Question about Maytag MER5775Q Electric Kitchen Range
My bake option does not work. All burners and broil option works though. How do I fix this? Is it a matter of just replacing the element because I cannot find any fuses to replace?
  • 643 Answers
It's more likely a faulty switch,and i would try the switch first as it would be a less expensive repair, elements tend to run a little higher cost.
Posted on Nov 09, 2010
Frigidaire oven fefl68 broil element comes on on broil only will not come on on bake or clean
Hello - - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Nov 17, 2012 | Ovens
Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Aug 12, 2008 | Viking VDSC307-4B Dual Fuel (Electric and...
Oven has power but none of the burners on top or the bake or broil elements work
Go to breaker panel,turn off and wait a minute and turn on,may reset it.
Oct 28, 2012 | Kenmore Kitchen Ranges
My oven wouldn't bake or bbroil but all burners
First suspect is the thermal fuse that feeds the bake and broil elements. It is located on the back oven wall or sometimes the top.
Jun 27, 2010 | Frigidaire FEF312 Electric Kitchen Range
Bake element not working,broil element is working,top burners work,no break in bake element,
sometime's you cant see brake in elements . test it w / a omm meter . or ck to see if it has power to it . if so just replace the element .. m m
Nov 20, 2009 | Kenmore Kitchen Ranges
Bake element for Maytag MER5765RAS did not work. Replaced bake element but Broil and Bake element still do not work but burners do
look inside the breaker box..find the 220 breaker to the range...make sure both sides are in the on possition....if not then only 110 volts are going to the range instead of 220...hope this helps..thanks
Nov 08, 2009 | Maytag MER5765RAS Stainless Steel Electric...
Kenmore electric range 790. Both the broil and
Kenmore oven 790.91072601, bake & broil not working, relays are cycling but no heat... Sounds like I have the same problem but its the night before Thanksgiving and Iam in panic mode... I've orderd a new Temp Probe part # 316233902. did you ever get yours fixed
Jul 13, 2009 | Kenmore Kitchen Ranges
Replaced bake element but will not heat
I had the same thing happen to me replaced burner did not fix the problem so I ended up calling service guy and it ended up being a lose connection on the mother board all he had to do is solder the wire!!
Jul 10, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Frigidaire oven not working in bake setting
Hi Thanks For The Question. I Would Check The Bake Element. Replace The Bake Element .Thanks The Appliance Doc
Oct 06, 2008 | Frigidaire FEF366 Electric Kitchen Range
Maytag MER5775Q Electric Kitchen Range Logo
67 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
