Question about Apple iPod nano
Nano hi there, my old nano is causing constantly shows the flashing 'do not disconnect' screen. it also doesn't show up on my pc either...my pc used to be riddled with viruses, might that have something to do with it? i've tried resetting it a couple times but that doesn't work...any help would be great...i'm starting to hate this thing!!!!!!!!!!
Hi im in skool right now!
Posted on Jun 16, 2008
Unit is one year old. Worked fine this morning, got back into car and GPS asking set-up questions but a the time prompt it flashes off and starts the set up over againi with language prompt. Keeps...
try this originally posted by gt3rs i just did it and it worked for me Here is a solution that worked in my case (constant reboots after voice select)
  1. Plug your tomtom into your PC.
  2. Run TomTom Home
  3. Select the option to run your TomTom through your PC (TT Home)
  4. You should be greated with the select language screen
  5. Then simply select language etc.
  6. When you get to the voice selection: select a voice (here TTHome should freeze) <- also strangely enough notice the cancel button doesn't on the screen (as it does when doing this on the device)
  7. Don't panic TT Home should start working again in a few seconds
  8. Disconnect your TomTom and that should have solved the problem, the normal map screen should show up upon starting up your TomTom
This solved the issue for me, hope it does for you good luck!
May 10, 2011 | Tomtom One XL GPS Receiver
The screen of my Ipod Nano is frozen and shows only battery symbol. It wont get connected to the PC. And doesn't operate it's functions. And doesn't shut down.
Turn on hold, then turn it back off, then hold menu and the middle button down until the screen shows the apple symbol. Trust me, this happened to my old 3rd gen nano, found the soultion on apple's support pages somewhere.
Feb 07, 2009 | Apple iPod nano
Wont synch
Ipos is a gadget which you hav to sync using Itunes the you can listen to music or watch movies
id youy directly transfer any content to ipod using Mycomputer , it wont show upp anything on th screen
Jan 30, 2009 | Apple iPod nano
Ipod wont show up on itunes
Hey there Twinkle,
The wierd symbol when charging is normal.
The HISPEED thing is because the USB socket you are plugging into is not powered so it won't work at all in this kind of socket. The best way to connect it is using the main USB socket in the PC or MAC you are using rather than an external hub. If you do use an external hub make sure it is powered v2.0 USB.
To fix the ipod reset thing, once you do get it connected to your pc do a software update on it (this will probably come up automatically when you've connected it) or click the 'Restore' button and this should fix it.
All the best
Sean
PiDigital
Dec 08, 2008 | Apple iPod nano
Try the five r's:
These are for Nano, but they apply to all iPods:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
Jun 14, 2008 | Apple iPod MA446LL/A MP3 Player
For it to recongnize, maybe try:
1: go to control panel
2:add hardware
3:connect your hardware device and click "yes i have connected the hardware"
4:scroll down and select install new hardware device
5:select install hardware that i manually select from a list
6:scroll down to windows portable devices
7:and choose MTP device
this should make it so your ipod is now recognised by the computer
---John
Give credit to Randomassist
May 16, 2008 | Apple iPod nano
Ipod nano 2gb
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
Mar 24, 2008 | Apple iPod nano
Hey, watch this tutorial and try the things it suggest.
Id highly recommend, restarting, and returning the device into the original state.
All this is covered in the video here:
http://www.apple.com/support/ipod/tutorials/troubleshooting.html
If that doesnt help contact the appel support.
Mar 09, 2008 | Apple iPod nano
go to applications then utilities then open disk utility
on the on the left side all the hard drives will be listed. click on your ipod then click erase, look here click "erase" and then "ok". when it is done disconnect the ipod, open itunes and reconnect the ipod. itunes will tell you the ipod is corrupted and i needs to restore it. click ok and then wait for it to complete the restore.
PC:
go to start, my computer. in the new window your ipod's name will apear right click then click format. make sure that quic format is checked and then click "ok". when it is done disconnect the ipod, open itunes and reconnect the ipod. itunes will tell you the ipod is corrupted and i needs to restore it. click ok and then wait for it to complete the restore.
Feb 19, 2008 | Apple iPod nano
try these websites. it can be a frustrating problem.
http://www.apple.com/support/ipod/five_rs/classic/
http://docs.info.apple.com/article.html?artnum=93716
make sure you follow all of the steps
good luck
Dec 14, 2007 | Apple iPod nano
Apple iPod nano Logo
23 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
