Question about Linksys WRT300N Wireless Router
My linksys router is frozen. The lights for ports 1-4 and the internet light is on solid. There is also a high pitched noise coming from the router. How do I reset it?
  • lornalynmd Nov 09, 2010
    Forgot to include: Pressing the reset button on the router and unplugging it from the outlet does not solve the problem. The router is still frozen.
  • 38 Answers
You can find a reset on the router. Press and hold it using a pen and release after 30 secs.
Posted on Nov 09, 2010
  • englishvalet Nov 09, 2010
    Can you ping the router? To ping it, connect a computer directly to it using a cable. Go to command prompt and type ping 192.168.1.1. If your get replies, there is a possibility that the router can be upgraded .
    If you want, I can walk you through the process, call me through skype or yahoo.
    Skype ID: english_valet
    Yahho ID: ronaoclarit
Need to connect Linsys to motorola modem for wi fi usage
  1. simply unplug the router and the modem from their power source
  2. plug the power cable into the modem
  3. wait for the lights to stop coming on, until you see solid power and internet connectivity LED and an intermittently blinking activity light.
  4. now plug the power to the router and allow it to boot all the way up as well.
  5. no your internet should be workin. (the ethernet cable should go from the LAN port on the modem to the Internet port on the rear of the router, and any desktops should be connected beginning with the LAN 1 port and advancing as required)
Jan 08, 2011 | Linksys Wireless-G WRT54G Router
Set up the router to new modonm
It should be simple to just plug the modem into the Internet (WAN) port on the Linksys Router. You should plug the line from the wall to the modem then the modem to the Linksys router. The router should "ask" the modem for an IP address. The modem should have lights on it. Make sure that the DSL or Internet net light is solid or at least flickering.
Sep 04, 2010 | Linksys Wireless-G Broadband Router
Why is my port lights and internet lights blinking no power light comes on at all?
If the indicator for the numbers and the internet are blinking like christmas lights, this indicates that might be a hardware problem on your linksys router. A working router should show solid green power light. You may still resolve this by upgrading the firmware of the router.
Jun 11, 2010 | Linksys WRT160N Wireless Router
Every time i turn power to router on i have to
Check your connection between modem and router.
Jun 23, 2009 | Linksys EtherFast Cable/DSL Router
Cannot connect to internet
best way to check if your ethernet is working (internet port) is by looping. get an ethernet cable, connect one end to either one of the local ports (1,2,3,4) at the back of the linksys router, the other end of that will then be connected to the Internet port or the WAN port. if the internet light goes on upfront, that will mean your internet port is working.
okay about making this work with your modem, it is still best if you start with ground zero on the router.
locate and press the reset button on the router for 20-25 seconds, then let it go, after so unplug the power, then plug it back in after 15 seconds.
once that is done follow these:
check your PC's IP.
XP
click start>run>CMD> then click "OK"
on the command prompt type in ipconfig then press "enter"
vista
click start(orb)>on start search type in CMD then press "enter"
if your IP address shows 192.168.1.xx (xx being a number from 2 to 253), you may close the window and proceed to the next step.
if your IP starts with 169.254.xx.xx please repeat resetting the device, then the power cycle.
okay so you got a good IP, follow these then.
1.open IE
2.on the address bar type http://192.168.1.1 then hit go
3.it will as you for a username and a password, leave the UN blank and the PW is admin, if that did not work try putting admin on both username and password.
when a linksys window shows up, you will see tabs like:
Setup
Wireless
Security
Applications and Gaming
Administrator
etc
on the "Setup" tab, look for a subtab that says "Mac Address Clone" then:
1. enable the clone service
2. click on the "clone your PCs MAC"
3. click on "Save Settings"
once saved, we do a power cycle including the modem.
1.turn the modem and the router off
2.after about 10 seconds, turn the mdoem and wait for the light infront of it to be stable. (like the "online" light should be solid)
3.once it is solid, turn the router back on, then let it sit there for about 15 seconds or modem until the power light is solid
once both devices are on, go back to your Linksys setup page, click on the status tab and you should be able to see an IP address on the internet section, once you have it, you're now online.
Jun 20, 2008 | Linksys Ultra RangePlus Wireless Routr...
Linksys box fell to the floor. The power and LAN lights are on, but the computer is not connecting.
no need to worry abt that...i think the router is back to the factory default setting....just follow these steps,ur issue will b resolved
U dint specify that whether u r using the cable Internet or DSL!!
