Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
I have a 97' polaris xlt sks. Has been running great, always a single pull start. Took it out riding, ran great. Got home and it wouldnt start. Has spark and fuel. What the heck!!!????
  • matthau Nov 10, 2010
    thank you for the response. I put new plugs in, sprayed ether and still nothing. i pulled the plugs and cranked the engine till the excess fuel was all out. Still nothing. I will now check the air cleaner. Im also going to put it in the garage and let it thaw out and see if that helps. If you have any other ideas please let me know. Thanks again
  • 2,973 Answers
Matthau,
Please check if there is flooding in the carb. If not then may be it needs a choke as it must be running in extreme cold conditions.
Posted on Nov 10, 2010
    Guru:
  • 773 Answers
May have spark, but the plug could still be fouled or dirty, or bad. The spark may be poor. Try cleaning the plug first, then try a new plug.
Also, check the air cleaner, because if its clogged it will flood the engine.
If you still have problems, give it a shot of ether.
Posted on Nov 09, 2010
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Jan 04, 2016 | Cars & Trucks
When my 2001 indy 500 idles i have a knock
idle knocks indicate worn pistons or worn gudgeon ( wrist pin) bushes
check the ignition timing as it may be too far advanced for idle causing piston slap
Sep 09, 2017 | Polaris ATV
Polaris xlt engine troubles engine will start but will only keep running if i play with the choke
had same problem just this week mine would only run in choke positions simply die in run position i ened find i very small crack in the stem of my fuel filter believe it ir not so i removed it and ran a new line without filter straight in just to see what would happen and it worked ran like a champ put new filter today and still flawless runs great and idles perfect was told it simply was sucking in air threw that small crack witch would screw my fuel flow sounds crazy but hey easy fix you never know
Feb 01, 2011 | Polaris New Genuine Polaris Snowmobile...
I just purchased 2003 Polaris Trailblazer for my boys for Christmas. I test drove it for about 5 minutes (in a subdivision). It started and ran perfect. I started it a few times over the days before...
that would be the fist place i would look if you have a electrical meter place it in the ohms position take some reading on the primary and secondary windings on the coil when it is cold then run until it stalls and take them again they should read the same if not the coil is at falt
Dec 27, 2010 | Polaris ATV
97 lumina car runs great. today I ran it and when
No it doesn't have fuel. What test did you do.? The fuel filter is dirty or the fuel pump is mechanically bound once in awhile.
May 05, 2010 | 1997 Chevrolet Lumina
Replacing snowmobile track slides for 94 polaris xlt sks
remove the screws from the front part of the rail that holds the hifax on, then slide it backwards through a window in the track, same procedure on instalation
Sep 15, 2009 | Polaris New Genuine Polaris Snowmobile...
93 polaris xlt tripple wont run to full potential
The issue I had with my 94 was due to an oil adjustment, wich you can find below the carbs. It ran great at full throttle but once it sat at idle, the plugs would get wet and the same type of bog would accure. Get new plungs and make sure all three are firing first, if they are then the oil adjustment is off. If not sorry to say but you may have a bad coil.
Feb 10, 2009 | APW Wyott Sport & Outdoor - Others
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
181 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
toddgilbert
toddgilbert
Todd Arndt
Todd Arndt
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
