Question about Whirlpool LSR5132PQ Top Load Washer
Washer fills, then just hums for about two minuts and shuts down
  • Whirlpool Master
  • 1,902 Answers
Hello
The hum sound is coming from the motor that is probably bad and needs replacement. Hope you understand...the washer fills with water which indicates that the control and the water inlet valve are both fine however, as after this you hear a hum sound it means that the motor is bad. Please get back to me if you have any other questions.
Kevin
Posted on Nov 09, 2010
5 Suggested Answers
  • 4 Answers
SOURCE: shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Posted on Sep 02, 2008
JR JR
  • 116 Answers
SOURCE: Washer starts but motor louder than normal
POSSIBLE INSPECT MOTOR AND CAPACITOR
Posted on Nov 30, 2008
blueextc3221
  • 15935 Answers
SOURCE: washer will not drain, just hums then shuts down
If you put it on wash - does it agitate?
If not - Most likely the coupling is failed.
Any way you look at it - you will need to empty as much water out as you can - because to replace the coupling - the pump must be disconnected.
CLICK HERE to see the coupling.
Another telltale sign of a failed coupling are black rubber bits, and plastic pieces under the washer when you tip it up.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2009
blueextc3221
  • 15935 Answers
SOURCE: washer won't agitate
It appears your Agitator/Agitator Dogs has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Sep 16, 2010
Maytag washer (LAT7400AAV)shuts off during rinse cycle
The machine control board is programmed to allow a maximum continous fill time of six minutes
or an accumulated fill time of 8 minutes for each full wash cycle.
If the required fill time exceeds the time limit, the washer will shut down.
This is to prevent flooding in the event there is a loose hose clamp or damaged air dome hose.
Check the incoming water lines for a minimum pressure of 20 psi.
If lower, the customer can use smaller clothes loads and reduce the pressure to 10 psi.
An alternative solution would be to change the plastic inlet screens to metal screened washers
and remove the nozzle extender found in the water valve inlet hose near the dispener inlet."
Dec 10, 2014 | Maytag Washing Machines
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
My Front Load Affinity washer shuts off after a few minutes
Good Afternoon Lori - Thank you for your post! Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. If you noticed a humming noise, then once again it could either be a clogged drainage hose or pump that needs to be cleaned, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Jul 11, 2013 | Frigidaire Affinity ATF7000E Front Load...
NFW7200TW hums and does not turn or fill with water
if it doesn't fill the water valve will hum,first thing is to see if it's a problem with the house water valve or the washer valve,shut off the water supply,reomve the water hoses from the back of washer,mark the hoses so they go back on the same way,stick the hoses into the washer or a bucket and turn the water on,if water comes out of hoses then you know the problem is just the washer,check the valve,look at the screens where the hoses connect to the valve,usually sediment gets in there and the valve on the washer has to be replaced,on some the screens can be removed and cleaned,also you say you have trouble with the lock,what's humming is it the lock or the valve,if you turn it to drain and spin will it run?you could have a bad door switch,if door doesn't latch washer won't run but most likely bad water valve
Jun 15, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
What are the symptoms of a bad solenoid?
it shud hum when ok also u can feel a click when working
Sep 16, 2012 | Maytag Neptune Washer Door Mah3000aww
HI - I was given a Maytag Neptune MAH5500B - just installed it and it does not work! It just makes a humming sound but after 7 minutes it is still not filled with water or rotating or anything. The door...
ok check to make sure you have the water turned on
thsat 7 mins is just about right
it is shutting down on slow fill
, the humming kinda tells me the water valve is opening properly
and calling for water
please check the screen and source
let me know
Oct 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Kenmore Elite Oasis He Washer model #110.2706 will not fill with water. I have checked for blockage in the water lines and they are clean and clear. The washer is only two years old. It will hum like it...
Your fill valve needs replacing. Not too expensive to change. This is all based on the fact that you have checked both feeds to the washer hook up and that the shut off lever is fully open.
Jul 29, 2009 | Washing Machines
Shutting down on rinse cycle
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
196 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
