Question about Sun Mountain Speed Cart V1
I have a sun mountain push/pull golf cart that needs a replacement part. A stableizer rod is bent..
  • jgoble48
    jgoble48 Jul 10, 2012
    I have the same problem. Did you ever find out where to get stableizer rods? Thanks
2 Suggested Answers
SOURCE: Sun Mountain Speed Cart V1 users guide
I am trying to replace the lower bag holder with the new non bungie type. They didn't send instructions. Do I have to drill new holes in the frame to make this assembly work? The top one was a straight replacement.
Posted on Mar 27, 2011
How to fix accelerator that doesn't come back off. When you push on it you have to pull it back off. On cub car golf cart.
Probably a broken return spring or just corrosion. You would have to get under the cart to see if this is the DS model. If it's the precedent model, It is one unit in the floorboard.
Mar 18, 2017 | Golf
Got hit from the left side but theright frontwheel was the one tilted towards insideof the wheel well can it be the stable lizers
it can be any part of the front suspension or brake system including drive train damage jack up right side and with wheel still on place hands at top and bottom of wheel and push and pull in and out if movement usually a ball joint but ball joints dont give off a grinding noise ===now grab tire at the 9 and 3 position front and back -push and pull if loose possible tie rod damage or steering component damaged this also doesnt give off a grinding noise unless bent into a turning part =====turn wheel and listen and look at cv axle and around brake area if noise remove wheel and now inspect brake caliper ,brakes ,hub and axle for noise these components can give you your grinding noise repair or replace damaged components the other tests performed were for possible damaged parts since wheel was bent inward
Apr 09, 2014 | 2005 Ford Taurus
Adjust break
Follow the brake cable from down the cart until you find the tension bolt. To tighten turn to the left. If you are not comfortable working on the cart, most bicycle shops can repair them for a small fee.
Sep 04, 2013 | Sun Mountain Sports Golf Speed Cart V1
I NEED A NEW LATCH HOOK BRACKET FOR SUNMOUNTAIN GOLF CART
Hi try here
https://www.sunmountaingolf.co.uk/article.php?xArt=25
Oct 20, 2012 | Sun Mountain Speed Cart V1
Craftsman 16 HP Electric start 41" mower - on a overhead valve briggs and stratton two stroke engine the hollow push rod bent. We pulled the head and everything seemed in working order. The replacement...
On any pushrod engine you have to make sure that the timing is correct or nearly correct when first firing it up, if you had the cam in the wrong position the pushrod had no place to go when the cam lobe came around=bend push rod.
Sep 24, 2010 | Garden
Apr 05, 2010 | Sun Mountain Speed Cart V1
Can't open
hello. It is supposed to snap in. Try a little WD-40 or even pam cooking spray on the yoke to lube it. If it still will not work properly take it to your golf course pro shop as they work with these items daily and will show you exactly the best way to proceed.
Also note that it is very important to only push this cart and never pull it as doing so will void the warranty. Joe
Mar 22, 2010 | Sun Mountain Speed Cart V1
Where can I find a brake cable for my Sun Mountain speed Cart v1?
Call sun mountain and they will send a new cable for free.
Sep 08, 2009 | Sun Mountain Speed Cart V1
Sun Mountain Speed Cart V1  Logo
229 people viewed this question
Top Sun Cycling Experts
Tom Chichester
Bill Boyd
Donald Ayers-Marsh
Are you a Sun Cycling Expert? Answer questions, earn points and help others
