Question about Sharp AL 1631 Copier
Woodpecker noise II
I have a similar problem as "LOUD woodpecker noise" with a Sharp AL-1631 but with some variations that I think are important to list it separately.
I opened up the drawer to place more paper when still making a copy. After this, I got the LOUD Woodpecker noise and cant use the multi-bypass tray. I still get copies using paper from the drawer, but the noise is still there. I looks like a gear is rotating and hitting a plastic part. The noise comes from the multi-bypass tray and side cover.
I tried the following but the noise is still there and cant get copies from paper loaded in the multi-bypass tray:
1. Turn off/on.
2. Copy without the paper tray.
3. Copy without the TD cartridge.
Is there any solution for this?
  • CharlieGreen Jun 18, 2008
    Hi and thank you very much for your response. I would like to answer your questions about possible codes or the status of side door as follows.
    Side cover. The side cover closes without any indication of misadjustment. We tested again applying pressure to the closed cover but the sound continues.
    Codes. There are no codes shown on the screen. This machine is working great as always except for two things:
    1. Multi-bypass tray. The feeding mechanism of the multi-bypass tray is not working when requested using the operation panel. This is the only section of the machine that is not working.
    2. Woodpecker noise. This noise has a frequency that is similar to the pass/gap between gear teeth. It comes from an area that includes the side cover and the rear part of the machine close to the side cover. This frequency makes me think that probably a gear might be hitting a mispositioned plastic part of the feeding mechanism in the multi-bypass tray.
    Depending on your recommendations, I am planning to open up the section located between the paper tray and the multi-bypass tray beneath the copier.
    Please let me know your comments about this.
    Regards,
    Charliegreen
  • CharlieGreen Jun 23, 2008
    Theoldtech, thanks for trying. The copier is working fine, so far, after my secretary gave it a girly hit! I will have into account you recommendation if this happens again.
    Thanks.
Really Guys, Thank you so much , This was really helpfull, It fixed my printer, Thank you so much
Posted on Oct 22, 2008
Open the rear door above the bypass feed area. Find a small phillips screw on the bottom near the left side. It is located near the door interlock switch. Remove the screw and gently lift the cover starting on the left side. This will allow view of the paper pickup roller. There is a plastic piece over the pickup roller that was jammed in the down position. When it was allowed to move freely it returned to the up postion. Replace the cover and the small phillips screw. Close the door. Try the printer again. When I did this, the woodpecker noise disappeared and the copier returned to normal operation.
Posted on Jun 23, 2008
  • Sharp Master
  • 2,794 Answers
A technician should look at this. There could be a gear going bad on it. Ive see a fee cases where the drum gets bad and cant turn any more.
Are there error codes on the screen?
Make sure the right door where the bypass tray is closed all the way.
Posted on Jun 16, 2008
  • Tim Babcock
    Tim Babcock Jun 24, 2008
    Even after working on things for as long as I have I never knew about that. Thanks for the tip.
Woodpecker problem
Hmmm.
Since this question is in the Washing Machine category, I would tie a string to the lid of the washing machine, and put woodpecker food inside it. When the woodpecker flies in to get the food, pull the string and the lid ill close, catching the woodpecker.
Jun 13, 2015 | Washing Machines
When i close the back door it is making a loud noise. sharp al 1631
If it sounds like gears grinding it may be the fuser unit. The bushings and gears need replaced or new fuser unit.
Aug 31, 2010 | Sharp AL 1631 Copier
Where is the computer connection to this printer/copier? Sharp AL-1631
If your model number is 1631, there are no provisions for operation as a scanner or printer, it is a copier only.
The very similar 1641CS does have these features.
Jul 07, 2010 | Sharp AL 1631 Copier
I have a sharp copier AL 1631- it's making a noise
Hello sir; Bring back the toner cartridge to the store where you bought for exchange.
Feb 08, 2010 | Sharp AL 1631 Copier
Sharp AL-1631
there is severl thing this could be 1. paper feed cluch need cleaned 2-bypayss roller lift arm need removed, 3-or the drum unit need clened out . all thses thing can be dones easilly by a sharp tech about $120 should do it. note this is the only model of copier left that you can refill the toner unit for $6 & drum for $15 ( id keep it )
Mar 10, 2009 | Sharp AL 1631 Copier
SHARP COPIER AL-1631
2 things:
1. Fusing Unit has to be replaced- worn or broken gear
and/or
2. Main Drive clutch has to be replaced.
Either way it has to be done by a trained technician.
Dec 24, 2008 | Sharp AL 1631 Copier
Woodpecker noise II
A lot of times when this happens those grears need to be replaced. If you find a Sharp dealer in your area, they shold be able to fix it for you.
Jun 17, 2008 | Sharp AL 1631 Copier
I have the same problem with one of my clients copier and I open the machine from the by pass tray and the clucth from one of the gear there is a spring that it is broken the spring is cover by a housing tube it is very simple to fix but tidues to get to it they don't sell this part
Carlosavalencia@roadrunner.com
carlos
May 28, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
651 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