Steps for Cable internet...
1,connect the blue cable between the computer and the router(any 1 of the 4 ports in the
router)
2,connect the other Ethernet cable between the Modem(came from ur internet people) and the
Router's Internet port(standalone port at the back of the router)
3,In the rear panel of the router u can see the reset button.with the help of the paper or
ball point pen,press it hardly and hold it for 1 minute..
4,Now turn off ur modem and the router..wait for other 1 minute..
5,turn onn only the modem first and wait till all the lights lit.now turn on the router and wait
till the power light is solid..open the internet Explorer it should work..
STeps for DSL Connection
1,connect the blue cable between the computer and the router(any 1 of the 4 ports in the router)
5,turn onn only the modem and wait till all the lights lit.now turn on the router and wait
6,open internet Explorer and in the address bar..enter as 192.168.1.1..it will prompt for a
user name and password..leave the user name blank and the password will be admin.
7,linksys set up page will open..there u can see local ip address which says 192.168.1.1.
please change it as 192.168.2.1..click on save settings at the bottom of the page..
it will say like "settings are successful please release and renew the ip address".click
continue or OK
8,Now turn off ur modem and the router..wait for other 1 minute..turn onn only the modem and
wait till all the lights lit.now turn on the router and wait till the power light is solid.
9, Open Internet Explorer and it shuld Work....
STEPS FOR WIRELESS CONFIGURATION
1,open internet Explorer and in the address bar..enter as 192.168.1.1..it will prompt for a
2,
U can see the option WIRELESS in the black bar..click on wireless..
Wireless network mode should be "Mixed".wireless network name can be ur first name or
anyother name.select the channel as 11 and the SSid broad cast should be Enabled.click on
save settings.it will say like "Settings are successful"click continue.
3,to set the password for ur wireless network...below wireless tab in the black bar..u will
find a blue bar which says "wireless security".click on "wireless security". Security mode
should be "WEP"..Default transmit key should be 1.wep encryption should be 64
bits..passphrase should be empty..in the key 1 box enter ur 10 digit telephone number(ur
telephone number will be ur password for the wireless connection)click save settings and
continue..
4,
now in the laptop check whether the wireless switch is turned on...u can find ur wireless
signal..while connecting it will prompt for a password.enter ur telephone number there..
u will be connected to the internet..
ALL THE BEST!!!!!!!!try it and post ur feedback
Jun 18, 2008 | Linksys Wireless-G WRT54G Router
When i try and set up my wireless router it tells me the router is not detected
Please ensure that you have the router connected via the blue cable directly to your computer's ethernet port. You should be able to interface into your router's config page by typing in 192.168.1.1 in the web browser expolorer bar. Hope this helps, however, please do get back to me should there be anything else. Thanks.
-Technomancer
Jun 02, 2008 | Linksys Wireless-G WRT54G Router
I purchased a wireless router model wrt110 early this month, installed and working fine unitl last night had to uninstall and tried to install it back i get to the installation to figure the router and i...
NO need to worry i will provide a valid trouble shooting steps
I think u have used the set up cd..dont use the Cd..i will give u the exact steps..
2,connect the other Ethernet cable between the Modem(came from ur internet people) and the Router's Internet port(standalone port at the back of the router)
3,In the rear panel of the router u can see the reset button.with the help of the paper or ball point pen,press it hardly and hold it for 1 minute..
5,turn onn only the modem and wait till all the lights lit.now turn on the router and wait till the power light is solid..open the internet Explorer it should work..
STeps for DSL Connection(verizon)
6,open internet Explorer and in the address bar..enter as 192.168.1.1..it will prompt for a user name and password..leave the user name blank and the password will be admin.
it will say like "settings are successful please release and renew the ip address".click continue or OK
8,Now turn off ur modem and the router..wait for other 1 minute..turn onn only the modem and wait till all the lights lit.now turn on the router and wait till the power light is solid.
TRY IT AND GIve me ur feedback
May 31, 2008 | Linksys Wireless-G WRT54G Router
Router problem
Make sure you have the wireless icon on the taskbar lower right side. If it does not show connected, click the icon and search for wireless devices, you should see the router. connect to the router. Also make sure you have a solid DSL/CABLE status light on the service modem. BPCS
Dec 28, 2007 | Linksys WRT300N Wireless Router
Linksys WRT300N Wireless Router Logo
1,456 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
