Question about Kenmore Elite 45986 Front Load Washer
HE3T washer screw at base front side
Star shape, my allen wrenches do not really work. Where do you get the tool to get these screws out? Michelle
    Genius:
  • 1,036 Answers
This is known as a Torx fastener.
They come in many sizes like allen screws.
There are even security fasteners with a pin in the centre.
Most mechanics centres and online tool suppliers stock them.
Snall sizes can also be supplied as hexagon bits for replacable-tip screwdrivers. Larger sizes available in 1/4" & 3/8" socket drive.
Look for the word Torx.
If this helps you locate them, please rate as Fixya!
Thanks.
Posted on Jun 16, 2008
What type of screw driver do we use to remove the screws from an Oreck cordless steam iron?
these days a lot of mfg r using Torx screws.
It almost looks like an Allen wrench except it is shaped like a star.
UNLESS the mfg doesn't want u to take it apart, then it has a security pin in it to prevent u from using a regular driver.
Sep 13, 2014 | Oreck Cordless Iron Model JP8100C In...
Where is the belt in my Miele upright
You will need a Torx wrench (a special star-shaped wrench that is similar to an Allen wrench), to pull off the bottom plate. Once you do, the belt is easy to get to. Torx wrenches are a little uncommon, but they are normally sold in numbered sets, so either take the vacuum with you to the hardware store, or get a good idea of the size by looking at the screw head.
Jul 19, 2014 | Miele Vacuums
Star shaped tool
Torx bits...are standard sizes. Can get them at any parts store. Much like Allen wrenches.
Jun 04, 2014 | 1995 Lexus ES 300
Star shaped bolts in 1997 Kia mentor engine
That is referred to as a torque head screw. Most are metric. You can buy them in a set or just the one you need at most auto stores. The tool fits on your socket wrench. They come in 3/8 and 1/2 inch drive.
They also have sets on swing out handles like the Allen wrenches have. Most likely you'll want to find the socket wrench type for this application. I hope this helps.
Oct 26, 2013 | Cars & Trucks
Water inlet screws
those screws are called security torx(star) or allen(hex), and can be found online or hardware stores.
Jun 28, 2012 | Kenmore Dishwashers
Vornado 533 grill removal
Vornado 533 black Vornado Fan.
FULL GUIDE, DISSASEMBLY AND CLEANING. NOISE FIX.
Recommended tools.
  1. #2 phillips head screwdriver.
  2. Small handheld flashlight.
  3. Flat prying tool like a flat head or a dull knife.
  4. Small wrench, adjustable wrench, or pliers.
What mistakes I made.
  • I undid the screws on the axle/hinge for angle adjustment. Not nescisairy.
  • I tried to do the tabs before finding the three screws on the back of the fan cage.
How to get the grill off.
  • Get a small tipped but long phillips head screwdriver. 3 inches will likely work fine.
  • Position the fan to be completely level, like the normal non- angled position. Parallel with the base arms.
  • On the back are three small silver screws, remove each. (Don't lose them!)
  • Push plastic tabs on the outer rim of the back of the cage downwards, to the center of the ring. You may want a prying tool like a flathead screwdriver.
  • Pull off frontal grill.
Removing Rotor.
  • To clean the fan, take off the center bolt (You will need a small wrench, but pliers may be used if it's your only option.) think the front bolt may have been reverse threaded?
  • Pull the fan off of the rod, notice how the rod has a flat side.
  • There is a small unique shaped washer underneath the fan, it has a shape that aligns with the plastic of the fan, on it's bottom face. Remember it's position. I remember it being concave outwards, but I may be mistaken.
Cleaning the fan.
  • I then pulled off a bunch of cat hair, and wiped off dust from all parts, especially the spinning rod part. I gave the fan a few quarter second squirts down into the crack of the rod with WD-40s.This got rid of my squeaking noise!
Re-assembly
  • I then put the funky shaped washer back on, and aligned it with the plastic rotor as I slid it back onto the rod. Put the front nut back on, with washer before it. I think the front bolt may have been reverse threaded, can't remember.
  • I then carefully aligned the front grill with the screw holes on both sides of the grill, and re tightened the screws. Make sure you get them nice and snug, otherwise it will be loose and could cause vibrations.
May 11, 2012 | Dryers
LFX25975sw
There are Allen set screws on each end of the handles (Top/bottom for the refrigerator doors, left/right for the freezer compartment.) These screws are accessed through small holes in the side of the handle with a 2.5 mm (3/32") Allen wrench. There are on the bottom side of the freezer handle as it's installed. There are also mounting brackets under the handle that can be tightened with a 1/4" Allen wrench with the handle completely removed.
For pictures of the handle hardware, see page 9 of the manual for the LFX25975SW. This is page 10 of the pdf here: http://www.managemylife.com/mmh/owner_manuals/2228/LG-Bottom-Mount-Refrigerator-L0906255 . This link should display in your browser.
I hope this helps.
(Allen wrenches (Hex keys) are L-shaped tools with a hexagonal design where it contacts the screw head. You'll need the long side to get into the holes. Do not overtighten the screws - this can strip the threads. Then you'd need to replace the entire handle unless you can work a new screw into the spot.)
Apr 26, 2012 | LG LFX25975SW (247 cu ft) Bottom Freezer...
What size allen wrench to open panel of the bosch dischwasher
It is not an allen wrench you need but a torx wrench (looks like a 6-point star). DO not try af open with an allen wrench or you will strip the screws.
Jan 17, 2011 | Bosch SHU9915UC Dishwasher
What tools are need for monte carlo front brake job
Hi: You'll Need a Floor Jack ,Jack Stands, To Keep it Safe ,Loosen Lug Nuts on Front Wheels Before You Jack it up. Then After Tires are Off, You'll need a 3/8 Inch Either a Allen L-Shaped Wrench or Even better and i Recommend you Use a 3/8 Inch Socket Type Allen Wrench,Using this you'll need a Ratchet to Fit the 3/8 Inch Socket Allen ,This Allen Socket is needed to Break Loose your Caliper Hold Down Bolts,There Located on Back Side of Caliper Theres On 2 of Them.Then You'll Rock the Caliper Back and Fort until it Comes out of the Caliper Bracket.If its Stubborn you Might Need to Use a Large Screw Driver to get Sme Leveage Under the Caliper to Get it Off.The You'll see the 2-Pads ,HERE Look and See which Pad goes in the Back Side Of Caliper and Which one to The Front Side.Normally the Pad With a Spring Like Tab Goes on The Inside And That Tab Fits into the Caliper Piston.Then you'll Need a Large C-Clamp To Compress the Caliper Piston Flush or Even With The Caliper Housing. You can Use 1 of the Old Pads To Tighten and Compress the Piston Back.The Old Pad you Use will be used on The Piston Side. As Far as Tools Thats Really ALL you'll Need. T\Let Me know How I Helped you By Voting on My Solution i Sent You. Thanks the WYOCWBOY
May 30, 2010 | 1999 Chevrolet Monte Carlo
Kenmore Elite 45986 Front Load Washer Logo
125 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
