Question about Uniden DECT 6.0 Cordless Phone ID
Change the number of rings - Uniden DECT 6.0 Cordless Phone ID
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest your select it from the list beginning here to download a copy of the manual.
Posted on Dec 23, 2012
  • kakima Dec 23, 2012
I have 2000 ram 1500 4WD v8 5.9l auto. Need to change refer ring and pinion. Dose the teeth of ring and pinion should be same ront and refer?
NO--- Check Gear Ratio On Tag Or Tube--Front and Rear Are Not The Same. Or Count Teeth On Pinion And Ring Gear--Divide Pinion Number Into Ring Gear Number For Ratio.
Feb 17, 2015 | 2000 Dodge Ram 1500 Truck
CHANGE THE NUMBER OF RINGS ON THE VTECH CS6719-16
The CS6719-16 isn't an answering machine. It will ring until someone answers, some other answering machine picks up, or the caller hangs up.
If you want to change the number of rings before an answering machine picks up, please reply to this post and specify the answering machine.
Apr 08, 2014 | Vtech CS6719-16 Cordless Phone with Caller...
Change number of rings before answering
Change the ring count on the fax when the receive mode is set to Fax/Tel or FaxOnly modes. Change the ring count on your answering machine when it is connected to the fax and the receive mode is set [Ans mc connect] (Answering Machine Mode).
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button.
  3. Press the left or right arrow button to select [Maintenance/settings], then press <OK>.
  4. Press the left or right arrow to select [Device settings], then press <OK>.
  5. Press the up or down arrow to select [FAX settings] (item <1>), then press <OK>.
6. Press the up or down arrow to select [RX settings] (item <3>),
then press <OK>.
7. Press the up or down arrow to select [Incoming ring], then press
<OK>.
8. Press the up or down arrow to select [ON], then press <OK>.
Note: The default setting is [OFF]
    1. A window will appear displaying the number of rings before the machine will answer. Press the up or down arrow to select the number of rings (from 1 to 30 rings).
    2. Press <OK> to set the number of rings.
9. Press the <Stop/Reset> repeatedly to return to Fax standby
mode.
I hope this helps.
Apr 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I want the fax to work with an identa ring. How do I program this? As it is now I have to turn on the fax to receive. Does this HP work with identa ring?
The following set up assumes you have one conventional phone line, but two different phone numbers. One being your regular phone number and the other a distinctive ring for your fax machine
If that is what you have then this is how you set up the phone. Its important to know what type of distinctive ring your phone company will send to your phone. If it doesn't work you can talk to them about getting a different one than their default distinctive ring.
2 Set the HP all-in-one to answer incoming calls automatically.
Press the Auto Answer button until the light is on.
3 Change the Answer Ring Pattern setting to the pattern that has been assigned to your fax number by the telephone company, for example, double rings or triple rings.
For information on changing this setting, see Change the answer ring pattern
(distinctive ringing).
Note Your HP all-in-one is factory-set to answer all ring patterns. If you do not set the correct ring pattern assigned to your fax number by the telephone company, your HP all-in-one might answer both voice calls and fax calls or it might not answer at all.
4 (Optional) Change the Rings to Answer setting to one ring or two rings.
For information on changing this setting, see Set the number of rings before answering.
5 Run a fax test. For information, see Test your fax setup.
Your HP all-in-one will automatically answer incoming calls that have the ring pattern you selected (Answer Ring Pattern setting) after the number of rings you selected (Rings to Answer setting). Then it will begin emitting fax reception tones to the sending
fax machine and receive the fax.
If it is easier or you want to know other options which may be more applicable to your phone setup. You can find that information here.
http://h10032.www1.hp.com/ctg/Manual/c00235090.pdf
Jul 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
To change # of rings you have to go into programing OK press feature * * on the main set and config (266344) then the password admin (23646) this goes to terminals and sets hit show and enter the set you want to change go to capabilities this will allow you to chang # of rings on that set
Mar 17, 2009 | NorStar Meridian M7310 Phone
Norstar M7310 auto attendant problem
As far as changing the # of rings, that may be your phone company. Feature 983 will get you in to change to number of rings. It goes as follows:
Feature 983
System coordinator mailbox # and password
OK
AA
Lines
Enter Line Number
OK
Table
Rings
CHNG
Enter the desired number of rings
If after changing the number of rings the Auto atendant does not pick up at all, You have to call your phone company and set up the second delay through them. We had the same problem here.
Mar 27, 2008 | NorStar Meridian M7310 Phone
How to change number of rings
Not sure how to change the number of time it rings but to change your voice message call yourself, put in your pass when it tells you to then press 4. Now press 3. Now press 1. To have a standard greeting with your number press 1, to have one with your name press 2, and to make your own press 3. Hope this helped.
Feb 22, 2008 | Motorola Mobility V325 Cellular Phone
Change the amount of times it rings before goes to V-mail
In Coverage path form for voice mail
COVERAGE CRITERIA
Don't Answer? y y Number of Rings: 2
COVERAGE POINTS
Point1: h2 Rng: 1
you can change Number of rings,Rng options
Jan 17, 2008 | NorStar T7316E Corded Phone
Changing the amount of rings
Pick the phone up earlier it will stop ringing......:-)
To set the number of rings-to-answer
To set or change the number of rings-to-answer, use the following steps:
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Fax setup, and then press tick
3. Use the < or the > button to select Fax Recv. setup, and then press tick
4. Use the < or the > button to select Rings to answer, and then press tick
5. Use the alphanumeric buttons to enter the number of rings-to-answer, and then press tick
But I still think picking up the phone earlier would be easier
Your Manual, please rate as fixya or post back
Dec 28, 2007 | Office Equipment & Supplies
Number of rings
press *94, then press the number of rings you want 1-9. The tone will change and thats it.
Nov 29, 2007 | Siemens Gigaset S455 Cordless Phone
Uniden DECT 6.0 Cordless Phone ID Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
