Question about Proform XP Weight Loss 620 Treadmill
I am assembling the ProForm 705 Trainer Model PFTL70009.0. On page 11 of the manual, Step 10, it has me attaching the Crossbar with 4 #10 x 3/4" screws. The screws will just barely go into the tap hole and won't screw in any more. They stick up at least half an inch. I know it isn't supposed to be that way because they don't tighten down to the star washers. I have tried the screws in the tap hole without the crossbar to make sure they don't screw in any more and they don't. I am sure from the picture that I am attaching in the right place in the right screw holes. I don't know if I am doing something wrong or if I need to go to the hardware store and find a smaller size screw. Thanks.
You probably have a nswer by now (or have given up and bought other screws, but I have to tell you we just had this exact problem! We rubbed the screws on a bar of soap. then they screwed in just fine. Its still very tight, but they go in all the way.
We also first screwed them directly into the handrails without the crossbar on to make to make sure we could get the screws all the way in (as the drilled holes were not perfect). But I think the main trick is really the soap.
Posted on Nov 20, 2010
Pro form 320x treadmill stops working when you get on it
How can I get my Proform 320X treadmill from stopping a ...
www.shopyourway.com > Manage My Life > Questions
How can I get my Proform 320X treadmill from stopping a few seconds after starting? ... -why-does-my-proform-treadmill-belt-only-move-a-few-seconds-stops
ProForm Treadmill 320x User's Guide ' ManualsOnline.com
fitness.manualsonline.com > ... > ProForm Treadmill
ProForm 320x Treadmill User Manual. Page 1. Page 2. Page 3. Page 4. Page 5. Page 6. Page 7. Page 8. Page 9. Page 10. Page 11. Page 12. Page 13.
Nov 03, 2015 | Exercise & Fitness
Proform hybrid trainer squeaks - elliptical portion only. Everything tight. What do I do now?
Locate the site of the sqeak. Then spray WD40 or similar spray lubricant thoroughly in and around the screws in that area using the straw attachment. I did just that and it took care of the problem.
Aug 07, 2013 | Proform Hybrid Trainer Elliptical
Proform xp 580 - Occassionally, any button i push simply beeps, and nothing else happens, no response from the panel.
Step 1:
please replace the old batteries with a new ones, with the same mark+same polarity+full charge.
Step 2:
adjust the REED switch, see the diagram attached, test for open or faulty, clean it, and tight the connector very well .
Step 3:
tight all connector a) ribbon cable inside for keypads b) upper connectors board display vs lower connector main board.
God bless you
Jan 04, 2013 | Proform XP 580 Trainer Treadmill
When i start my proform 705 trainer the speed goes up and stop , the controller is faulty .What component in the mc-2100lts-30 should i replace to fix it
Dear Sir:
You must adjust , clean, and tigh very well the connector from speed sensor. see the diagram attached.
After that RUN the software calibration.
sincerely. God bless you.
ernesto cuadra
Apr 21, 2012 | Proform Exercise & Fitness
I need a manual for a schwinn personal trainer 705
You can get the Schwinn 705 assembly manual here
Apr 16, 2012 | Exercise & Fitness
Calibrate new console
Dear Sir:
Please see the instructions 1) some models attached under the Hood of the main motor 2) Other model is under the cover of display board.
3) Follow the instruction from user guide.
Adjust the reed swithc see the attached diagram
If you do not have user guide. go : www.proform. com go to customer service go then parts% Manuals, give your model, etc, and download for free your u. manual.
ernesto cuadra
managua, nicaragua. c.a.
Feb 29, 2012 | Proform XP 580 Trainer Treadmill
Heater keeps shutting off what could it be cant find manual to help
Use this manual to assist you in troubleshooting. http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
The manual will help you isolate the problem.
Things than can cause your symptoms:
1. Pump pressure incorrect
2. Dirty air intake, air output
and/or lint filter
3. Dirty fuel filter
4. Obstruction in nozzle
5. Photocell assembly not properly
installed (not seeing the flame)
6. Dirty photocell lens
7. Bad electrical connection between
photocell and ignition
control assembly
8. Defective photocell
9. Defective ignition control
assembly
10.Line voltage is below 108V or
above 132v
REMEDY corrosponds with 1 - 10 above
1. Fill tank with kerosene
2. See Pump Pressure Adjustment,
page 10
3. See Fuel Filter, page 11
4. See Nozzle Assembly, page 12
5. Drain and flush fuel tank with
clean kerosene. See Storing,
Transporting or Shipping,
page 7
6. Check electrical connections.
See Wiring Diagrams, page 16
7. Replace ignitor, see page 11
8. Replace ignition control
assembly
9. Check for proper line voltage
1. See Pump Pressure Adjustment,
page 10
2. See Air Output, Air Intake and
Lint Filters, page 10
5. Make sure photocell boot is
properly seated in bracket
6. Clean photocell lens
7. Check electrical connections.
8. Replace photocell
9. Replace ignition control
assembly
10.Check for proper line voltage.
Disconnect power equipment
that may be used on same
line
Thanks for choosing FixYa,
Kelly
Jan 09, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
How to replace a front motor mount on a 1993 Mercury Sable 3.0 V6
To change the right front motor mount on a mercury sable. 1. you will need a jack and 22mm and a 5/8 socket.
2. you want to place the jack under the catalyst converter or somewhere on the motor that will lift the motor separatly from the crossbar that the front mount is attached to.
3. apply a little lift to the jack raising the car(3 or 4 hydraulics jack lifts).
4. using the 22 mm socket wrench take the bottom nut off the mount which is located under the right side of the crossbar.
5. using the 5/8 socket remove the top bolt that attaches the mount to the motor.
6. raise the jack 2 or 3 more times( giving you more room to move the old mount out).
7 . remove the old mount paying close attention to the way it is positioned, being sure not to put the new mount in wrong.
8. apply the new mount.
9. apply the top bolt and tighten .
10. lower the jack until the mount is seated correctly onto crossbar.
11. apply bottom nut and tighten.
12. glad i could help!
Nov 03, 2009 | 1993 Mercury Sable
Proform XP Weight Loss 620 Treadmill Logo
378 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
