Question about LG 47LD450 47 in. TV
How do i get audio output from a LG 47LD520 with using the optical audio output??? My receiver doesn't support optical audio, is there a way to get audio from the TV without it???
  • Anonymous Mar 27, 2014
    how do I hook up an lg soundbar
Either use the white/red analogue audio outputs on the TV.
Or, you can get a Toslink optical to coaxial audio converter for $10 - $15 off ebay. http://cgi.ebay.com/TOSlink-Optical-COAX-Coaxial-Digital-Audio-Converter-/220657947104?pt=LH_DefaultDomain_0&hash=item33603d11e0#ht_1128wt_1139
Posted on Nov 09, 2010
I installed a HDMI cable and an Optical cable to whatch movies and shows from my LG HD LCD TV, but nothing seems to work. The stereo is also a LG LHB336 system. Which is compatible with the TV. We were...
Hi,Even though you have done some cabling already,for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 24, 2011 | LG 42LC2D 42 in. LCD HDTV
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
Hi. I write from spain. I have the blu-ray LG
Have you tried the another optical cable? They don't tolerate dirty connections or small-radius bends in their routing. THAT (and the expense of optical cables) is why I always choose coaxial connections when possible.
Mar 02, 2011 | Yamaha RX-V363 Receiver
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
Where are the red and white jack sockets to connect my new 50in lg plasma screen to my old wired 5.1 speaker system?
I am sorry to say that it does not have a left /right analog audio output. It only has a digital optical output on it. Unless your receiver has a optical input, you cannot use your set's audio out. If you are using a cable box or satellite receiver, you can their left /right output for you audio signal.
I hope this helps,
Skyassoc
Dec 11, 2010 | LG 50PG20 50 in. Plasma HDTV
Trying to connect to LG 60 inch plasma. no output
Hi.
You need to connect the Bose using the Optical Audio output from TV to Bose main unit (kind of square shaped connector), and not using the RCA inputs on TV.
The picture below is an LG back panel, the optical audio connector is at the lower side of I/O connections at the back of TV, on some model the location of connector may be different.
Dec 26, 2009 | Bose Cinemate Digital Home Theater System...
I have my ps3 connected to my t.v via HDMI, but want to get surround sound on my ps3, how can i do this as my receiver doesnt have optical or hdmi outputs?
Does your TV have any audio outputs at all? It is a new feature of a lot of TV's to have at least an Optical output. Use that to run back into your receiver if available.
Oct 25, 2009 | LG SP3700K - Left / right channel speakers...
LG 47LD450 47 in. TV Logo
2,062 people viewed this question
Steve Allison
Steve Allison
