Question about Whirlpool Washing Machines
Error message F 11 appears on my front load Whirlpool. What is Failure notice F 11 mean?
  • 5,911 Answers
Click on the following link for a full explanation of the "F11" error.
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
Please review the advice in the link carefully. If you need further assistance, please let me know. I hope this is helpful to you.
Posted on Jun 16, 2008
Machine is starting to show error codes, ie Dlr door lock and code #11
Do you mean F11 code? The Problem may be a communication error between the Central Control Unit (CCU) and the Motor Control Unit (MCU). You need to check the connections between them and verify that nothing is loose. I don't have a service manual for this type of front loader but if you have access to one it will give you a protocol to follow to verify which part is the most likely to be causing the failure.
Feb 10, 2015 | Kenmore Elite 45986 Front Load Washer
The washer stopped in the middle of a wash cycle. The error message was 11 F. I turned it off and turned it back on and washer stilled stopped and repeated the error message.
Hi
An "F-11" error code on a Whirlpool Duet could cause your washer to become inoperable and stop in the middle of a load. The cause of the problem could be a number of things and may require new parts.
F11 can mean anything from motor to motor control board to ccu board to wiring harness connecting ccu to mcu to motor.
Identification
The "F-11" code could appear with the dash or without the dash on the LCD screen. Be aware that there is also an "F-H" code that could look similar to the "F-11" code. Listen for 11 beeps to go along with the error code's first appearance.
Effects
The error means that there is no communication between the "Motor Control Unit" and the "Central Control Unit." This means that any operation selected like "Pre-wash" or "Large Load" cannot be sent to the motor for the washer to operate.
Prevention/Solution
Open up the washer panel to check the wire connections between the two units. If any plugs are loose or unplugged, reconnect them. Check to make sure none of the wires are stripped, rusty or broken off. After you reconnect the wires, rerun the washer to see if the error appears again.
Warning
If you do not know or understand the inside components of your Whirlpool washer, leave the job to a professional. Contact the store where you purchased the washer or Whirlpool customer service directly.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does PF 2 error message on Whirlpool duet washer mean?
Power failure most likely. To be sure remove the panel below the door and you will find the tech sheet. In it will be a list of errors and what to do to remedy
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I notice F22 error message on washer. Door seems to be jammed and will not unlock
This is a door lock failure code and it means the door lock is broken or just failed to unlock. Click on the links below for the detailed instructions for manually unlocking the door and replacing the door lock and switch assembly if it has indeed failed.
Manual Door Unlocking of Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Replacing the Door Lock and Switch Assembly on Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Mar 12, 2011 | Kenmore HE2 Plus Front Load Washer
I HAVE A FRONT LOAD WASHIER WHEN i PRESS THE BOTTIN IT CLICKS AND DOES NOT GO ON MESSAGE fL Do I need a new board?
no, this is what it means :
"F/dL" Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Feb 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does the message F1 mean, I have a Whirlpool caprio top loading washing machine
Hi
Thanks for using FixYa. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer
F/11
Serial Communication Error
Communication between the Central Control Unit (CCU)
and the Motor Control Unit (MCU) cannot be sent correctly.
Check Wire Harness connectors to the MCU, the motor, and-
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
F/dL
Door Lock Error
Check the wire harness connections to the Door Lock/Switch-
Feb 23, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Kenmore he4t washer shows f-11 error
F-11 // WILL THEN APPEAR FDL CODE DOOR LOCK LOCK FAILURE, F-11 COMMUNICATION ERROR REPLACE MAIN CONTROL,, JUST REPL 3 TODAY ....
Nov 28, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Washing Machines Logo
80 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
