. If you prefer to purchase this unit, you can place yourself on a waiting list by following this link:
http://www.unidendirect.com/itemlist.cfm?cattype=acc&catid=5
Dec 30, 2009 | Uniden BC350C Base Scanner
Need manual for bc780xlt
Most all manuals for Uniden scanners are available on line. Go to;
www.uniden.com
Sep 08, 2009 | Radio Communications
Manual
That model was the first prototype of the Uniden Bearcat Electra BC780XLT-PPKL88 otherwise known as the BC780XLT. That manual that you got for the XLT model should work just fine, the only difference is that the XLT has more features than the HLT. The HLT came with its own manual, but it wasn't very accurate either, just try to make due with the manual you've got. If you want a scanner that is easier to use, you should get a Regency Touch K500. The Touch K500 can scan up to the 900MHz range and has VHF/UHF/FM/AM/CB/WX/AIR scanning capabilities. It even comes pre-programmed with international channels. It also has an automatic Weather Alert Notifier Bank already programmed into its internal memory. In short, the K500 is the ultimate scanner. However it will be hard to find because Regency went out of business a while back.
Good Luck!
Jun 25, 2008 | Radio Communications
Getting stuck on trunked stations?
This is a digital trunk, you wont be able to pick these up on the bc780, it only does analog trunk systems. Some trunks use mixed analog/digital, if you can figure out which ID's are using digital you can lock them out. Even worse is the fact that the ID's you lock out are probably the ones that you are trying to monitor :(
May 10, 2008 | Uniden BC780XLT Base Scanner
Uniden BC780XLT Base Scanner Logo
205 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
