Question about HP LaserJet 4700 Printer
I have a printer on my network that won't print out until after it has been turned off and turned back on.
  • 3 Answers
Try upgrading the firmware downloadable from hp website. if this fails more than likely the jetdirect is playing up reset and manually reload ip address
Posted on Dec 09, 2010
Error 651?won,t print from note pad
Follow these steps:
Go to control panel following location
Click on Network and Internet\Network Connections
Right click on broadband connections [WAN Miniport(PPPOE)] and un-check set as default
Jan 12, 2016 | Lexmark X2250 All-In-One InkJet Printer
Hp 2840 won't stop printing
power off the printer. removed the network cable only. power on until it display ready. now print a config sheet or menu map. if it print without error then connect the network cable and print config sheet again. wait and observed. if it will start printing garbage then KILL the print jobs queued on the printer. after deleting all print jobs power off and power on printer with network cable connected. I hope that will fix the problem. by the way. was there any error display in the panel display like "49.4C02". etc.
I’m happy to assist further over the phone at https://www.6ya.com/expert/gerardo_bdb2f65bdb2cdd4d
Feb 21, 2013 | HP LaserJet 2840 All-In-One Printer
On my home wireless network, my notebook computer's print jobs go to the correct printer but won't stop printing until it is canceled from the device manager. The PC that is on the network wor
sounds like the print job queue is overloading the wireless network, causing a hang on that side
big print jobs do that even on wired systems might consider adding more printer memory
May 26, 2012 | HP P2035n Laserjet Printer Monochrome
I can't get my Macbook setup to use the Lexmark x6650. I used the install disc and the wifi light on the printer is green, but I still cannot figure out how to setup my Macbook to print to is...
Print the network settings page to identify if your printer is connected to your wireless network:
1. Press Setup on the printer operator panel.
2. Press the right or left arrow button until Network Setup is displayed, press OK.
3. Press OK at Print Setup Page.
4. Press OK when prompted to Load Paper.
5. Press OK. The network settings page will now print.
Check the Network Card Status, SSID, Trouble Code, TCP/IP Address. SSID should be the name of your wireless network. Otherwise, you may need to reset the printer's wireless network settings.
How to reset network settings:
1. Press Setup.
3. Press the right or left arrow button until Reset Network Adapter Defaults is displayed, press OK.
4. Press the right or left arrow button to display Yes, pressOK.
Once the Wi-Fi light turns on to solid orange, run the Lexmark Wireless Setup Assistant on your Mac.
Sep 21, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
HP Deskjet 6980 won't print. Says offline but i don't see how to turn it back online. was working. now not.
Printers often go off line for no reason. It can be genuinely off line or the pc is just not seeing the printer anymore To put it back on line all you need to do is open the print queue (double click on the printers icon in printers devices/ printer and faxes) go to File and in the drop down list it will say "Use printer Offline or Use printer online. click on it and if the pc is seeing the printer if will change and the printer will then start up and print. If this does not work then check your cable to the printer or your network connection to reestablish the connection.
Aug 07, 2011 | HP Deskjet 6980 InkJet Photo Printer
Hello I get problem to print on lan with my ir 5000 I give an ip and when i want to print i have notification printer is not on line
Hello issa,
Before you roll your eyes please understand that I am honestly eager to help you. There are a buttload of reasons why your device won't print. But I am intrigued by the way you asked the question. My helpful hint would be to say, remember that Canon devices will not accept network changes until you power them off (main power) and power them back up. And even then the default for Canon devices is 60 seconds before they will communicate with the network.It would be really cool if this is the only problem! Believe me, I have seen IT "gurus" pull their hair out over this issue. Again, ANY network changes on a Canon require a power cycle before they will accept these changes.GFL :-)
Jun 21, 2011 | Canon imageRUNNER 5000 Copier
Won't print just comes up with ink system has failed
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the printer off.
Keep holding the buttons down until the printer shuts off and the turn it back on.
You will have to turn the printer off twice and then it will recalibrate.
Make sure you have new cartiges in the printer so that it can reset.
Thanks
May 05, 2011 | Office Equipment & Supplies
Network adapter no longer pings and I can't print,
I had the same problem with a power outage affecting this printer. The printer has surge protection built in, but the network adapter still seemed to be affected. This is what I did to fix it:
Take out all the data cables and turn the printer off. Open the side panel and press the continue and cancel buttons. While holding the buttons turn the printer back on and hold until all the lights blink. Wait about 30minutes and close the side door. After a few seconds, the printer will restart and print a test page. This basically resets the memory on the printer. Also, do NOT turn it off in the middle or you'll destroy the printer.
Apr 09, 2010 | Dell 1320c Laser Printer
How do I print config pages for Lexmark T630, T640, T632, T642, and T650?
1 Make sure the printer is on.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Print Menus, and then press Select to
print the page. The message Printing Menus appears on the
display.
4 Verify that the options you installed are correctly listed under
“Installed Features.”
If an option you installed is not listed, turn the printer off, unplug
the power cord, and reinstall the option. See Step 3: “Install
memory and option cards” on page 30 for more information.
5 Verify the amount of memory installed is correctly listed under
“Printer Information.”
6 Verify that the trays are configured for the sizes and types of
print media you loaded.
or
3 Press Menu until you see Print Net Setup, and then press
Select to print the page.
4 Check the first section on the network setup page and confirm
that Status is “Connected.”
If Status is “Not Connected,” your LAN drop may not be active
or your network cable may be malfunctioning. Consult your
network administrator for a solution. Afterward, print another
network setup page to verify connection to your network.
or
1 Launch the CD.
2 Click Quick Reference.
3 Print the documents.
The same Quick Reference pages are stored in the printer. To print
them:
2 Press Menu until you see Help Menu, and then press Select.
3 When you see Quick Reference, press Select.
Sep 25, 2009 | Lexmark T632 Laser Printer
Can't print from my mac to my canon mp980 wireless printer
Sounds like when you added xp you inadvertently installed new print driver on server.
Try rolling back driver. But may drop xp from printing.
Best solution network printer to router bypass server. Will require hard wire from printer to router. disconnect from server may need network card for printer.
Mar 08, 2009 | Canon PIXMA MP980 All-In-One InkJet...
HP LaserJet 4700 Printer Logo
83 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
