Question about HP PhotoSmart C4480 All-in-One Printer InkJet
Paper jam but i open printer and i didn't see any paper
  • 1,218 Answers
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Posted on Nov 09, 2010
Paper jam and cannot see any paper
This PDF gives step-by-step help on clearing paper jams on the 8860MPF:
http://download.support.xerox.com/pub/docs/8510MFP/userdocs/any-os/en/user_guide_en.pdf#G12.1054794
Apr 14, 2013 | Xerox Phaser 8560MFP Laser Printer
Printer says to clear paper jam, can't see paper jam i clear it out.
Here is a post I found how someone else fixed their problem. Good Luck
I was getting the same fake paper jam and improper shutdown error messages on this POS printer. I blew it out with compressed air - but that was no help. To watch what was going on, I stuck a pen top in the open cover switch sensor (see top image at http://windowshopusa.com/hp_8500_POS.html ). It didn't appear that the cog wheel was the problem - it made no clicking noise or anything - the print head just traversed from R to L, then errored.
After I removed the sliding cover on the right, and with the print heads out of the way, I noticed that the chrome hold-down clip (bottom image) was crooked, and this prevented the print heads from traveling all the way to the right, causing the fake paper jam. Straightening the clip fixed the problem. (I didn't have to remove the clip, just pushed it straight - it's not in very tight.)
Nov 14, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Paper jam. Sheet printed but didn't pass through the rollers
  • Remove the paper tray completely by pulling it out towards you.
  • Now pull the jammed/stuck paper out gently.
  • If you cannot remove the paper by the above procedures,open the printers front cover to access the cartridges assembly.
  • Pull the cartridges assembly gently and slowly.This will come out together with the jammed paper.
  • If jam not cleared,open the back cover and pull the tab outwards to access the fuser unit.Remove the stuck papers here.
  • Hope this helps.Thanks!
Oct 31, 2011 | Brother HL-2040 Laser Printer
Whilst just starting ti print there was an unexpected noise form the printer, like loud clunk. Now it won't print - it says there is paper jam but there isn't. Press OK to clear jam, then it does...
Sounds like one of the gears has probably broken
check out the HP website for suitable alternatives .if your in the uk try http://h40059.www4.hp.com/uk/printers/ otherwise start at http://www.hp.com/
Sep 02, 2011 | HP PSC 2355 All-In-One InkJet Printer
I have a paper jam and need to open the back door of an HP 6200 Printer. Do I need a screw driver?
Hello and Welcome to FixYa!
No, you didn't need any screw driver for clearing a paper jam. But yes, if it is more mess than just a simple paper jam, then it depends.
For Paper Jam issues, kindly go through this document.
Concerned, Nooh.
Aug 04, 2011 | Office Equipment & Supplies
Hp officejet 5610 keeps saying paper jam but there is no paper inside
Hi there, i understand that you're having problems with your officejet printer.
regarding with your concern, theres so many possible reason why is that your printer is keep on saying paper jam..
one of the possible reasons is that the paper is jammed inside your printer where you cannot see it. and the paper tray is too full or overload with papers.
now, here's what you can do about it. open this link and follow all the steps on how to resolve the pape jam issue
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&cc=us&lc=en&dlc=en&product=441125&tmp_track_link=ot_search
now after doing all of the steps and still it didn't work then do a semi full reset.
1st - the printer should be on 2nd- unplug the power cord from the back of the machine 3rd- press and hold the # key and the number 6 at the same time while the power cord is unplugged 4th - now, re-connect the power cord after 30secs while still holding those buttons (dont release those buttons up until you see a message on your printer screen saying something about reset) 5th - after realeasing those buttons, then the printer will be doing something inside or in other words, it is doing its own reset.
if the semi full reset didn't worked then to tell you honestly it is something wrong with the machine or it is a hardware failure and there's no fix for that and you will need to have an upgrade or buy a new one..
if you have any other questions.. dont hesitate to reply..
Good Luck!!!
Jun 01, 2011 | HP Officejet 5610 All-In-One InkJet...
After picking up several pieces of paper at once and jamming, the printer now says there's a jam in the exit area. The paper jam I removed from the input area didnt leave any bits behind so I dont see...
You didn't mention your printer make/model but typically this is one of two issues. Either there is a jam (and it can be the tiniest of pieces of paper) or the printer "brain" needs to be reset. This can usually be done by holding down a sequence of buttons on the printer while turning it on. However, all makes/models are different so you best bet is to check the printer manual for how to do this.
Apr 27, 2011 | Office Equipment & Supplies
Printer Jam in HP CM 312 nfi mfp in output tray path. Can see paper from the front but you are supposed to be able to clear from the back. No one seems to be able to figure out. Please help.
Hi there.If the jamed paper didn`t reach the back of the printer then you need to open your front cover and pull out the toner cartridge and you can pull the paper from there.Grab the paper in the middle and pull it out slowly or you may broke the paper and the things will get serious.If the paper has reached the back of the printer, open the back cover of the printer, pull down the green levers of the fuser to release the paper and pull it out.If you need any futher help please replay.Thaky for using Fixya!
Dec 14, 2010 | HP Laserjet CM 1312NFI Color Printer
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
My Canon ip2600 keeps getting jammed. It takes
Lol!!! I was having the same exact problem--- looked in it, didn't see a thing, opened it, still didn't see a thing! I turned it over-- and sure enough, a pen fell out!! lol
Jul 21, 2010 | Canon Pixma iP2600 Photo InkJet Printer
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
392 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
