Question about Midland Two Way Radio
Im using a gxt 795 midland 2 way radio but my friend has a gxt 1000, hes on a group channel of 8 and frequency1, am i able to connect wit his radio and how?
Benimur
  • 6966 Answers
SOURCE: Midland gxt-850 gets HOT!
It is very possible that the terminal of the positive end of the bottom battery is shorting to the battery's body hence the heating up. If this is the case, then when you charge the radio, excessive current is flowing since the battery set has one shorted. Again this would cause heat buildup specially on the bottom battery and the charging terminals.
A possible solution is to check the bottom battery's positive terminal and ensure that it only contacts with the positive terminal of the battery and does not touch the battery body (which is negative).
Alternately (and perhaps more to your advantage), seek replacement of the defective unit considering it is new and therefore should be under warranty.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 06, 2007
randy54156
  • 55 Answers
SOURCE: midland gxt 500 wont stop vibrating
Stop shaking it
Posted on Nov 05, 2008
  • 157 Answers
SOURCE: midland radio battery pack constant vibrate
Hello pjbracht, I just responed to a duplicate of your problem. If they are new, return the battiers and confirm they are "by the book" replacements. If so ask for replacemrnts with a higher mAhr. It is not correct for vibration from a battery pack, lead, NiCad, Ni-MH, period.
Posted on Nov 07, 2008
Neto
  • 123 Answers
SOURCE: programming problem
http://www.midlandradio.com/owners_manuals.asp
Try this site
Good luck
Posted on Jan 23, 2009
BillB-SA
  • 2761 Answers
SOURCE: is the midland gxt 650 compatable with the g12
All type-accepted GMRS radios operate on the same frequencies and use the same type of transmissions. Channel numbers are the same on most models, but check the channel/frequency chart in the radio's operating manual to be sure.
Bill B
Posted on Jun 02, 2010
I need the manual for the Midland gXt 1000.How can I download it?
Go here....
Owners Manuals
Select the model and when the pdf shows up, click the download icon in the upper right hand corner of the window.
Mar 15, 2015 | Midland GXT1000VP4 Two Way Radio
One walkie talkie will send but not receive
Check your programming, specifically the private line (PL code) settings. This is one problem which can cause the problem you are describing.
Feb 22, 2014 | Midland Radio Midland Gxt 795 Vp4 Radio...
Wont turn on
did you try plugging it in. if its AC/DC try the other one to see if the switch is in the wrong position . May have a blown fuse also .
Dec 09, 2013 | Midland Radio Midland Gxt 1000 Vp4 Radio...
Needing a manual for the GXT 756.
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. If you require some other manual, the file doesn't work, or this isn't what you are looking for PLEASE reply to my answer here and I will correct it for you. Here is the manual / guide please give it a few minutes the file is quite large:
The GXT 756 is a variation of the GXT 750, which is covered in this manual here....
http://www.buytwowayradios.com/Products/Midland/manuals/GXT-710-manual.pdf
Oct 16, 2010 | Midland GXT450VP4 (22 Channels) 2-Way...
Hello and Good day, Can you please help me get the manual for the GXT 400 X-Tra Talk? Thanks Emileo
just click on this link.. its a pdf file....
www.buytwowayradios.com/Products/Midland/manuals/GXT-300om.pdf
Jun 22, 2010 | Midland X-TRA TALK GXT400 (7 Channels)...
Is the midland gxt 650 compatable with the g12
Bill B
May 30, 2010 | Midland Two Way Radio
I have 4x Midland GXT 600's and I am trying to tune them into my mates Motorola 2 ways, he is hos on channel 5 subcode 25. Now for some reason when I try to get on the same channels I can not hear him. I...
Motorola FRS radios works with CTCSS or DTCSS and Midland Calls them Privacy Codes, try first using Code numer Zero wich is no code or code off, of course at the same channel in all radios. if you can heard all radios the next step is to choose a code, Im sure that the first code numers in both radios must be the same
Feb 01, 2010 | Radio Communications
Midland   Two Way Radio Logo
122 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
