Question about Refrigerators
RS652 fridge stopped working overnight tripping circuit breaker
  • Refrigerators Master
  • 43,501 Answers
Turn it off completely and let is cool over night and then plug it back in and see if the fan runs and if the compressor runs...
If the compressor runs but not the fan then check for voltage going to the fan and replace as needed...if there is no voltage then trace bad to see if the main board is bad...
Start relay and capacitor may be bad if the compressor does not run after getting completely cooled down...
Check out these tips that I wrote about that... it is a greatplace to start trouble shooting your unit...and something that you can dorather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 09, 2010
Refrigerator disables all outlets on its circuit but the 1st outlet
I just answered your question on the previous situation but here it is again. A GFCI receptacle placed in a circuit controls power to all remaining devices on that circuit. If the GFCI trips, anything after it shuts down. That is your situation. If your fridge keeps tripping the GFCI, it has a grounding problem. You should have your fridge checked out so that your family does not receive an electrical shock when contacting the fridge. Be safe.
Aug 31, 2014 | Electrical Supplies
Fuse panel in k z 204s
The fuse panel is located in the breaker box to the right of the breakers. Each fuse should be properly labeled. If a fuse is blown and there is a draw on that circuit there should be a red led that will light up to indicate which fuse has failed. If you have any other questions please respond to this thread.
Jun 22, 2014 | Palomino 2013 Puma 31-DBTS
Circuit breaker tripping
Sounds like the electric motor in the fridge may have shorted out some of the windings which is causing it to draw more current. You should get one of those clamp on amp meters to see how much current it is drawing when it first kicks on.
Jan 23, 2014 | Admiral 26 cu. ft. Side-By-Side...
The jenn-air fridge that i have jcd2289ae has stopped working it is tripping the gfi, i have tried plugging it in another plug in but it trips the breaker
http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Refrigerator-Parts/Model-JCD2289AEQ/1266/0165000/M0406284/00012?blt=06&prst=&shdMod= here is a simplified wiring diagram for your unit. It might help you track back the problem.
Before it started tripping the circuit breaker what was your refrigerator doing that was not normal? Usually, before something fails massively it will give you hints it is coming. Did your ice maker or lights stop working? Has the compressor been running an excessively long time?
What trips a breaker is the unit drawing more current that what the breaker is listed at. So something in the unit has shorted to cause this to happen. Although the first thing we check in a situation like this is the compressor circuit it isn't always the cause.
Jun 26, 2011 | Jenn-Air 21.6 cu. ft. Side-By-Side...
The Lights circuit breaker keeps trips without load
try a new breaker, they do wear out over time
Feb 08, 2010 | Electrical Supplies
Fridge keeps tripping the circuit breaker
Unless there is a dedicated circuit of 20 amps to the refrigerator this will continue to happen When your refrigerator goes into defrost and other things like lights fans air conditioners are on the same circuit it will have no choice to not trip the breaker. Try this turn the breaker off and how may thing in your house stop working? You need a 20 AMP circuit or this will possibly damage the compressor or weaken the breaker because it has tripped so many time. Thanks, Please rate my solution, I have done this work for 30 years. Thanks, Sea Breeze
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Jul 10, 2009 | Whirlpool ES5FHAXS Side by Side...
get an inexpensive clamp amp meter (Harbor Freight has them). Turn off power to the plug. Remove plug from wall but do not disconnet wires. turn fridge OFF. plug the unit in the recept. turn on the power. set the meter for the higest reading (amps) & clamp it around the black wire. turn the fridge ON & observe start up current & the "run" current. If the fridge is within limits on the data plate the problem is in the wiring circuit, maybe a loose connection either @ the plug or the breaker. if there are several plugs in the circuit, the problem could be in one of them. In addition, if there is a gfi plug in this circuit, it could be faulty also.
Mar 01, 2009 | Refrigerators
Your fridge should draw no more than 5amp. Presuming your breaker is at least 15amp there's a problem. Move to a different circuit first. If the condition persists check the start relay on the compressor. I have a suspicion the circuit may have another item you are not aware of.
Mar 01, 2009 | Whirlpool GS6NBEXR Side by Side...
My fridge has stopped working on my samsung RS21FCNS can you help.
  • First off check the power. You should check to see if the receptacle is working properly, use a circuit tester for this. If the receptacle doesn't’t work, check for a tripped circuit breaker or blown fuse.
  • Other problems that could be associated with a fridge not working include, an electrical cord that is damaged.
Aug 27, 2008 | Samsung Refrigerators
Fridge/freezer trips my circuit breaker
This sounds like a grounded wire in your defrost system. Start by finding the defrost timer and checking the wires. One may have been pulled loose or pinched while it was being moved.
Dec 12, 2007 | Refrigerators
Refrigerators Logo
161 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
